Spray Foam Machine - General Discussion - Contractor Talk
Spray Foam Machine
Old 08-07-2010, 09:18 PM   #1
Don
rotarex's Avatar
Trade: Renovator/ Builder
Rewards Points: 508
Spray Foam Machine
hey guys i want to possibly add a spray foam setup to my tools.
question
is it a must to have a trailer or truck just for that tool?
and im looking to buy used whats a good name? the smallest machine this way it dont pickup space
and any glitches i should be worried about
is there different machines for different types of foam eg. organic or synthetic
thanks
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 08-08-2010, 08:05 AM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 182
Re: Spray Foam Machine
First you need to figure out which product you are going to sell... They can tell you what if any changes are required
Most of the large companies have packaged deals that you can buy for cheaper than trying it yourself
Trailers are generally preferred due to the need for heaters, storage of the houses, drums, air compressor (think large), and a generator
The smaller the sprayer, the longer it will take to complete a job & you may run into problems moving product through long hoses, etc...
Now if you want a nice little niche, go after a small sprayer setup that can fit in the back of a truck to spray behind showers & the band / rim joist area after they have been framed up - most large companies don't like spraying these area's as they have to charge so much to make money or do it almost at a loss if they think they will be spraying the whole house later.
Just my .02 from researching this a while ago
SLSTech is offline
Old 08-08-2010, 04:53 PM   #3
Don
rotarex's Avatar
Rewards Points: 508
Thanks SLS.
reason why im buying
#1 i know if my company is doing it, its done on time and when we need it done.
#2 i rather keep my own guys busy
#3 money
things are usually double the price and more here, now that our money is equal i use it to my advantage and buy state side, but you really get raped on shipping so i usually have things shipped to my family place and pickup there
rite now im looking into the DIY packages, i seen the videos on them and i know SLOW as F and god knows how much the gun setup with it will get busted, clog ect.
Custom Decks
Renovation
rotarex is offline
Old 08-08-2010, 05:21 PM   #4
Sean
SLSTech's Avatar
Rewards Points: 182
As an FYI - DIY packages are generally about twice what you would pay if you are setup with a company based on the coverage. Generally it is cheaper for me to hire it done than use those packs
The only area's that it doesn't apply to is behind the showers, or rim & band joists if we are going with a different type of insulation
Good luck
SLSTech is offline
Soy Based Spray Foam ApgarNJ Insulation 9 08-05-2010 08:36 AM
Spray Foam on the back side of Tounge & Groove Ceiling? J-Peffer Construction 10 06-22-2010 08:35 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
spray foam quesion mikeybobo Insulation 1 06-16-2009 08:40 AM
foam spray gun vs canned foam AustinDB Tools & Equipment 4 12-03-2008 08:30 AM
