Tolerable Wood Moisture Levels? - Page 4 - General Discussion - Contractor Talk
Old 07-14-2015, 04:32 PM   #61
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Re: Tolerable Wood Moisture Levels?
Can I say a few things about the work we do? I am not naming the company that I work for yet.
We are required, and DO, take before photos, during demo photos, and after we are done photos! For a small job, approx. 25, mid size, approx. 75, large job who knows how many??
So everything is documented, sent to the Insurance company, BEFORE we do the work!
Dave in Pa is offline
The Following User Says Thank You to Dave in Pa For This Useful Post:
hdavis (07-14-2015)
Old 07-14-2015, 04:43 PM   #62
BucketofSteam's Avatar
Trade: renovations
Rewards Points: 7,631
Things do slip through though.
BucketofSteam is offline
Old 07-14-2015, 10:00 PM   #63
hdavis's Avatar
Rewards Points: 2,250
Seems as if I've been lucky.
Being lucky counts for a lot.
hdavis is online now
Old 07-15-2015, 04:22 AM   #64
Contractor Joe's Avatar
Trade: Drywall
Rewards Points: 153
I am confused here? I do this type of work, and willing to help ya out! Let me say one thing first, I WILL never say a bad word about a competitor company, nor their work!!
So, why Is Servpro coming out next week?
We respond to site in 4 hr. or less, doesn't matter if homeowner calls, insurance company, who-ever, then go from there! We will work with the customer for cost later, cure the problem, FIRST! We will delay IF it is a hazard to the workers, due to weather etc.
As for the problem, I assume that there is NO insulation there, and it doesn't appear to be a large amount of water? Insulation will not dry out and will cause a issue!
For us, FROM the picture only, we would not tear into the ceiling, unless the readings were in the 20% or above range, most houses, pending air-conditioning, heat, etc. will be in the 8-13/15 % range, BUT they all vary, that is WHY WE DO A UNAFFECTED area test reading, in many places to compare to! Then we evaluate it and go from here!
And a few more thoughts, we will not, and really not set up drying equipment, if the problem, leak, source, was not corrected of fixed. Just no reason to, like beating a dead horse! And for the cost of $1000 of dollars to do, NOPE, pending on the situation, 200 best buy gift card the job, time to dry, etc. MOST insurance companies pay us direct, with no "out of pocket" money from the home-owner, with-out the deductible thing. Not sure if the rate will go up, I can't answer that! Being truthful here!!!
But I will say one more thing, saying this in a very POSTIVE way, as long as Servpro is in my area, I have work to do!
I definitely would not get my hands dirty on this...
Contractor Joe is offline
Old 07-15-2015, 03:22 PM   #65
GettingBy's Avatar
Rewards Points: 6,486
So the company reduces the risk to themselves by overkill but the homeowner pays the cost of the company's risk reduction and the cost of reducing his own risk.
The risk to the company should be borne by the company's insurance company and they pay for this other party assuming risk. The HO should only pay for his own risk reduction.
One problem is, after the fact, no one can tell how much remediation is/was necessary.
There must be studies done on reasonable measures to take in these situations but the HO may not read up on these and the company has no incentive to do so.
It seems the only cure is an informed HO but this HO is a bad customer. He knows too much.
GettingBy is offline
Moisture in wood rjconstructs Tools & Equipment 12 04-23-2015 12:19 PM
mud or wood icerock drywall Drywall 2 08-17-2012 10:50 AM
Roof rafters, floor joists. Wood to mortar contact. Baltimore Masonry 16 08-04-2012 02:58 PM
going over existing wood shakes davinci Windows, Siding and Doors 33 07-08-2012 07:09 PM
Top 10 framing errors - and how to prevent them (From a Professional Builder Email) wallmaxx Framing 9 02-20-2012 07:57 PM
