Is There A Good Foam For Under A Tub? - General Discussion - Contractor Talk
Old 10-04-2018, 05:06 PM   #1
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,562
In my personal house I have a 1 piece tub shower. I believe the floor is 7/16 osb embedded in fiberglass. I've noticed that the floor is far more spongy than the other 2 I have. I don't suspect a leak, or any major impact. I'm about to cover up my ceiling in the basement, which will mean I can't access the floor anymore. Im thinking about filling the tub half full of water and spraying some foam under there in an effort to help stop the deflection. Has anyone done this, and can they recommend a type? Im guessing I want closed cell.? Thanks
Sent from my SM-G935W8 using Tapatalk
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 10-04-2018, 05:28 PM   #2
Tom M's Avatar
Rewards Points: 906
Re: Is There A Good Foam For Under A Tub?
Its worth a shot. Ive done it with Great Stuff Gap filler and it does wonders.
Just make sure to over pump it so its ends up denser after it spreads out
Tom M is online now
Old 10-04-2018, 05:34 PM   #3
MarkJames's Avatar
Rewards Points: 20,301
I would forget about filling the tub halfway. That's an old wives tail for caulking, and mostly a waste of time.
MarkJames is online now
Old 10-04-2018, 05:41 PM   #4
t.carpenter00's Avatar
Trade: excavating/ drywall/ currently remodeling
Rewards Points: 292
We usually mix a bucket of 90 min joint compound and push it under there. Cheap, won't compact, and won't break up.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline
The Following User Says Thank You to t.carpenter00 For This Useful Post:
Mordekyle (10-05-2018)
Old 10-04-2018, 06:28 PM   #5
rrk's Avatar
Rewards Points: 128
you missed the part of no access
rrk is online now
Old 10-04-2018, 06:36 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 42
If the bathroom floor has proper joist spacing and sheathing, the place to address any "sponginess" is on top of the sheathing, not underneath it. The unit should have been set atop a base of mortar, thinset or foam. Unlikely anything underneath the sheathing is going to have any effect at all.
Tinstaafl is online now
Old 10-04-2018, 07:11 PM   #7
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 6,052
Never fill the tub with any water when setting it in a bed of anything.
Big Johnson is online now
Old 10-04-2018, 07:14 PM   #8
rrk's Avatar
Rewards Points: 128
I think he is going to drill a hole and shoot it through the hole
rrk is online now
JT Wood (10-05-2018)
Old 10-04-2018, 07:52 PM   #9
Tom M's Avatar
Rewards Points: 906
I use structolite on new installs. But when I came across something creaky and my only access was from the bottom I drilled a series of 1/4 holes spread around.
With the holes I stick the tip of the foam gun in it and blast until I see it ooze from a nieghboring hole.
Tom M is online now
Old 10-04-2018, 08:26 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 42
With my luck, I'd punch right through the tub bottom, guaranteed.
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
JT Wood (10-05-2018), rrk (10-04-2018)
Old 10-05-2018, 04:32 AM   #11
jeffmattero76's Avatar
Trade: Property Manager
Rewards Points: 84
The OP posted that AFTER he covers his basement ceiling he will have no access. Currently, he DOES have access as I read it.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline
Old 10-05-2018, 07:28 AM   #12
He currently has access to the subfloor underneath the tub, he won’t once he drywall’s the ceiling in his basement which is below the tub.
Old 10-05-2018, 09:04 AM   #13
Rewards Points: 84
Correct. That was what I stated.
Old 10-05-2018, 09:07 AM   #14
Mordekyle's Avatar
Rewards Points: 6,428
I’ve used the door and windows foam with success.
Mordekyle is online now
Old 10-05-2018, 09:41 AM   #15
rrk's Avatar
Rewards Points: 128
explain how to put drywall mud between a tub and subfloor from below the subfloor
rrk is online now
Old 10-05-2018, 09:55 AM   #16
Rewards Points: 84
I didn't say that was possible. I simply stated that the OP comment stated that he wanted to support it BEFORE he lost access by drywalling the basement ceiling.
My guess, as others have stated, is that the OP intends to drill holes in the subfloor and spray expanding foam under the tub. I don't believe he said anything about using drywall mud.
Old 10-05-2018, 09:44 PM   #17
JT Wood's Avatar
Trade: carpenter
Yes, the tub is on the main floor. I have partial access to the floor sheathing under the tub. (Drill Holes) These tubs are designed, and have built in feet to just simply put it in place and screw it to the walls. The bottom of the tub is actually a couple inches off the subfloor. We'e used probably 100 of these, and I have 2 others in my place that are rock solid on the base. I'm confident its not an installation issue.
It may be that this one was bad, or maybe someone fell in there and keeping it a secret. I honestly don't know. It's been this way for about a year that I've noticed with no real change, it just feels soft. I was concerned that the standard great stuff, may lose its structure after a couple years.
I thought if I put a 150 lb or so then added the foam, it would be less likely to cause problems, down the road. It sounds like it's not a concern.
Like tin says, My absolute biggest concern is putting 15 quarter inch holes in the bottom of the tub.
JT Wood is offline
Old 10-05-2018, 11:07 PM   #18
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I did it and it made my tub creak like a bastard...
Inner10 is online now
Old 10-06-2018, 07:54 AM   #19
Rewards Points: 84
Is there a "trouble door" at the faucet end of the tub? If so, you may be able to hammer in a few wedges to raise the tub slightly, and the squash in some structolite as far as you can push it under the tub, then remove the wedges. Let it sit for 24 hours before using the tub.
Design programs Kent Whitten Drafting & CAD Forum 72 04-24-2016 02:38 PM
Roofing Salesmen DALLAS - Good Fast Pay theADAM Help Wanted or Looking For Work 1 01-24-2015 10:46 AM
Good New Year Start greg24k General Discussion 30 01-22-2013 09:08 PM
Good Deals this week. Tylerwalker32 Tools & Equipment 2 11-27-2012 11:35 PM
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 02:50 PM
