Rewards Points: 12
Subfloor Sag Under Toilet
Thinking that the wax ring seal was bad, because of a sewer gas smell in the bathroom, I pulled the toilet in the photo. Turns out the toilet was not the problem. The smell was because the drain in the rarely used tub dried up and there was no water to prevent gas from backing up. That’s the background on why the toilet was pulled. Pulling the toilet revealed another issue. You can see in the photo that the subfloor has sagged on the right side of the drain. It has also sagged on the back side. On both sides the sag extends about two rows of tile and then it is fine. The front and left sides are ok. Judging from the look of the subfloor there was some water leaking at some point. I need to fix the floor before reseating the toilet and want to see if anyone has a better method then what I plan to do.
I’m going to remove the tile and cut the subfloor around the drain back to the joists (not sure which way they run). Then add supports to better support the toilet, replace the subfloor and re-tile. I’ll have to put the subfloor in as two pieces to be able to get it under the toilet flange but will make sure it is properly supported. Sound like a reasonable repair? [The shims in the photo are because I need to temporarily replace the toilet because I can’t repair the floor before Christmas day and I’ve got 20 people coming over for dinner. I need that extra bathroom]? ![]() Sent from my iPad using Tapatalk |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Radical Basement Dweller
![]() Trade: Whatever needs to be made or repaired
Rewards Points: 2,614
Re: Subfloor Sag Under Toilet
Incoming....
If you tell the truth, you don't have to remember anything. Mark Twain |
Rewards Points: 352
If the plumbing is cast iron you’re okay for the party 🤪
Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Caleb1989 For This Useful Post: |
SmallTownGuy (12-20-2018)
Sponsored Links | |||
Advertisement |
Rewards Points: 128
doesn't home depot have a sale on five gallon buckets now?
Trade: Home Beautification
Rewards Points: 412
Throw double wax rings on, and fix your toilet issues in another 5 years. Leave the shims they are a perfect repair!
![]() Paying a contractor to perform the surgery is going to be expensive for you. Start saving now...also have the wife choose new tile. |
The Following User Says Thank You to Peter_C For This Useful Post: |
ScipioAfricanus (12-20-2018)
Rewards Points: 5,304
What happened to the metal ring around the pvc?
Trump-The "Con Man's" Con Man. |
Trade: Handyman Services
Rewards Points: 16,103
Your flange is at least a 1/2" too low, so that helped it seep. But the floor looks salvageable to just replace the toilet. There are a couple ways to do it.
Rewards Points: 12
Re: Subfloor Sag Under Toilet |
#9 | |
Rewards Points: 12
Re: Subfloor Sag Under ToiletQuote:
The flange is low because of the sagging. I shimmed it up more than the photo shows. So, what are the “couple ways to do it”? Sent from my iPad using Tapatalk |
#10 | |
...there are flanges with "ears" where you can screw it down to the flooring outside the ring...go from there....or you can buy a flange insert with gasket...slide it into the existing ell (pipe), and screw that down....or you can buy a jumbo wax ring (which have even more wax than the ones at the big box). Go to a regular hardware store and pick one up. And you can cut some ply and shim the edges of the ring upward, etc. Screw all that down. Then use a jumbo wax ring, flange spacers or whatever you have. Last edited by MarkJames; 12-20-2018 at 02:25 PM. |
Eater of sins.
Rewards Points: 108
I don't think that the floor is sagging, I think the level is arched.
Andy.
https://andytardif.wixsite.com/website |
The Following 4 Users Say Thank You to ScipioAfricanus For This Useful Post: |
Rewards Points: 5,814
2x4 cleats from the ceiling below to underpin the sheathing that's shot. Then a fat horned wax ring with spacer. Deal with the drywall patch instead.
Sometimes lead bend wastes run to the side wall instead of the back and people unknowingly drive all kinds of screws into it because it's a weak connection which adds to the problem. Last edited by Tom M; 12-20-2018 at 06:26 PM. |
Rewards Points: 12
#15 | |
Rewards Points: 12
I don’t know what you mean Tom. There is no damaged sheathing and no drywall damage. The only problem is that section of the subfloor sagged. Don’t know why. Maybe it will be obvious when I open it up. Sent from my iPad using Tapatalk |
Rewards Points: 12
Oh. No smiley face. I know some people who would make that their first assumption.
The flange is screwed to a deteriorated subfloor sheathing.
If there is a ceiling below, I would open an access to underpin the floor then patch that up |
#18 |
Eater of sins.
Rewards Points: 108
What kind of contractor are you?
Hmmmmmmm? Andy.
#19 |
Capra aegagrus
![]() ![]() Trade: Remodeler
Rewards Points: 76
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed. Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Toilet dollys | platinumLLC | Tools & Equipment | 17 | 01-16-2015 08:25 PM |
Toilet Mystery | carolinahandyma | Plumbing | 9 | 01-05-2013 05:50 PM |
Is Access to a Toilet a ‘Basic Human Right’?: (This isn't a joke!) | MAULEMALL | Off Topic (Non Trade) | 50 | 05-28-2012 02:42 PM |
Easy, toilet replacement | fireguy | Plumbing | 21 | 05-12-2011 08:03 AM |
Toilet Challenge | Vermaraj | Plumbing | 40 | 11-09-2007 09:04 PM |
Go to Page... |
