Subfloor - General Discussion - Contractor Talk
Subfloor
Old 11-07-2019, 01:45 AM   #1
radon86's Avatar
Trade: general
Rewards Points: 8
Subfloor
Hello all, need some input. Need to build up a subfloor, 3/4"hardwood will be installed. Back story: house in the chicagoland area built in late 60's. Will be installing 3/4" hardwood throughout the house save for the bathrooms. Bedrooms and front room were carpeted but kitchen, dining room and hallways are all tile. While beginning to take up tile in the kitchen I come to find that tile was laid atop 2"mortar bed. Not just in the bathrooms, EVERYWHERE, (2400 sq'). I didn't know whether to laugh, cry or run. The mortar bed was thankfully poured over tar paper. In order to have subfloor flush with existing bedrooms and front room subfloors I need to make up 2 1/4". I am seeking any words of wisdom in the best manner to tackle this. (FYI-all floors must be same height) Thanks in advance to all.
radon86 is offline
Old 11-07-2019, 03:17 AM   #2
hdavis's Avatar
Rewards Points: 1,556
Re: Subfloor
2X4 sleepers and 3/4" subfloor.
hdavis is offline
The Following 6 Users Say Thank You to hdavis For This Useful Post:
A&E Exteriors (11-08-2019), fjn (11-08-2019), Morning Wood (11-08-2019), Seven-Delta-FortyOne (11-09-2019), stuart45 (11-07-2019), TheConstruct (11-07-2019)
Old 11-07-2019, 05:20 AM   #3
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 94
Re: Subfloor
Obvious as the nose on your face.
pinwheel is online now
The Following 3 Users Say Thank You to pinwheel For This Useful Post:
A&E Exteriors (11-08-2019), hdavis (11-07-2019), TheConstruct (11-07-2019)
Old 11-07-2019, 07:48 AM   #4
Bob's Building's Avatar
Trade: general contractor
Rewards Points: 16
Re: Subfloor
I would do the same but just use 1/2" and 1/4" ply instead of just the 3/4" plywood. Glued and screwed of course. I find it squeaks less and stronger too.
Bob
Bob
Bob's Building Services
Bob's Building is offline
Old 11-07-2019, 10:15 AM   #5
TheConstruct's Avatar
Rewards Points: 1,374
Re: Subfloor
Bob
But... why? That seems more expensive and labour intensive. I'd argue it would not be stronger and likely more prone to squeaks.
TheConstruct is offline
The Following 4 Users Say Thank You to TheConstruct For This Useful Post:
cedarboarder (11-09-2019), rrk (11-08-2019), Seven-Delta-FortyOne (11-09-2019), SmallTownGuy (11-07-2019)
Old 11-07-2019, 10:34 PM   #6
90%-er
onmywayup's Avatar
Rewards Points: 2,218
Re: Subfloor
Yeap. Sleepers glued and screwed, 3/4" T & G OSB, glued and screwed, is how we'd do it. Nice opportunity to shim the subfloor perfectly level while you're at it if needed.
Sent from my SM-G973U1 using Tapatalk
onmywayup is offline
The Following User Says Thank You to onmywayup For This Useful Post:
hdavis (11-08-2019)
Old 11-08-2019, 06:56 AM   #7
Rewards Points: 16
Re: Subfloor
My way is more labour but it works great. Glue and screw sleepers down shimming as needed or scribing and cutting to get level. Then glue and screw 1/2" PLYWOOD down. I hate OSB. Check for any low spots and pour SLC if needed. Then glue and screw 1/4" Plywood down. If down right will never squeak and if it gets wet will not swell up like OSB. And it makes it stronger because you end up with more thinner layers then is 3/4" plywood was used. The old houses i work in need all the help they can get, and this way was taught to me many years ago and i have been following it ever since.
But if you don't need that much strength or just need to get it done fast, 3/4" over sleepers will be ok for hardwood. I would not do just 3/4" for tiles. had to redo too many tile floors from other contractors that i do not trust it.
Bob
Old 11-08-2019, 10:53 AM   #8
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,547
Re: Subfloor
Don't know if you want to use OSB if your going to shoot down the cherry--unless the mfg's specs/okays it.
rescraft is offline
Old 11-08-2019, 11:16 AM   #9
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,222
Re: Subfloor
imagine the weight on those floors . wonder if the reduced ceiling height is noticeable .
JFM constr is offline
Old 11-08-2019, 12:28 PM   #10
pinwheel's Avatar
Rewards Points: 94
Re: Subfloor
Every hardwood flooring manufacturer I've ever laid specs 5/8" osb as a suitable subfloor
Old 11-08-2019, 01:12 PM   #11
radon86's Avatar
Trade: general
Rewards Points: 8
Re: Subfloor
Boy do I feel like dope, this was obvious. I think I was still in shock after discovering the mortar bed. 9’ ceilings so it won’t be bad. Thanks gentlemen for the quick replies and info. Really appreciated. Pinwheel, I’m stealing the witty reply, that was a good one.
radon86 is offline
The Following User Says Thank You to radon86 For This Useful Post:
pinwheel (11-08-2019)
Old 11-08-2019, 01:36 PM   #12
Remodeling GC
kevjob's Avatar
Rewards Points: 392
Re: Subfloor
Damn 2400 sq ft of mortar bed!!!
yikes that is a huge change order and weight in dumpster!!
kevjob is offline
The Following User Says Thank You to kevjob For This Useful Post:
hdavis (11-08-2019)
Old 11-08-2019, 07:38 PM   #13
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Subfloor
No pun intended, hdavis nailed it.
fjn is offline
Old 11-08-2019, 09:04 PM   #14
AustinDB's Avatar
Rewards Points: 1,352
Re: Subfloor
sure that's not gypcrete?
I've run into 1-1/2" gypcrete floors in multi-family units, although it was all carpeted. little rot goes a long way and joist failure from overloading.
some projects I might try to sell the upside by installing new doors/trim. that's based on the fact that base always gets replaced when I install new flooring and it's usually upsized from the old 3-1/4 to a taller profile. turn lemons into lemonade for $$
AustinDB is offline
Old 11-08-2019, 09:09 PM   #15
Box Builder
Morning Wood's Avatar
Rewards Points: 10,238
Re: Subfloor
When someone says osb subfloor that translates directly to advantech for me.
Morning Wood is offline
The Following 4 Users Say Thank You to Morning Wood For This Useful Post:
Bull Trout (11-09-2019), hdavis (11-09-2019), pinwheel (11-09-2019), Seven-Delta-FortyOne (11-09-2019)
Old 11-09-2019, 06:44 AM   #16
radon86's Avatar
Trade: general
Rewards Points: 8
Re: Subfloor
austinDb, you may be correct about the gypcrete. house is from late 60's/early 70's. hopefully it is, it'll be easier for me to take out. awaiting permit and dumpster so i'll be digging in in the next week. advantech is nice but too costly for the area.
radon86 is offline
Old 11-09-2019, 07:06 AM   #17
pinwheel's Avatar
Rewards Points: 94
Re: Subfloor
And not necessary in dry conditions like you've got.
Old 11-09-2019, 11:33 AM   #18
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 778
Re: Subfloor
Mortar bed was a pretty standard setting bed for tile for....thousands of years.
As recently as 20 years ago it was still used extensively.
Still used now in a lot of specialty situations.
Tile backer board products are fairly new.
Old 11-09-2019, 12:41 PM   #19
hdavis's Avatar
Re: Subfloor
By the time you glue and screw 1/2" ply then glue and screw 1/4" ply, you may have well just put down Advantec.
hdavis is offline
Old 11-12-2019, 10:26 PM   #20
Ken360's Avatar
Rewards Points: 56
Re: Subfloor
That was a common way to do it back in the day. Worked on a lot of older homes, where joists were set lower or were cut back to accommodate a thick mortar bed. I've seen it where they laid nailers down along the joist bay to hold planking for the mortar bed, with the tops of the joists cut to form a chisel edge with the mortar bed being as much as 4" thick. Not like they had decoupling membranes back then, lol.
Ken360 is offline
