Silicone Caulk Removal - General Discussion - Contractor Talk
Old 09-02-2014, 02:56 PM   #1
rservices's Avatar
Rewards Points: 376
Does anyone have any suggestions on how to get silicone caulk off FRP (Fiberglass Reinforced Panels)
I had one of my guys go caulk some sinks in a restaurant and he almost painted the walls with it. 100% Silicone
It's like 2" above the sink and finger marks everywhere
I'm not against chemicals, I don't know if heat will warp the FRP (Mite loosen the adhesive holding it up
Thanks
rservices is offline
Old 09-02-2014, 02:58 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Re: Silicone Caulk Removal
Oh sh!t....they make a softener but I've never tried it.
Inner10 is offline
Old 09-02-2014, 04:24 PM   #3
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,180
I'd try to use some kind of plastic scraper or plastic razor blades (which I've never used). Something that's stiff and sharp enough to get under it without scratching.
It seems like you should be able to scrape it with the right angle and pressure but silicone can bond pretty tight to some materials.
Good luck!
dielectricunion is offline
Old 09-02-2014, 04:35 PM   #4
aptpupil's Avatar
Rewards Points: 1,894
Try fingernails for the big stuff and mineral spirits for the little bits. I wouldn't try heat or a metal razor (don't know about plastic kind) on FRP.
aptpupil is offline
Old 09-02-2014, 05:13 PM   #5
dan-the-man's Avatar
Trade: Apprentice Plumber
Rewards Points: 195
I would use some sort of a blade and mineral spirits.
dan-the-man is offline
Old 09-02-2014, 06:03 PM   #6
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,940
Goof Off works pretty good , had some on a vinyl window the other day cleaned it right off. I used the spray can one.
Randy Bush is offline
Old 09-02-2014, 06:46 PM   #7
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 840
Motsenbocker's LiftOff (Home Depot carries it)....best stuff I've ever used. Caulk, silicone, foam sealant remover. Typically works within a few minutes, and never had a problem ruining other surfaces.
dsconstructs is offline
Old 09-02-2014, 07:20 PM   #8
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,482
rservices:
Rip some plastic laminate into 1" wide strips. When you break them, they'll create edges sharp enough to scrape the silicone, but soft enough to not scratch the FRP. Snap off another when the edge gets dull. Use this with the previously mentioned solvent.
Kowboy is offline
The Following 2 Users Say Thank You to Kowboy For This Useful Post:
Agility (09-03-2014), dielectricunion (09-02-2014)
Old 09-02-2014, 08:42 PM   #9
Matt0034's Avatar
Rewards Points: 344
I've found with 100% silicone if you take your finger and rub it with pressure it'll break the seal and come of pretty easily. Almost all the caulking I do is against Frp and it'll break away fairly easily. I've seen others use goof off with good results. I'd maybe try a spot out if site down low to see if it would discolor at all, but I doubt it does with Frp.
Matt0034 is offline
Old 09-03-2014, 12:10 AM   #10
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
Good advice here,
2" up the wall tho? Man, I start feeling bad if my beads 1/4".
mgb is offline
Old 09-03-2014, 12:16 AM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,862
Home cheapo sells plastic putty knives. I've used these with great success when I removed the vinyl lettering from my truck. It took the lettering off without scratching the paint. I also used the bug and tear remover you get at pep boys. The combination may be the ticket.
Calidecks is offline
Old 09-03-2014, 01:02 AM   #12
VinylHanger's Avatar
Rewards Points: 11,492
Look for 3M silicone remover in the green aerosol can. Nothing works better and it leaves no residue. I use it for prepping showers for resiliconing. It dissolves cured silicone and quickly cleans up new silicone with no rinsing required.
It is a bit hard to find these days, but should be online. This reminds me, I need some.
I just poked around and couldn't find it. I am on my phone which makes it tough to really surf.
The other one I would use is Dow Corning OS2. It also leaves no residue. It doesn't dissolve the cured silicone as well, but it softens it enough it will pull off, then you can use it to clean the remainder off. The aerosol spray is the secret. All the other sprays get messy as you squirting them on.
Good luck. You need to train your guy on proper procedures which include taping the joints to make them look cleaner and contain the mess. Once you get silicone on your hands it is over. That stuff just gets messier and messier.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Calidecks (09-03-2014)
Old 09-03-2014, 07:05 AM   #13
Kowboy
Kowboy's Avatar
Trade: Countertops
I never tape to silicone. Lay a bead, mist it with Windex, spit on your finger, wipe it and it's perfect. Wipe off the over sprayed Windex and you're done.
Kowboy is offline
dielectricunion (09-03-2014), Xtrememtnbiker (09-03-2014)
Old 09-03-2014, 09:40 AM   #14
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 774
The windex keeps it from sticking to the adjacent surface?
Delta
Old 09-03-2014, 11:47 AM   #15
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Soapy water works to. Dip your finger in and use light pressure. Spit works but it's not an endless supply. for the soapy water i use about 25% soap and 75% water. Keep a rag handy to clean your finger every once and awhile. Figured this was all taught in caulking 101.
IDK about fiberglass but every other material i've removed silicone off of I just grabbed an edge and carefully pulled it up/out.
1985gt is offline
Old 09-03-2014, 03:45 PM   #16
Kowboy
Kowboy's Avatar
Trade: Countertops
Delta
Yep. Like a champ.
Kowboy is offline
Old 09-03-2014, 04:19 PM   #17
Matt0034's Avatar
Rewards Points: 344
Something in the windex keeps it off other stuff and leaves a very smooth bead. They also have caulk smoother in a spray bottle and caulk-ez. Probably only found online
Matt0034 is offline
Old 09-04-2014, 01:38 AM   #18
Trade: Highwayman
Rewards Points: 774
Uhm... Yeah, I know.
I was asking about Windex. Not soapy water.
Soapy water is what I use.
Hadn't heard of the Windex.
Delta
Old 09-04-2014, 07:18 AM   #19
Inner10's Avatar
Delta
You can even use plain water, but the soap give it a little more body to keep the slime in place. Silicone won't stick to anything that's wet.
The only caveat about spritzing with windex or soapy water is you have to pull a nice clean bead with your caulking gun. If you tape the joint any fool can make it look like a million bucks.
Inner10 is offline
Old 09-04-2014, 11:07 AM   #20
jb4211's Avatar
Rewards Points: 2,306
I would contact the manufacturer
Jon
jb4211 is offline
Caulk removal tool stonecutter Painting & Finish Work 7 08-28-2014 01:59 PM
silicone caulk with long shelf life MarkJames General Discussion 3 06-18-2014 07:46 AM
GE Silicone 3 hour caulk 3.12 JonM Tools & Equipment 1 06-10-2013 10:25 AM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
Silicone caulk around toilet base ProWallGuy Plumbing 37 08-26-2011 07:03 PM
