Sheetrock On The *exterior* Of A House? - Page 3 - General Discussion - Contractor Talk
Old 04-13-2014, 07:11 PM   #41
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Sheetrock On The *exterior* Of A House?
Originally Posted by Tom Struble View Post
one i've run into recently..notice the fancy wiring
Hey! Toms Trouble is alive!!
Is that a computer punch card...
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
Tom Struble (04-13-2014)
Old 04-13-2014, 08:05 PM   #42
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i'm sure i wouldn't know..seein how young i am..
some kind of manufactured home obviously, the vertical aluminum panels were actually glued on instead of blocking being installed
Sheetrock on the *exterior* of a house?-0517021635a.jpg   Sheetrock on the *exterior* of a house?-0514020931.jpg   Sheetrock on the *exterior* of a house?-0514020912a.jpg
Tom Struble is offline
TimelessQuality (04-13-2014)
Old 04-13-2014, 11:16 PM   #43
The Dude
smalpierre's Avatar
Trade: home improvement
Rewards Points: 1,946
Originally Posted by Needles View Post
Let in bracing should be used.
In the 90's installed a lot of that ext type x on condo/apts buildings while framing. Would use it in combination with osb.
Let in bracing isn't done much around here anymore. Lots of plywood corners and blackboard.
I worked on a house built in the 50's that had diagonal 1x12's for sheathing.
"That somebitch looks like MANAGEMENT MATERIAL TO ME...I would have handed him another rod after he bent the first one." ~MAULEMALL
"I think he was grandmaster at a gay pride parade in san fran this week (not that there's anything wrong with that). " ~ J F
smalpierre is offline
Old 04-13-2014, 11:21 PM   #44
The Dude
smalpierre's Avatar
If you tape wire nuts, the box is purely optional. If you put enough twists in the ground, the green wire nut is also optional, I've heard it called "western-union"
One of my friends puts tape on wire nuts for some reason - thinks it's doing something
For a long time, I thought it said Toms Trouble. The mind will make some things up as it goes
Old 04-13-2014, 11:25 PM   #45
The Dude
smalpierre's Avatar
It sure looks like one. Clipped corner, rectangular holes look like they might be in the right pattern from what I remember.
I'm outside the punch card era, but they did teach about them in college (majored in computer science). When I was a kid, my dad worked in a bank data center. They had them there too, but were being phased out.
Old 04-14-2014, 12:54 AM   #46
Needles's Avatar
Trade: Finish Carpenter
Rewards Points: 1,682
I have only installed let in's once. It was detailed in some set of prints the home owner bought from a plan mill.
Haven't run into 1x's diag. sheathing on older homes yet. Sub flooring yes. Usually 3/4 ship lap or 3/8's ply on ext.
Needles is offline
Old 04-22-2014, 04:59 PM   #47
BenderBoy's Avatar
Trade: Siding
Rewards Points: 38
The commercial job I've been at lately is being sheathed with a fiberglass mat gypsum sheathing called denseglass.
Kind of ironic seeing the roof being covered with this stuff because it has "not for roofs" printed all over it. I'm thinking it's probably labeled that way because people could have it break underneath them? On this job it's laid over metal decking so maybe it's acceptable?
BenderBoy is offline
Old 05-06-2014, 10:55 PM   #48
ellisr63's Avatar
Trade: Koi Ponds
Rewards Points: 16
That looks better than my last house did in 2003... It was stucco and one whole side of the house was only 2x4 framing with black paper and then the screen for stucco. It was a track house in Sunnyvale, Ca. I questioned it when it was being built, and I was told it was to code. I would have thought every wall would have to have OSB especially on a house that was almost $900,000..
ellisr63 is offline
Old 05-06-2014, 11:12 PM   #49
Love me some Concrete
brhokel606's Avatar
Rewards Points: 4,125
I think that gypsum would be better than the stupid foil faced foam board I am finding around here. They did the metal strapping for rack and then just used the foam, heck most of the houses seams were not even taped. These houses were built in the 90's, big boom area and build it fast/cheap was the moto.
Now the lack of flashing, proper sealing are starting to rear their ugly heads...well consitant flow of jobs I guess. Plus that foam board did not stand up to water/rot very well, nothing really does but house wrap would have at least created another plane for the water to run down and not infiltrate. Granted it would not have been flashed correctly anyway.
The times I have done siding work on these, I quote taking off the entire side and installing OSB and house wrap. Anytime you try and pull nails or anything, stupid foam breaks apart and comes out in pieces. Hate that stuff
I know I'm crazy...I love concrete
brhokel606 is offline
The Following User Says Thank You to brhokel606 For This Useful Post:
rescraft (07-04-2014)
Old 05-07-2014, 01:29 PM   #50
Ray C's Avatar
Rewards Points: 77
I have seen it a couple of times also. Both times it had black paper on it. Don't know the purpose for using it though, because as I recall the time frame the two houses were built, was a time when plywood was fairly inexpensive. And I don't think osb was available yet. Seems to me that a builder could have a real nightmare if the walls were up and they got into a rainy period.
Ray C is offline
Old 05-07-2014, 03:33 PM   #51
IHI's Avatar
Rewards Points: 1,040
We've had the privilege to working on a number of 70's era homes that were built with the white paper gypsum and I remember 22 or so yrs ago the first time I saw it I was like WTH is going on? Did some asking around, found it was a common way to save some money back in the day. As mentioned all we worked on had either metal/wood let in bracing on the corners or newer builds used plywood cdx on the corners.
Depending on how well the home/apartment units were maintained, some were in still like new condition, other's had severe deterioration from failed window/door flashing/caulks. Like most on here, we would cut and replace with 1/2" OSB when dealing wiith compromised area's.
Funny part is there's no real fire threat here in corn country, have never worked an area that had places stacked on each other, usually it's been acres between building or in town 10-40' gaps between units..so I have to think it was just a new technique for that time that everybody jumped on....while some builders didn't stray from the tried and true 1x8/10/12 sheeting covered in tar paper that was also a common practice before the gypsum era.
IHI is offline
Old 06-26-2014, 06:35 PM   #52
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,474
Originally Posted by Diamond D. View Post
... as I mentioned earlier, with the advent of the insulation board, a metal T strap fitted into a saw kerf cut on the 45* and nailed to the studs.
D.
What I HAVEN'T seen is these t straps fitted in to a saw kerf nailed to studs. What's that look like and how does it work?
link or pic? I think I've got the idea but I could be way off.
Ok This???
I know you've seen illustrations and stock photos on this thread, but here's a real life view, on another thread while discussing a totally different topic.
https://www.contractortalk.com/f11/po...5/#post2042519
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 06-29-2014, 12:01 PM   #53
Nouveau Eccentric
Diamond D.'s Avatar
Oddly enough, I'm remodeling my kitchen and I came across this Friday night while re-routing the cables that were hanging in the old soffett.
An example of the cut in 1X4 racking brace. This one isn't on the corner due to a window in the power room.
D.
" ROCK YOUR WORLD "
fb
Old 06-29-2014, 03:33 PM   #54
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,024
Yet another way...
Tinstaafl is online now
Tom Struble (06-29-2014)
Old 06-30-2014, 01:54 PM   #55
AmCraft Manufacturing
Roseann's Avatar
Trade: Industrial Curtains
Rewards Points: 146
Originally Posted by rustyjames View Post
Anyways, my best assumption would be that if this was the original sheathing of the house (so, built in 80's/90's), composition might be different than exterior sheathing that is made today. Roofing felt was used as a weather resistive barrier between the exterior sheathing and the building.
It also looks like it has some pretty deep water stain, especially along the corner where the roof gutter system is located - My best guess would be leaks that seeped through somehow and kept in moisture for a while.
Leader in Quality and Customer Service for Industrial Curtain Dividers
|AmCraft Industrial Curtain Dividers|
Roseann is offline
Old 07-02-2014, 02:10 PM   #56
Handymen are people too
realelectrician's Avatar
Trade: electrician
Rewards Points: 356
My house has it, late 50's. SE Pa.
Water restant, fire retardant gypsum board, that is.
Still used today, although not so much around these parts anymore.
The trend now is more toward insulation board.
D.
That's funny your location says cape may and bucks county. I live in Bucks and I'm from Cape May county specifically the Wildwoods
realelectrician is offline
Old 07-04-2014, 06:38 PM   #57
fjn's Avatar
Trade: mason
Rewards Points: 11,202
This is the product I see used on commercial work. Around here (N.w. Indiana) it has a yellow surface to it.Looks like a fiberglass mat. Although,I think it is labeled Denseshield,probably same product though.
fjn is offline
Old 07-04-2014, 07:17 PM   #58
Greg from K/W's Avatar
Rewards Points: 530
Our house was built with this stuff. Black faced drywall on the outside. They used Tin test on the inside of the walls for plaster backing inside the house. Stupidest thing I have ever seen. Pain in the ass to repair too. I would love to rip it all out and re do all the plaster work in our house just to get rid of the crap.
Dens shield and dense glass are the same thing just different companies that make it.
Greg from K/W is offline
Old 07-04-2014, 07:25 PM   #59
Mountain Man's Avatar
Trade: Drywall
Rewards Points: 113
They are actually both made by Georgia pacific. Dens-shield is tile backing and dens-glass is sheathing.
Mountain Man is offline
The Following User Says Thank You to Mountain Man For This Useful Post:
fjn (07-04-2014)
1900's House discovery greg24k General Discussion 9 12-16-2012 07:43 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Beach House Mitch M Painting & Finish Work 8 05-01-2011 07:16 PM
Adding a new chimney on an existing house Desdevinc Masonry 7 03-20-2011 11:14 AM
House in Disarray need help Chris22298 General Discussion 21 03-29-2009 03:06 PM
