Tips And Tricks..... - Page 3 - General Discussion - Contractor Talk
Old 05-04-2020, 11:00 AM   #41
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,836
Re: Tips And Tricks.....
Originally Posted by Big Johnson View Post
Me or my electrician always block out switches at doors and in corners. I prefer to do it myself because if the electrician does it you can guarantee a hump in the drywall.
When I do it I rip 1/4” of the blocking to keep it just inside the edges of the studs.
Anyone who is not capable of banging on a scrap 2x and not get the two faces lined up should not be allowed to so much as even look at a hammer.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
SouthonBeach (05-04-2020)
Old 05-04-2020, 11:14 AM   #42
MarkJames's Avatar
Rewards Points: 19,393
It requires more finesse when one is banging nails with lineman pliers.
MarkJames is offline
Old 06-09-2020, 09:38 PM   #43
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,834
Regardless of how much purple primer and cement you need for the job, have at least one can of each extra.
Because no matter how careful you are, you're going to kick your last can into the trench 3 joints before you're done.
The Following 6 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
asevereid (06-10-2020), Frank Castle (06-10-2020), jproffer (06-10-2020), mrcat (06-10-2020), overanalyze (06-11-2020), SouthonBeach (06-10-2020)
Old 06-09-2020, 09:42 PM   #44
480sparky's Avatar
If, by 'finesse', you mean 8 more seconds, then yeah... I guess it takes more of it.
Old 06-10-2020, 05:58 AM   #45
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,776
Some 2x4’s are thicker than others. You’ve clearly been electrocuted too many times to know that. Or you’re just stupid.
Big Johnson is online now
Old 06-10-2020, 06:41 AM   #46
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 318
You only get electrocuted once. He may have been shocked too many times.
But you're right...some 2x4s are 1/64" thicker than others.
Jim P.
jproffer is offline
Old 06-10-2020, 07:30 AM   #47
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,017
I've seen 2x4s 1 1/2" to 1 5/8" thick. Depends on how green they are.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Big Johnson (06-10-2020)
Old 06-10-2020, 09:59 AM   #48
e·lec·tro·cute
/əˈlektrəˌkyo͞ot/
Learn to pronounce
verb
past tense: electrocuted; past participle: electrocuted
injure or kill someone by electric shock.
"a man was electrocuted when he switched on the Christmas tree lights"
Old 06-10-2020, 10:03 AM   #49
1-5/8 X 3-3/4 all the time. Way quicker to pick up a 2x4 and buzz a little off than it is to search around for the “right piece”.
Old 06-10-2020, 11:39 AM   #50
hdavis's Avatar
Rewards Points: 1,920
Also depends on what mill they come out of. Some mills run larger.
hdavis is offline
Old 06-10-2020, 12:57 PM   #51
VinylHanger's Avatar
Rewards Points: 13,388
I've had lumber from the same units be 1/8 different. Always fun.
Sent from my SM-N975U using Tapatalk
VinylHanger is online now
Old 06-10-2020, 08:24 PM   #52
Adamthebuilder's Avatar
Trade: Builder
Rewards Points: 330
I have a file folder for each current job in Dropbox. For each one I have folders labeled, Documents, Plans, Trades, Estimates and Photos. Transfer all your photos in this folder. When you are looking for a particular photo, you know what Job it belongs to and you can find it easily.
Adamthebuilder is offline
The Following 2 Users Say Thank You to Adamthebuilder For This Useful Post:
asevereid (06-11-2020), Robie (06-12-2020)
Old 06-10-2020, 08:37 PM   #53
jproffer's Avatar
Rewards Points: 318
e·lec·tro·cute
/əˈlektrəˌkyo͞ot/
Learn to pronounce
verb
Does electrocuted mean death?
Many people use electrocution vs shock interchangeably. But the difference between an electrocution and an injury from an electrical shock is literally a matter of life and death. ... An electrocution means that a person has died as a result of an electricity.
It all depends on what Google hit you choose and how you were taught. I was taught this....which is a BIG difference.
Jim P.
jproffer is offline
Old 06-10-2020, 08:40 PM   #54
LRG WoodCrafting
Leo G's Avatar
But it doesn't mean they stayed dead. Electrocution and then revived is electrocuted.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 06-10-2020, 10:48 PM   #55
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 3,124
That's what she said.
Life - Liberty - Pursuit of Happiness
Freedom is a God-given right
2A is my personal guarantee
wallmaxx is online now
The Following User Says Thank You to wallmaxx For This Useful Post:
hdavis (06-11-2020)
Old 06-11-2020, 11:33 AM   #56
jproffer's Avatar
Rewards Points: 318
Ok then.
Jim P.
jproffer is offline
Old 06-11-2020, 01:25 PM   #57
Stunt Carpenter's Avatar
Rewards Points: 2,892
If you need to dowel something together a kreg shelf pin gig makes a great dowel guild also
https://builddaley.com/
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 06-12-2020, 09:02 AM   #58
The Sheriff
Jaws's Avatar
Trade: Builder
Rewards Points: 16,084
Truck Ass Wisdom of the Week
1) if you see someone about to actually ask you to do something text someone to call you. Then rush off for an "important meeting"
2) carry no tools. Your already set wearing the house shoes but if your wearing nice boots and have no tools you can be like "what do you want me to do, I'm standing here flatfooted. I got a pocket knife and a phone "
3) make sure always look at your calendar in your phone when someone asks to set a meeting, and shake your head and grumble a bit and say I can make thrusday at 2 work. I'll move some stuff around . Even if the calendar is empty
4) always show up after 9, that way you dont have to buy them a $5 cup of coffee too
5) 330 happy hour meetings are "networking" and if it becomes necessary to explain where you are at then say you have a "function" to attend
6) make sure to set your lunch appointment early as your other truck ass buddies will already have scheduled their lunch with someone. 2 hours is a lot of time to fill by yourself
7) it will seem weird but wear dark sunglasses so they cant see your eyes and stand behind people while they are working and smoke a cigar. This will make the snowflakes hate you, which is ok because it creates solidarity and teamwork amongst them and that is what creates productivity.
The older experienced hands will recognize your infinite wisdom of the "big picture" and appreciate your paying attention to their work. Always give atleast one example of how they could do their job "better" or more (efficient).
I'm full of all kinds of good leadership strategies like that
8) never miss an opportunity to say "when I was doing the work" or " when I did your job" I did it this way or this is how it was. It is important for their overall job security and satisfaction to understand you "get it" and are truly a wealth of knowledge and experience
Also always tell stories from your time in the trades. They love to hear about how competent their leaders are
9) when a sub gives you a price even if it's really low be sure to say how high it is and that he is trying to screw you around. Even when you give it to him make sure to say how it's because you like his work so much and because of his loyalty to your ever changing (volitlie) schedule
10) always schedule times to talk about discrepancies in payments to subs (like when you hold 10k for punch) for around 5 on friday. So if you do have to pay them more money they cant cash until Monday
Holler if you need some more advice hoss
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following 8 Users Say Thank You to Jaws For This Useful Post:
Calidecks (06-12-2020), Mordekyle (06-13-2020), onmywayup (06-12-2020), overanalyze (06-12-2020), pinwheel (06-12-2020), Seven-Delta-FortyOne (06-12-2020), SouthonBeach (06-12-2020), Tom M (06-12-2020)
Old 06-12-2020, 09:06 AM   #59
Trade: Highwayman
"How To Be A Big-Timer".
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Calidecks (06-12-2020), Jaws (06-12-2020)
Old 06-12-2020, 09:07 AM   #60
LRG WoodCrafting
Leo G's Avatar
Sounds like a recipe to get yourself shot
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Jaws (06-12-2020)
