Soundproofing Top Of Glass Partitions Question - General Discussion - Contractor Talk
Old 12-17-2019, 08:40 PM   #1
woodspike's Avatar
Rewards Points: 708
customer has an office space on the 6th floor.
they need soundproofing
the space is divided into 4 separate offices , by glass partitions, with aluminum frames .
ceilings stop 2 feet short of the cement ceiling.
they want me to close that space up , and soundproof as well as possible.
initially , on the phone , i told them i could build a stud wall partition to the ceiling , insulate it, then install soundboard on each side and drywall over that, and skim smooth.
when i got there , i found sheet metal a/c ducting ( a lot ), fire sprinkler-piping , electric , and plumbing pipes going in all directions, everything is exposed .
again , a lot ,
found out 2 other contractors came in , and priced it $2000 more or higher, they were planning on re-ducting , and moving pipes , shutting them down , and having to shut water off in the building.
so i told him i could possibly make panels in place , and cut around all the items as i went.
then i could install double soundboard , and 5/8 drywall on them .
my way , they can technically still work there as we do this
i told him it won`t be sound-proofed , but more sound-restricted
any better ideas?
is drywall more soundproofed than sound board? cork?
woodspike is offline
Old 12-17-2019, 09:33 PM   #2
rrk's Avatar
Rewards Points: 3,158
Re: Soundproofing Top Of Glass Partitions Question
quiet rock, roxul and green glue
rrk is online now
Old 12-17-2019, 09:39 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 368
Wasting your time and their money.
Your issue is the glass and aluminum frames.
Its an expensive fix.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (12-18-2019), rrk (12-17-2019)
Old 12-17-2019, 09:45 PM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,814
Cut drywall around pipe then tape it tight. You could even spray foam it. With that said, I think Griz is right the sound is more than likely a glass and frame issue. Hard to believe just closing off the top will solve their issues. They arenít going to be happy to pay for something that didnít work and thereís a good chance it wonít. Imo
Mike.
_______________
Calidecks is online now
Old 12-17-2019, 10:46 PM   #5
TheConstruct's Avatar
Rewards Points: 1,372
Won't it have to look decent? I think what you described won't.
TheConstruct is online now
Old 12-17-2019, 11:15 PM   #6
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 882
Once you make a room ( a cubicle that the walls go all the way to the ceiling ) the fire suppression system needs to have a head in there
Then of course the other heads may need to be relocated.
I am no expert in suppression systems but I think 8 ft is the distance for each head.
Still "Shakin" the tree boss
sunkist is online now
The Following 2 Users Say Thank You to sunkist For This Useful Post:
Calidecks (12-18-2019), Rio (12-18-2019)
Old 12-18-2019, 05:48 PM   #7
sunkist's Avatar
Rewards Points: 882
It may well be 8 feet is the distance for the spray so head separation is 16 ft
Old 12-18-2019, 08:46 PM   #8
Stunt Carpenter's Avatar
Rewards Points: 2,222
I did a doctors office last year with the same problem. It was a Reno and they had two furnaces above the tbar.
We ended up installing a noise canceling machine above the ceiling grid that helps a fair amount.
https://builddaley.com/
Stunt Carpenter is online now
Old 12-19-2019, 08:01 AM   #9
builditguy's Avatar
Rewards Points: 1,930
I've had requests for several sound proof offices.
In my experience it can't be done. Sound proof rooms can be done, but they are expensive and require alot of space. In offices they don't want to pay for sound proof. Just a sound proofing door will be over $3000.
In your case, it is a no win situation. The glass and doors can't ever be improved. You've also got the fire suppression issue and heating and cooling in the offices.
Can pretty much guarantee they will never be happy with the sound emissions.
I am interested in the noise cancelling machine.
builditguy is offline
Old 12-19-2019, 08:09 AM   #10
Iím not expert but it essentially listens and sends out a counter wave to the sound it hears.
I canít find the specs on the one that I installed. It was a simple plug and play set up.
Old 12-19-2019, 08:11 AM   #11
Tom M's Avatar
Rewards Points: 7,150
As tempting as it might be to dive in to align yourself as the go contractor, commercial work requires a permit.
Which in turn hands off design responsibility. Better off, plus all of the mechanical's need to addressed. Not cut and dry
Tom M is online now
Old 12-19-2019, 10:56 AM   #12
rrk's Avatar
can be done, I used to do a lot of trim work for a large law firm, they had 3 large sound proof conference rooms and 5 or 6 tiny 6x8 rooms all glass walled the small rooms had frosted glass, large rooms clear glass.
insulated glass, wood supports, 1 3/4 solid core doors with exterior weatherstripped jambs and no sill, carpeted floors, cloth covered homosote over drywall on the walls
rrk is online now
