Smoke Rated Door Frames - General Discussion - Contractor Talk
Old 07-29-2019, 10:10 AM   #1
johnfin's Avatar
Trade: masonry
Rewards Points: 2
I need smoke rated hollow metal frames on an existing building. Can these be added to existing frames or do I need new HM frames?
johnfin is offline
Old 07-29-2019, 11:27 AM   #2
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,108
Re: Smoke Rated Door Frames
I'm familiar with "fire rated" but never heard the term "smoke rated" when discussing hollow metal doors and frames. The fire rating of the wall assembly determines what type of fire rated door is required, and there are several, the architect or engineer typically specifies the rating required on the door schedule or specs and a competent door supplier will provide you with the correct doors and hardware.
You could get yourself into trouble trying to reuse old HM door components (frames), as the door and frame are considered an assembly and and there will be rating labels somewhere on the door, frame, or both.
Fishindude is online now
The Following User Says Thank You to Fishindude For This Useful Post:
hdavis (07-29-2019)
Old 07-29-2019, 11:51 AM   #3
avenge's Avatar
Rewards Points: 120
Not sure how you would retrofit smoke frames to an existing door. From what I know smoke rated doors and frames have a gasket and are self closing.
avenge is offline
Old 07-29-2019, 12:25 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 616
Smoke rated doors are spec'd to protect an egress corridor that is usually within a rated fire corridor.
However, they are rarely used and a fire rated door is installed in its place.
In my experience you will not be able to retrofit an existing frame to the required rating.
Doors and frames come rated from the manufacturer with an attached metal label.
griz is online now
