Touch/Motion Faucets - General Discussion - Contractor Talk
Old 11-22-2016, 05:12 AM   #1
Big Shoe's Avatar
Rewards Points: 2,122
Been researching these. Getting new granite tops in my renovated 2nd kitchen. No more stairs. The wife and I moved downstairs (1st floor).
Pros/Cons. I picked up a standard Grohe yesterday. I have 10 or so days to decide. They will bore the holes at install.
For those of you wondering, the main living area is the second floor.
My plumber has only installed 3. Can't really give me any feedback except he recommends Moen.
Expect the Unexpected
Big Shoe is offline
Old 11-22-2016, 06:35 AM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,750
Re: Touch/Motion Faucets
I've only installed one and it was a Moen...two years ago.
No problems and works as advertised.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 11-22-2016, 06:55 AM   #3
builditguy's Avatar
Rewards Points: 2,080
We've only installed 1. Also a Moen. It's been 2 years with no complaints.
builditguy is offline
Old 11-22-2016, 09:00 AM   #4
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Same here only one install 5 years ago "Delta" worked fine no call back.
What i did see a few years back before the touch/motion was a foot control in the toe kick.
sunkist is offline
Old 11-22-2016, 09:21 AM   #5
diplomat
Golden view's Avatar
Rewards Points: 1,550
One of my only callbacks. It was a Delta. Delta sent a whole new unit.
Golden view is offline
Old 11-22-2016, 10:17 AM   #6
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,062
We’ve installed a few (all Moen). We took one out after 6 months at the customer’s request. For them it was too sensitive – just getting close to it turned it on – when they didn’t want it on.
We’ve heard from another client that their cat turns it on.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
Big Shoe (11-23-2016)
Old 11-22-2016, 11:00 AM   #7
VinylHanger's Avatar
Rewards Points: 13,022
We've done one. Same deal, too sensitive. Everything we would go to open the window or dust the counter, it would go off. This was in a house on the market. Living with one would be a nightmare to me.
The faucet spins all the way around, so if it is over the back splash and gets turned on by the cat, or an errant arm, it is now running all over the counter. It also doesn't turn off as easily as it turns on. Especially if you are panicking.
I do think it would be cool when cooking and have meat juice on your hands though.
VinylHanger is online now
Old 11-22-2016, 07:33 PM   #8
fred54's Avatar
Trade: contractor
Rewards Points: 292
just installed a Delta, waiting for the third replacement solenoid from Delta. Drip drip drip.
I think Grohe is a little higher end though.
It's weird for me I can't get used to it but the client uses it every day and they like it.
fred54 is offline
Old 11-22-2016, 08:21 PM   #9
rrk's Avatar
Rewards Points: 4,946
I have done a couple of Moens also. The sensitivity can be adjusted
rrk is online now
Old 11-22-2016, 10:37 PM   #10
DLynch0009's Avatar
Trade: Residential Remodeling
Rewards Points: 306
Installed a few Deltas, and only one Moen that I remember. I do know they were all in older houses and if you don't have that filter off at the end of the faucet spout it will suck debris in the pipes into the valve that mixes the hot and cold water, which results in a contant drip (this is on the Deltas). Replacement part is easy enough to put in though.
DLynch0009 is offline
Old 11-22-2016, 10:57 PM   #11
antonioooooooo's Avatar
Trade: framing, finishing.
Rewards Points: 429
I installed a Delta touch faucet at my house, and I hate it. Turns on when I don't want it too, turns off when I don't want it too.
antonioooooooo is offline
The Following 2 Users Say Thank You to antonioooooooo For This Useful Post:
Big Shoe (11-23-2016), DaVinciRemodel (11-23-2016)
Old 11-23-2016, 04:16 AM   #12
Big Shoe's Avatar
Thanks guys.
I didn't mention I worked in a couple homes that had these. Had to unplug them because they kept coming on while I was working.
I'm leaning towards not getting one at this time. Going to do some more research.
Big Shoe is offline
Old 11-23-2016, 08:32 AM   #13
You should go for it Shoe
Big Shoe (11-24-2016)
Old 11-23-2016, 03:07 PM   #14
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,838
Plumbing and electricity should never mix in my book. You're in the airport or gas station bathroom flailing your hands around, doing a jig, and the damn water still isn't coming on in the sink. Maybe you try the one next to it. Might work, might not.
I just installed one of these for a customer. Easy enough installation, but I'm sticking with mechanical.
Kowboy is offline
The Following User Says Thank You to Kowboy For This Useful Post:
Old 11-23-2016, 05:12 PM   #15
rselectric1's Avatar
Rewards Points: 948
I've been called in twice to install receptacles since the batteries didn't last long. I don't recall the brand(s).
I can see many instances where such a device could be bad. Such as pointed out above with the cat on the counter setting the thing off all day BUT with the stopper in the drain.
I wouldn't want one.
rselectric1 is offline
The Following User Says Thank You to rselectric1 For This Useful Post:
Old 11-23-2016, 07:54 PM   #16
MarkJames's Avatar
Rewards Points: 19,031
More stuff to malfunction, as far as I'm concerned. Simplicity is best. Get something with a lever and bump it on with the back of your wrist. Problem solved!
I just replaced a couple hands-free Kohler Cimarron toilet tanks for a client because of ghost flushing in the night that was driving them nuts. (Yes, they can be fine-tuned and made drip-free inside the tank lid to prevent that, supposedly....but wth?!)
Oh, I have those tanks now...any interest here? Anybody? Bueller?
MarkJames is online now
Old 11-23-2016, 08:00 PM   #17
Shoe, you should invest in one of these.
http://quatreauusa.com/
Old 11-23-2016, 08:01 PM   #18
Only $9,000 before taxes and shipping
Old 11-24-2016, 05:39 AM   #19
Big Shoe's Avatar
Looks like something I could use............Thanks
Big Shoe is offline
Old 11-24-2016, 08:51 AM   #20
Everyone should have at least one
faucets that won't move on smooth stone, etc. MarkJames Plumbing 7 03-11-2016 10:56 PM
Pex Manifold - Distance to Faucets GTHill Plumbing 15 01-05-2014 04:13 PM
What's this No Lead Law with Faucets ? We Fix Houses Plumbing 3 12-27-2012 10:54 PM
Plumbing fixtures and faucets tygerpaw Contractor Swap 0 04-10-2010 08:20 PM
Water Heater noises & air sputtering at faucets LarryS Plumbing 10 01-10-2009 10:41 PM
