Sound Proofing - General Discussion - Contractor Talk
Sound Proofing
Old 01-30-2019, 07:50 PM   #1
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,708
Sound Proofing
My daughter owns a duplex and the middle wall was not insulated or anything so it transfer noise pretty bad. Will sound board and a second layer of sheetrock do anything or do just need to pull sheetrock and install sound batting?
Thanks
Randy Bush is offline
Old 01-30-2019, 07:56 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 50
Re: Sound Proofing
be best to create an air gap to break the sound transmission.
most common to use hat channel then your drywall.
it won't be perfect but it will be better
griz is offline
Old 01-30-2019, 08:00 PM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,272
Re: Sound Proofing
If you double drywall it use green glue and you have to address any punctures in the wall such as outlets and any plumbing
Windycity is offline
The Following User Says Thank You to Windycity For This Useful Post:
overanalyze (01-30-2019)
Old 01-30-2019, 08:32 PM   #4
hdavis's Avatar
Rewards Points: 350
Re: Sound Proofing
Quick and dirty is just have the wall blown with fiberglass. Drill and fill dense pack.
If you need more, then go with the hat channel and drywall.
hdavis is offline
Old 02-11-2019, 05:37 PM   #5
BLI's Avatar
Rewards Points: 12
Re: Sound Proofing
Did a lot of sound proofing in mansions in the Hamptons. We would use Roxul safe and sound inside the walls. Then 1/2" plywood, then a rubber product we called LV-1. I can't find this product though for a better name. It was 1/8th" thick and came on a roll 36" by about 75'. Then 5/8 sound board drywall. It was a purple board with a layer of fiberglass in the middle I believe. If you don't want to open the walls try the plywood and 5/8 drywall, you can get outlet extenders for the added thickness.
BLI is offline
The Following User Says Thank You to BLI For This Useful Post:
Randy Bush (02-11-2019)
Old 02-11-2019, 06:44 PM   #6
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 762
Re: Sound Proofing
Hey Randy there are a bunch of drywall types to cut down on noise my favorite is Quiet rock c/k out 530 or 545, 530 is 5/8 fire rated perfect for common walls.
Others, sound block, silent fx, I forget which one claimed their panel was the same as 8 layers of reg sheetrock.
Edit
These products are no cheap but remember this is not reg drywall some where in $70.00 for a 4x8 panel.
I read all the time about stuffing all kinds of things in the walls but most of these things are not for cutting down sound they are for stopping the loos of hat etc
I remember reading about a membrane that can be applied I think it was a Aussie invention ?.
Still "Shakin" the tree boss
sunkist is offline
windows 7 sound problem boman47k Technology 6 01-14-2013 02:03 AM
water proofing parkers5150 Masonry 6 10-25-2012 02:33 PM
Searching for partition system without hollow sound HassaanAbdeen Drywall 10 08-08-2012 04:27 AM
Looking for suggestions to prevent sound transfer through TJIs Mid-Mountain Construction 3 07-21-2011 02:14 PM
Inexpensive sound proofing methods Humble Abode Construction 30 10-27-2006 06:18 AM
