Tape / Other Material To Hide Screw Holes In Metal Door Frame? - General Discussion - Contractor Talk
Old 05-28-2009, 09:21 AM   #1
Panzer5's Avatar
Rewards Points: 254
Anyone know of a product (i.e. a thin metal or vinyl tape) that I could apply to cover screws & recessed screw holes in a metal exterior door jamb that won't interfere with the door closing properly?
I've got a customer who previously had a steel exterior door installed. The rest of her doors are all wood with smooth painted trimwork. The metal jamb of the new steel doors has several recessed screws showing & she doesn't like the look - especially since it is so obviously different from the otherwise smooth trim & millwork throughout the rest of the house.
I thought about just caulking the holes & smoothing them over with a putty knife - but think this won't look all that good. So something like a thin tape might be the best bet.
Any ideas?
Scott (the ex-grunt-tanker-jarhead guy)
Panzer5 is offline
Old 05-28-2009, 09:48 AM   #2
Rewards Points: 2,000
Re: Tape / Other Material To Hide Screw Holes In Metal Door Frame?
Any ideas?
http://www.3m.com/US/auto_marine_aero/Bondo/
neolitic is offline
Old 05-28-2009, 02:34 PM   #3
PGD's Avatar
I'm not exactly sure where the screws would be, I've installed thousands of hollow metal doors, knock down metal frames, and if your talking about the large adjustment screws on the "stop" of the jamb.... you could bondo that up without interfering with the operation, however good luck removing the door in the future.
As for the trim area, I'm not aware of any screws that might be showing, unless the installer drilled and recessed his own holes....what type of frame is it, Timely, western integrated, Wilson partition? is it just a hollow metal one piece or 3 pieces? if it's just an open cased frame it should have come with some form of trim to hide the screws and they wouldn't be recessed...
Just tell the home owner that this is what security looks like and you don't wanna paste something on that's gonna look worse.
PGD is offline
Old 05-29-2009, 07:54 AM   #4
Panzer5's Avatar
Rewards Points: 254
They're pretty large head screws running vertically along the side jambs. The installer put them in correctly & they look fine considering what he had to work with. She just doesn't like the fact that they're obvious.
I thought about bondo, too, but didn't want to do something that might look bad. I know I can sand the stuff down to be flush with the steel jamb & she can get it painted afterward - but don't particularly like that solution.
That's why I thought something like a 'craft' tape or metal/vinyl tape might be a solution...
Panzer5 is offline
Old 05-29-2009, 08:19 AM   #5
Tape peels, scrapes, tears....
Bondo is permanent, paintable,
invisible when finished....
Column A, column B......?
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
nEighter (06-02-2009)
Old 06-02-2009, 01:33 AM   #6
Archania's Avatar
Trade: General Contractor, Electrician
Rewards Points: 25
Go for the bondo, that's pretty much exactly what it is used for anyway... Or there is some putty I have used before, kind of like spackle called "Crack shot" from Dap. Can be used on metal doors to fill in dents and whatnot.
Archania is offline
Old 06-08-2009, 01:44 PM   #7
Panzer5's Avatar
Rewards Points: 254
I went with the bondo. She loved it.
Tells me she's putting me on the "approved contractor list" for her complex.
Panzer5 is offline
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 88 09-01-2014 09:30 PM
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Metal Framing Help gambinos1983 Framing 7 04-06-2008 07:01 PM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
