Stone Veneer Install - Interior Chase - General Discussion - Contractor Talk
Old 09-02-2020, 12:17 PM   #1
Jon951's Avatar
Trade: HVAC Installer
Rewards Points: 6
Framed a chase for fireplace and son installed 1/2" drywall over it. Wondering if install of 1/4" Hardibacker over it is recommended or if drywall should be torn down and 1/2" Hardibacker or Durock should be applied before installing stone veneer.
Also, interior of chase is lined with 1/4" Durock. Planned on taping seams with mesh tape and thinset. Fireplace is propane fired 40k output with 4/6" concentric venting. Clearance between vent pipe and interior surfaces minimum of 10" all around. Someone I spoke to said 5/8" firecode sheetrock is often used. I'm guessing the format I described is fine in terms of fire protection, but seeking comments from others knowledgable about this type of thing. Thanks
Jon951 is online now
Old 09-03-2020, 03:37 PM   #2
Kingcarpenter1's Avatar
Trade: GC carpenter
Rewards Points: 8
Re: Stone Veneer Install - Interior Chase
Check your code. They don’t do Hardi in Tx. w/chase bare on inside couple inches clearance. With propane it shouldn’t be any problem
Kingcarpenter1 is offline
Old Today, 05:16 AM   #3
Jon951's Avatar
Rewards Points: 6
Thanks,
Sounds good
Old Today, 08:49 AM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 3,024
Seems like all the new builds I am around here they get Dura rock around the gas fireplaces before the rock is put on.
Randy Bush is online now
Old Today, 02:12 PM   #5
Jon951's Avatar
Rewards Points: 6
Randy...
do you see anything installed interior to the chase over the framing? Thanks
