Tolerable Wood Moisture Levels? - General Discussion - Contractor Talk
Old 07-10-2015, 06:42 PM   #1
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Is there such a thing? We had a small roof leak, filled a bucket about 1/4 inch during an extremely heavy down pour.
I went to look at the ceiling (picture attached) and wasn't able to notice where the leak was until I saw the buckets. Homeowner is concerned the structure of the house (100+) years old may be compromised.
They are having servpro come out to do a moisture test next week. I want to know what I'm talking about. The ceiling doesn't look any different to me than I'm sure it has for years though. I'm concerned, knowing how that company is, they'll find something and want some ridiculous number to fix it.
P.S, the actual yellow stain is not from us. That's been there for awhile. Only area it dripped in was above buckets.
BamBamm5144 is offline
Old 07-10-2015, 07:22 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,030
Re: Tolerable Wood Moisture Levels?
Wow. You sure can pick 'em, Bam.
I wish I could give you an authority to quote other than just common sense. Consider this: probably 80-90% of new housing, especially back 100 years ago, gets rained on and thoroughly wetted before it's dried in--without any structural issues related to that.
Servpro may come up with some Chicken Little stuff about fast drying vs mold concerns, but I doubt even they would try to claim structural problems caused by a one-time leak.
Tinstaafl is online now
rrk (07-11-2015)
Old 07-10-2015, 08:25 PM   #3
Yeah well this one is our mistake. He's been reasonable, just concerned about future problems.
Old 07-10-2015, 08:31 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,064
What's above the ceiling?
An appeaser is one who feeds a crocodile, hoping it will eat him last.
Winston Churchill
Robie is online now
Old 07-10-2015, 08:46 PM   #5
The second story.
Old 07-10-2015, 08:51 PM   #6
Robie's Avatar
I'm assuming you are replacing some ceiling drywall.....I have taken in my wood moisture meter before and done some comparative testing of what is known to be dry and what was once moist/wet.
Just a thought.
Winston Churchill
Robie is online now
Old 07-10-2015, 09:13 PM   #7
No, its plaster. If you look, there are lines, cracks and stains so we will see. Don't want to replace a ceiling that's 100 years old over one small leak. Fingers crossed.
Old 07-10-2015, 09:15 PM   #8
GettingBy's Avatar
Rewards Points: 6,486
IIRC, wood stabilizes at less than 15% moisture content?
Wood damage may result from sustained soaking but
how much moisture content
for how long
equals
how much loss of strength?
There may be tests for structural integrity for existing structures.
I'd go poking with an ice pick but for a more quantitative check you could pull on structural members with a comealong in series with a very strong spring and measure joist deflections.
The spring lengthening tells you the force if you know or measure the spring constant. Storm door snubber springs are ~40 lbs/inch but this spring needs to be stiffer, more like a rocker arm spring.
GettingBy is offline
Old 07-10-2015, 09:20 PM   #9
In your opinion, would an amount of water that filled up that bucket to about a quarter inch during one rain cause this problem?
Roof was finished a Wednesday. Hard rain Monday, leak noticed and fixed immediately, plaster dry to the touch with 24 hours.
Old 07-10-2015, 09:34 PM   #10
GettingBy's Avatar
Nah, think of all the roof leaks that go unnoticed for years.
I've never heard of a roof collapse from water damage, but I'm not a roofer.
This kind of event does seem newsworthy even if no one was hurt, so it would be reported somewhere.
If someone does know about this, how old was the house and where was it located (so we can figure yearly rainfall totals)?
I'd put Servpro on hold until you've done searching, pdf files hopefully. At least you'll know if they say something totally off the wall, which may cast doubt on other stuff that comes out of them.
Old 07-10-2015, 09:37 PM   #11
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Rent a couple of big dehumidifiers---that should take care of the moisture in the plaster--and perhaps hire a painter to paint the ceiling.
Your leak is unlikely to have caused any lasting damage---the age of the house means that it is not air tight and air sealed like todays structure---
That building can take a one time leak without an issue.
mikeswoods is offline
Old 07-10-2015, 09:44 PM   #12
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
You should be fine BAM.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 4 Users Say Thank You to TNTRenovate For This Useful Post:
CarpenterSFO (07-12-2015), Framer53 (07-11-2015), Jaws (07-10-2015), mikeswoods (07-10-2015)
Old 07-10-2015, 10:00 PM   #13
There is no humidity in the room or stains on the ceiling. There is nothing to paint. I believe the homeowners insurance company got him worried about the potential "damage"
Old 07-10-2015, 10:13 PM   #14
mikeswoods's Avatar
Those old places dry out very quickly---I'd be shocked if there was any lasting damage--
Old 07-10-2015, 11:48 PM   #15
Talking Head
EthanB's Avatar
Rewards Points: 438
It might be worth cultivating a relationship with a local dryout company. I know a guy in my area who is very well respected and he would be my first call if I ended up in your situation. I've seen some of the most incredible asshat-ery from some "remediation" companies. One of my regular customers had a small leak from a fridge and asked me to look at it. I tested moisture the next day, no insulation under the kitchen, and said that it looked to be drying well and no significant damage other than they should plan on replacing that section of carpet in their basement(it needed to go anyway).
The "remediation" company came in and tore out their HVAC, tile floor, subfloor and basement carpet. Dinged the insurance company for $20k. The very next fridge delivered leaked also. It took them 6 weeks to turn all the work around. What had sounded like a great "deal" turned out to be a huge headache.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
hdavis (07-11-2015)
Old 07-11-2015, 06:44 AM   #16
hdavis's Avatar
Rewards Points: 2,150
Wood prone to rotting rots above 30% MC, and it takes some time. I can cut down a tree, throw it in a pond for a while, then cut it up and dry the lumber with no rot problems. How do I know? That's exactly how bazillions of board feet were processed...
Green tree trunks were also used as structural beams. They didn't rot, either.
Wood has to get wet and stay wet for quite some time to rot. If there is structural rot in that area right now, it would be from past recurring leaks. As long as it dries out fairly soon, it will be fine. If that ceiling was strapped down and uninsulated, air flows freely through all bays, and it will definitely dry out fine.
hdavis is online now
Old 07-11-2015, 10:39 AM   #17
rrk's Avatar
Rewards Points: 5,398
If the leak is your fault get ready to bend over. Servepro will place a few $1000 a day dehumidifiers in the house, and may recommend all drywall and insulation be removed.
I have seen it done here with roof leaks, not as much with freshwater leaks. The one recently the tore everything out and sprayed white sealer on everything, carpet was removed. They were going to remove subfloor but homeowner's son stopped them.
Nothing good can happen when servepro shows up here at least
In a normal situation a leak is not a huge deal
rrk is offline
hdavis (07-11-2015)
Old 07-11-2015, 12:40 PM   #18
If servpro says there is a problem, I'm going to get my liability insurance involved. I'm sure they won't find anything.
I don't even know if its possible for wood to be rotted in this situation. If you look at the picture, you can't even see inside damage caused from the leak.
Old 07-11-2015, 01:11 PM   #19
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,543
The most you have to worry about is mold and mildew. If you let that go for a long time it might turn into rot.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 07-11-2015, 03:23 PM   #20
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
I am confused here? I do this type of work, and willing to help ya out! Let me say one thing first, I WILL never say a bad word about a competitor company, nor their work!!
So, why Is Servpro coming out next week?
We respond to site in 4 hr. or less, doesn't matter if homeowner calls, insurance company, who-ever, then go from there! We will work with the customer for cost later, cure the problem, FIRST! We will delay IF it is a hazard to the workers, due to weather etc.
As for the problem, I assume that there is NO insulation there, and it doesn't appear to be a large amount of water? Insulation will not dry out and will cause a issue!
For us, FROM the picture only, we would not tear into the ceiling, unless the readings were in the 20% or above range, most houses, pending air-conditioning, heat, etc. will be in the 8-13/15 % range, BUT they all vary, that is WHY WE DO A UNAFFECTED area test reading, in many places to compare to! Then we evaluate it and go from here!
And a few more thoughts, we will not, and really not set up drying equipment, if the problem, leak, source, was not corrected of fixed. Just no reason to, like beating a dead horse! And for the cost of $1000 of dollars to do, NOPE, pending on the situation, the job, time to dry, etc. MOST insurance companies pay us direct, with no "out of pocket" money from the home-owner, with-out the deductible thing. Not sure if the rate will go up, I can't answer that! Being truthful here!!!
But I will say one more thing, saying this in a very POSTIVE way, as long as Servpro is in my area, I have work to do!
Dave in Pa is offline
The Following User Says Thank You to Dave in Pa For This Useful Post:
hdavis (07-11-2015)
Moisture in wood rjconstructs Tools & Equipment 12 04-23-2015 12:19 PM
mud or wood icerock drywall Drywall 2 08-17-2012 10:50 AM
Roof rafters, floor joists. Wood to mortar contact. Baltimore Masonry 16 08-04-2012 02:58 PM
going over existing wood shakes davinci Windows, Siding and Doors 33 07-08-2012 07:09 PM
Top 10 framing errors - and how to prevent them (From a Professional Builder Email) wallmaxx Framing 9 02-20-2012 07:57 PM
