Stud Finding Advice - General Discussion - Contractor Talk
Stud Finding Advice
Old 11-19-2010, 12:57 PM   #1
federicomuelas's Avatar
Trade: Public Art
Stud Finding Advice
Hi Everyone,
First of all thanks in advance for your advice!.
Here is my question; Im working on a public art piece for the New School of Architecture at the University of New Mexico. The piece comprises an outdoor large 900 sq feet screen that we are installing over an exterior wall in the building.
In order to screw the supporting system for the screen, made of 6 x 8 x 5/16 wall aluminum rectangular tubing, we need to find out the position of the metal studs inside the wall.
The building was inaugurated in 2006 but still no one; not the architects nor the contractors or the engineers (who calculated and designed the structure for the wall) can provide the exact position of the studs, they only know that they are 16 o.c. apart.
The existing wall is 5/8" glass-mat sheathing with 3/4 stucco and the studs are 6 18 gage galvanized steel studs with 1 5/8 wide flange.
They think a stud finder (even the most advanced ones) wont do the trick and therefore we need to cut open the wall, what it means that we will have to waterproof it afterwards (since its an outside wall).
This seems a bit extreme to me also since we dont need to be precise to the millimeter, we just need to put a #12 self-tapping screw in the center of each stud.
advice anyone?
Thanks!
Federico
federicomuelas is offline
Old 11-19-2010, 01:05 PM   #2
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
Rewards Points: 810
Re: Stud Finding Advice
use a small masonry bit to drill a series of horizontal holes, 1" apart. find the first one. after that, measure 16" oc. small holes can be filled with caulking like polyseamseal.
we're not in Kansas anymore Toto
essrmo is offline
Old 11-19-2010, 01:07 PM   #3
Trade: Public Art
Hi essrmo,
Thanks for your advice, we thought of that also, but still they insist on cuting the wall. I'm this close to take a flight to Albuquerque to just do it myself!
F
Old 11-19-2010, 01:13 PM   #4
Maxi-Pier Tech
essrmo's Avatar
Rewards Points: 810
cutting the wall will compromise the waterproofing integrity. that will in turn, lead to structual intergrity issues further down the line.
Good luck.
essrmo is offline
Old 11-19-2010, 01:16 PM   #5
JonM's Avatar
Rewards Points: 1,248
What finish is on the interior?
JonM is offline
Old 11-19-2010, 01:21 PM   #6
Trade: Public Art
that's what i thought about cutting the wall. they are suggesting to cut a hole on the wall inside the building that connect to this outside wall, but still seems to extreme to me.
hi JonM,
the wall is hollow, is this what you're asking?
Old 11-19-2010, 01:22 PM   #7
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
exactly Jonm find the studs on the inside, find a reference point such as a window mullion or door jamb and transfer
parkers5150 is offline
Old 11-19-2010, 01:35 PM   #8
Trade: Public Art
oh I see what do you mean, this is a standing wall, meaning the only part that connects to the building is one of the short sides (see attached image)
Old 11-19-2010, 02:40 PM   #9
JonM's Avatar
I'm willing to be they went 16 oc from the building wall outward...try a magnet...I would be totally surprise if no pictures exist of such a project going up....if only for liability purposes
JonM is offline
The Following User Says Thank You to JonM For This Useful Post:
griz (11-19-2010)
Old 11-19-2010, 03:13 PM   #10
Cletus's Avatar
Trade: Tube Installer
Rewards Points: 150
That's a pretty big piece to leave in the hands of guys stymied by finding some studs. Sounds like trouble.
I'm four blocks away, I'll keep an eye out for the screen tangled up in the trees across the street.
Cletus is offline
The Following User Says Thank You to Cletus For This Useful Post:
JT Wood (11-19-2010)
Old 11-19-2010, 03:40 PM   #11
Trade: Public Art
I Know!
when I tell my architects friends that I'm having such a hard time for them to figure out where the studs are they roll their eyes up.
there are some photos of the construction process but it seems that they are not of any use for this. And since I'm based in NY all I can do is to rely on them.
I'll pass them your ideas and let's see if at least they get inspired.
thanks Guys
F
Old 11-19-2010, 04:13 PM   #12
BarryE's Avatar
Trade: Remodeling & Painting
Rewards Points: 150
get a big enough rare earth magnet and you can probably pull that wing wall down
BarryE is offline
The Following User Says Thank You to BarryE For This Useful Post:
Gough (11-19-2010)
Old 11-19-2010, 04:23 PM   #13
Trade: Public Art
magnets, i like the idea too!
Thanks Barry
Old 11-19-2010, 06:33 PM   #14
Wayfarer Doors's Avatar
Trade: windows and doors/ construction supervisor
Rewards Points: 150
why not try a thermal(thermo?) camera. Use it early morning or night when there is a temp difference inside and out.
Wayfarer Doors is offline
The Following User Says Thank You to Wayfarer Doors For This Useful Post:
mikeswoods (11-19-2010)
Old 11-19-2010, 06:45 PM   #15
Gough's Avatar
Trade: painting
We end up using neodymium magnets for this type of thing all the time. As walls get thicker and thicker, we just switch to larger and larger magnets.
As a side note for whomever talked about using something like a window for a frame of reference, we use pairs of magnets for this as well: matching an attic location with a spot on the ceiling, for instance.
Gough is offline
Old 11-21-2010, 05:38 PM   #16
boman47k's Avatar
Rewards Points: 2,006
Simple metal detector??
boman47k is offline
Old 11-21-2010, 07:06 PM   #17
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
How many studs is that thing meant to secure to?
www.bcconstructionllc.com
BCConstruction is offline
Old 11-22-2010, 08:54 AM   #18
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
X2, this is probably your cheapest and quickest solution without compromising the wall. Keep the settings on week side and fine tune it as you wave back and forth, i am willing to bet you will pick them right up.
woodchuck2 is offline
Old 11-22-2010, 05:57 PM   #19
knoxwindowdude's Avatar
Trade: window,siding and roofing contractor
Rewards Points: 75
stud finding adviceprobely not to many on this site! Come on, No one caught this!
knoxwindowdude is offline
Old 11-22-2010, 07:36 PM   #20
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
My $.02...........In theory. A stud should be 14.25" +/- the wall covering from one corner or the other......
WNYcarpenter is offline
Tags
construction , finding , installation , stud , wall
fiberock aqua tough board on 25 gage stud Miked55 Drywall 8 02-06-2010 11:50 AM
Advice wanted for starting a construction firm P.J. Construction 34 10-09-2009 01:51 PM
Need advice on Greek Revival mikeremote Historical Restoration 3 05-12-2009 10:21 PM
Need your advice! rcesare Excavation & Site Work 9 03-01-2009 06:35 PM
Advice for starting Career as Operating Engineer TrendTherapy Excavation & Site Work 0 02-13-2009 11:07 AM
