So...... - Page 2 - General Discussion - Contractor Talk
So......
Old 07-28-2017, 10:01 AM   #21
hdavis's Avatar
Rewards Points: 418
Re: So......
I have a whole collection of gutter and crawl space tools. I can see why they didn't mind losing them....
hdavis is offline
Old 07-28-2017, 03:25 PM   #22
Mordekyle's Avatar
Rewards Points: 6,504
Re: So......
Yes, a $5 trowel left at the back of a crawlspace hardly justifies one more trip through the slop and the rat turds to fetch it.
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
A&E Exteriors (07-28-2017)
Old 07-28-2017, 03:38 PM   #23
MOC's Avatar
Trade: General Contractor (Historic Preservation)
Re: So......
Oh I thought the trowel was to dig your own scat hole.
MOC is offline
Old 07-28-2017, 06:52 PM   #24
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Siding, & Additions
Rewards Points: 15,602
Re: So......
Originally Posted by Randy Bush View Post
But it is level. Lots of guys don't understand that a level is just a starting guide when siding . Seen guys side with a laser, transit, in the real world that does not always pan out. Lots of times it is knowing where and how to fudge things to make it look right to the eye.
I like having it to check how it's going. Lots of measuring and line snapping too.
Originally Posted by illbuildit.dd View Post
I use a rotary to match the bottom all the way around then put it away
I'm doing that now that I have a laser.
A&E Exteriors is offline
The Following User Says Thank You to A&E Exteriors For This Useful Post:
illbuildit.dd (07-28-2017)
Old 07-28-2017, 07:08 PM   #25
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Re: So......
Originally Posted by Tinstaafl View Post
Yeah, I start at the bottom with a level, then the rest of the way is all based on measurements to the top. Sometimes it feels like I'm making a Japanese fan.
My experience with vinyl siding is limited to new construction that I framed. Would it make sense on an old house that might not be level to measure from the soffit down and run everything parallel instead of level?
Or is that just crazy talk?
I always say that it has to look right, not necessarily be right.
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
A&E Exteriors (07-28-2017), SmallTownGuy (07-29-2017)
Old 07-28-2017, 07:14 PM   #26
Re: So......
You are correct sir
B.Johnson (07-28-2017)
Old 07-28-2017, 08:48 PM   #27
Capra aegagrus
Tinstaafl's Avatar
Re: So......
As you say, the emphasis is on making it look right. One job I did years ago consisted of closing in a large front porch that ran the width of the house, creating two new rooms with an entryway in the center between them.
Those rooms got windows, which of course were installed level and plumb. The catch was, the entire house was 3" out of level from one side to the other.
In that case, I framed the windows level with each other, started the siding level and stayed that way until I got above the windows. Then it was japanese fan time. Tough squeak, but it worked out.
Tinstaafl is offline
SmallTownGuy (07-28-2017)
Old 07-28-2017, 09:10 PM   #28
FrankSmith's Avatar
Rewards Points: 5,124
Re: So......
I lost one while siding a townhouse subdivision. I was sure it had to be on top of a chimney or in a gutter. My buddy who was helping me has a plane so we did what anyone would do.
FrankSmith is offline
Old 07-28-2017, 10:28 PM   #29
VinylHanger's Avatar
Rewards Points: 324
Re: So......
Go to Thailand and get hookers?
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
B.Johnson (07-29-2017)
Old 07-29-2017, 06:25 AM   #30
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,902
Re: So......
Thats alot better than worrying about some stupid level
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
KitchenAndBath (08-08-2017)
Old 07-29-2017, 07:22 AM   #31
fast fred's Avatar
Trade: carpentry
Rewards Points: 840
Re: So......
all the time, lost a drill in a wall, levels, hand tools, keys, you name it, once left a gallon of water squeezed in between some lookouts on a roof. No way to get to it unless we ripped the roof sheeting up, always wanted to go back and look for water stains in the soffit in the spring
fast fred is offline
Old 07-29-2017, 08:09 AM   #32
pizalm's Avatar
Rewards Points: 838
Re: So......
And none of that is related to smoking weed all day...
Sent from my iPad using Tapatalk
pizalm is offline
Old 08-01-2017, 01:47 PM   #33
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,512
Re: So......
Originally Posted by NYgutterguy View Post
My brother leaves at least 3 torpedos a year in gutters lol
Left another one today at the second job.. smh
NYgutterguy is offline
The Following User Says Thank You to NYgutterguy For This Useful Post:
A&E Exteriors (08-01-2017)
Old 08-01-2017, 02:37 PM   #34
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: So......
I've lost 3 Stabila torpedos. One was the same day I bought it...left it on a rooftop steel trellis. I need therapy.
Inner10 is offline
Old 08-01-2017, 02:56 PM   #35
water re-locater
Re: So......
And he's the smart straight laced one of the family
Old 08-01-2017, 03:04 PM   #36
Inner10's Avatar
Re: So......
I'm the family retard, one sister got paid for her master's, the other one has a PhD. I'm a two bit wire jockey with a bachelor's degree...no wonder I can't keep track of a fifty dollar level.
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
Old 08-01-2017, 03:21 PM   #37
water re-locater
Re: So......
Won't embarrass myself on a public forum. Amazed I'm not still pumping gas.
Old 08-02-2017, 12:03 AM   #38
Mordekyle's Avatar
Re: So......
I'll bet you still pump gas
Resta (08-02-2017)
Old 08-02-2017, 05:24 AM   #39
water re-locater
Re: So......
No reason to try to hurt my feelings in front of all the guys
A&E Exteriors (08-02-2017)
Old 08-02-2017, 09:20 AM   #40
Rewards Points: 324
Re: So......
I pump gas every chance I get. My wife hates it, but laughs when the dog does it.
