Thoughts On Vinyl Siding Vs. Steel Siding? - General Discussion - Contractor Talk
Old 10-25-2017, 11:09 AM   #1
lge77's Avatar
Trade: Home Builder
Rewards Points: 1,002
Helping my brother with a fixer upper. Do you prefer vinyl house siding or steel siding and why?
lge77 is offline
Old 10-25-2017, 06:25 PM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,766
Re: Thoughts On Vinyl Siding Vs. Steel Siding?
Kind of depends on what part of the country you are in , but. Here I pretty much only put steel on , only 3 vinyl jobs in 20 years. IMO steel is a good way to go. When installed right you are pretty much done with it. Will not come off due to wind, holds up to hail pretty good , carries a fairly good warranty. Insulation can be added fairly easy when installing. It is a green product , if one cares about that. Personally I think it looks better then vinyl , steel will not fade like vinyl. I can install steel in cold weather without worry about it breaking.
Am sure there are other things too, I do every thing I can to talk people out of even thinking about vinyl.
Randy Bush is online now
The Following 3 Users Say Thank You to Randy Bush For This Useful Post:
lge77 (10-26-2017), Rio (10-27-2017), Tom Struble (10-25-2017)
Old 10-26-2017, 05:52 AM   #3
builditguy's Avatar
Rewards Points: 2,136
I agree with Randy, but unfortunately I live in the land of vinyl. I've only seen 2 steel jobs in the last 20 years. People are at the point they only consider vinyl.
builditguy is offline
Old 10-26-2017, 06:42 AM   #4
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,374
Vinyl is final here. Can't say I've ever seen steel siding on a residential home.
NYgutterguy is offline
Old 10-26-2017, 07:17 AM   #5
Randy Bush's Avatar
IMO the only real good thing can say about vinyl is it is cheap and goes on fast, For a flip where one is looking to make money it works. Steel does seen to be a regional product.
Old 10-26-2017, 08:58 PM   #6
Kumpel's Avatar
Rewards Points: 28
This
Kumpel is offline
Old 10-26-2017, 11:40 PM   #7
Dirtywhiteboy's Avatar
Rewards Points: 5,150
What is the green part
Where does the steel come from
We don't use exterior wall coverings over here, it's all wood byproducts or Cementitious products.
Dirtywhiteboy is online now
Tom Struble (10-27-2017)
Old 10-27-2017, 12:05 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 1,272
It's green because it's 100% recyclable and a lot of steel used in construction has been used before for something else.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
fjn (10-27-2017)
Old 10-27-2017, 07:13 AM   #9
Randy Bush's Avatar
Yep , try recycling vinyl , or Hardi = landfill I like getting paid to get rid of it rather then paying.
Old 10-27-2017, 10:49 AM   #10
Where does the metal come from???
Nothing green about it,,, it's a farce!
Vinyl siding issue redwood Windows, Siding and Doors 29 08-03-2015 10:15 PM
cheapest siding material (that is not vinyl siding)? UALocal1Plumber Carpentry 19 02-03-2013 06:55 AM
Vinyl siding ascott Windows, Siding and Doors 12 03-31-2012 10:00 AM
Getting roofing under steel lap siding? 232323 Roofing 1 11-17-2011 12:04 PM
Edco Steel Kore Vinyl Clad Siding wallmaxx Windows, Siding and Doors 2 12-18-2009 07:48 PM
