Sparky Needs Advice With Leaking Water Heater - General Discussion - Contractor Talk
Old 08-05-2010, 07:41 PM   #1
RJS3rd's Avatar
Trade: Electrician
Maybe you guys can help me.
Long story short my mothers gas heater is leaking from the bottom. Enough that after ten minutes there is a sizeable puddle around it. I can feel the moisture around most of the bottom.
Im sure it needs to be replaced but it will be a few weeks before I can afford a replacement. My idea originally was to buy a small water pump with 2 hoses, one to suck up the water from a drip pan I can put under the heater and the other to pump it to a nearby sink.
Please tell me this can be done. I am camping out at my mothers this week so I can use a shop vac to manage the leak.
Thanks for any advice!
RJS3rd is offline
Old 08-05-2010, 07:55 PM   #2
rselectric1's Avatar
Rewards Points: 858
Re: Sparky Needs Advice With Leaking Water Heater
Where's the nearest floor drain?
rselectric1 is offline
Old 08-05-2010, 08:01 PM   #3
RJS3rd's Avatar
Trade: Electrician
There is none. Just a sink 3' from the tank.
At this point Im willing to surrender and just get any kind of pump to just pump the water out by the back door where it collects.
Its pretty bad actually.
RJS3rd is offline
Old 08-05-2010, 08:10 PM   #4
Rewards Points: 858
You're a good son!
What about shutting off the supply to the water heater as well as the gas or electric supplying it, (might only work if you you have shut offs on cold and hot sides), then draining the tank via a hose to the outside. Then only using the tank when absolutely necessary. (Fill it back up and run it only a couple times a week when absolutely necessary) Mind you I'm not a plumber-just throwing out some ideas.
My thought is that you will spend less time doing this on a sporadic basis than manning it 24/7.
Old 08-05-2010, 08:14 PM   #5
RJS3rd's Avatar
Trade: Electrician
That sounds a tad more extreme but I will look into it.
I found a dehumidifier pump for 77 at Lowes that might do what I want. Looking into that right now.
Thanks Mr. Multiplicity
RJS3rd is offline
Old 08-05-2010, 08:16 PM   #6
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Depending on how long before you can replace it, how bout drain it, and slide a water heater pan under it. Would then be able to just use a regular submersable pump to pump it out every once in a while.
Brett Hocking
Eagle Eye Construction/Aspen Custom Cabinets
Buffalo, WY
bhock is offline
Old 08-05-2010, 08:18 PM   #7
Rewards Points: 2,000
The nasty truth is....
it's only gonna get worse,
until it totally lets go.
Got a credit card?
neolitic is offline
Old 08-05-2010, 08:24 PM   #8
Rewards Points: 858
RJS please check your private messages.
Old 08-05-2010, 08:24 PM   #9
Project Superintendent
mudpad's Avatar
Got a credit card?
Yeah, why spend $77 bucks on a pump when you can replace for $450? Take out a pay day loan or something and replace the thing.
Steve
mudpad is offline
Old 08-05-2010, 08:42 PM   #10
Rewards Points: 858
Moved to General Discussion per OP, for more views and an intro and profile update have been promised.
Welcome in advance to CT.
Old 08-05-2010, 08:46 PM   #11
Vegas Plumber
CSINEV's Avatar
Trade: Plumbing, heating, & Cooling
Yeah I agree get a payday loan and replace it now before it gets worse. The amount of money your going to spend on a pump is the same for a loan fee. It's not worth the hassle. What state are you in?
CSINEV is offline
Old 08-05-2010, 08:53 PM   #12
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
slide a small section of pond liner (45 ml EDPM) under the unit and trough the water into a 5 gallon bucket. you'll be in the quick fix for less than $20.00
parkers5150 is offline
Old 08-05-2010, 10:10 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,283
You can't afford to replace the heater, but you're willing to throw money down the tubes on an interim and probably ineffectual compromise?
Unless Mom's situation is exacerbated by something you haven't mentioned, the thing to do is quit using the heater until it can be replaced. My grandparents had a coal-fueled cookstove in their kitchen, and the reservoir built into that was their sole source of hot water for many, many years. Even in this weather.
On the face of it, this is a no-brainer, guy.
Tinstaafl is offline
Old 08-05-2010, 10:13 PM   #14
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 64
It's (I assume) on the floor already...how would the water get into the bucket?
Jim P.
jproffer is offline
Old 08-05-2010, 10:16 PM   #15
always building
if its a gas heater then it should absolutely not be on the floor
Old 08-05-2010, 10:35 PM   #16
Rewards Points: 858
Since THIS did not occur as promised, I am closing the thread with the DIY script. Since I allowed yet another new poster to make an arse out of me again by giving the benefit of the doubt, regulars, please beat me silly and remind me of this thread.
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
New Gas Water Heater Which One? tuchodi Plumbing 7 02-22-2010 02:35 AM
ge water heater warranty coachbuilds Plumbing 7 01-27-2009 06:30 PM
Need advice on high pressure water mains. MC Excavating Excavation & Site Work 25 12-13-2008 08:35 PM
Water heater is leaking jerry1967 Plumbing 4 10-12-2007 05:52 PM
