Sheetrock On The *exterior* Of A House? - Page 2 - General Discussion - Contractor Talk
Old 04-09-2014, 01:41 AM   #21
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Sheetrock On The *exterior* Of A House?
Originally Posted by smalpierre
The other guy mentioned plywood corners. Durrr!!! I've seen that done before with blackboard between without being nailed off to where it's structural. I've seen racking braces, but usually 1x and in old houses - inset into the studs. What I HAVEN'T seen is these t straps fitted in to a saw kerf nailed to studs. What's that look like and how does it work?
My best way to describe it would be. It looks like the t's from drop ceiling. You snap a line at a 45 and cut the studs so it can slip in. Then pop an 8d nail in through the top of the t into the studs
jlsconstruction is offline
Old 04-09-2014, 01:54 AM   #22
The Dude
smalpierre's Avatar
Trade: home improvement
Rewards Points: 1,946
link or pic? I think I've got the idea but I could be way off.
Ok This???
"That somebitch looks like MANAGEMENT MATERIAL TO ME...I would have handed him another rod after he bent the first one." ~MAULEMALL
"I think he was grandmaster at a gay pride parade in san fran this week (not that there's anything wrong with that). " ~ J F
smalpierre is offline
Old 04-09-2014, 02:05 AM   #23
stacker of sticks
Rewards Points: 590
The Following User Says Thank You to jlsconstruction For This Useful Post:
smalpierre (04-13-2014)
Old 04-09-2014, 05:15 AM   #24
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
We used to use a ton of it along the shore. It has a good flame spread rating. The buildings we used it on were 4' off the property line. http://www.ebuild.com/product-detail...ior/223132.hwx
loneframer is offline
Old 04-09-2014, 05:34 AM   #25
mk5065's Avatar
Rewards Points: 89
Originally Posted by rosethornva
I'm an old house gal, and know precious little about 1980s/90s construction. I'm helping a friend with a problem she's having at her 30-year-old house in California. They've found excessive wood rot due to moisture, and she's telling me that her house has sheetrock used as an exterior sheathing (in place of plywood/osb) on her California tract house. Has anyone heard of this before? And any ideas when this practice was in vogue? It's on a not-so-nice two-story tract house in a San Francisco suburb. Thanks for any insight.
A lot of it in South Jersey. 2x8 sheets wrapped in black paper. We call it Gyplap. Don't know if that's the proper term. I've seen people install foam panels over top of it and then install the vinyl siding. I guess that's ok since there are houses that are foam right on the studs then sided over around here. If you remove all the exterior to install plywood then plan on installing new insulation too. I've done it before on a few houses and we always reinsulated. Good luck!
There's alot more to it then just putting on a toolbelt
mk5065 is offline
Old 04-09-2014, 06:41 AM   #26
mako1's Avatar
Rewards Points: 1,094
I used it here in IL once on a commercial building built 1' from the property line for fire rating.Code called for 2 layers of 5/8 on the exterior and 1 layer of 5/8 on the interior for a 2 hour fire rating.The wall was 64' X10'H and turned into a $5000 wall for materials.This was around 15-20 years ago.
mako1 is offline
Old 04-09-2014, 02:16 PM   #27
rosethornva's Avatar
Trade: Architectural historian
Rewards Points: 518
Thanks for the many replies and good responses.
I learned something about new construction today!!!
And frankly, I'm not too dazzled! LOL. I can't imagine putting this exterior gypsum on a house in lieu of sheathing.
Yikes!
Thanks again.
rosethornva is offline
Old 04-09-2014, 03:16 PM   #28
Kent Whitten's Avatar
Rewards Points: 2,040
Rose, while this is not perfectly normal sheathing, it is definitely a common sheathing out west on buildings like multi unit apartments. We called it gyp board. At the time, they said it was a requirement for the prevention of spreading fires.
It looks like from the pictures that it's not the gyp board that is the issue, but rather the leaking from the siding. Protected from the elements, this product is no worse than anything else that is put up. I've put up tons of it.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 04-09-2014, 10:21 PM   #29
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Used 5/8 green board for fire rated sheeting on these semi attached homes today. It's used for code here and sometimes over 1/2'' ply . If not sided soon it will begin to break down . Great when used in a flood or coastal area .
These homes replaced homes damaged or destroyed by Sandy on Staten Island . They are on raised foundations as per new flood elevation maps . Neighbor hood very slowly coming back .
Eaglei is offline
Old 04-10-2014, 11:10 AM   #30
aptpupil's Avatar
Rewards Points: 1,894
Yup, seen it before on a 1961 house in Santa Cruz. Did a stucco patch and was surprised to see it used as sheathing. Effing sucked trying to get the stucco off without destroying the gypsum sheathing behind it.
aptpupil is offline
Old 04-10-2014, 07:25 PM   #31
CarpenterSFO's Avatar
Rewards Points: 2,044
I've only seen gypsum board used as sheathing in the Bay Area a few times, under stucco, in some less fancy suburban homes from the 60s or 70s. I've never seen it in the City. DensGlass, which is a bit of a different animal, does get used, particularly when fire rating counts, in multi-family projects.
Never in shear walls. Now, many urban and suburban lots in densely packed suburbs are narrow, with few window and door penetrations in the long, side walls. Those long, side walls are sometimes strong enough without being engineered shear walls, or so has been explained to me, and that's where you'd see it, both gyp board and DensGlass these days. That's where I've seen it, now that I think of it.
I'll ask the next S.E. I talk to.
- Bob
CarpenterSFO is offline
Old 04-10-2014, 11:34 PM   #32
What do you know, I have a set of plans on my desk right now, for an addition, that specify gypsum board under stucco. Tomorrow I'll ask the engineer why.
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
rosethornva (04-10-2014)
Old 04-11-2014, 09:55 PM   #33
I asked, and the engineer's response was that the wall needs sheathing, primarily as backer for the stucco, and the wall doesn't require the strength of plywood, and gypsum is cheaper than ply. I can use ply if I want, at about $25/sheet, or gypsum sheathing, at $14/sheet. I'm not sure where score and snap and screw compare in cost to skilsaw and gun nailing.
It was probably mentioned by another post, but gypsum sheathing is very similar to but is not the same as standard gypsum wallboard, which is for interior use only.
One on-line reference mentioned that gypsum sheathing can be used in Type 1 and Type 2 construction, where plywood can't be used.
Rose, I'm glad you started the thread. It's been educational for me.
- Bob
rosethornva (04-12-2014)
Old 04-12-2014, 06:05 AM   #34
Rewards Points: 518
Thanks!
Heaven knows I've certainly learned a *lot* in the last couple days about contemporary construction techniques!
BTW, this house I posted about is in a San Francisco suburb, and I see you're in that area. I wonder if exterior gypsum board is more prevalent in that area?
Here in Norfolk, I've never ever never heard of exterior gypsum being used on a house.
Old 04-12-2014, 07:02 AM   #35
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Simpson Strong Tie:
http://www.strongtie.com/news/indust...entional.html#
http://johnotvos.wordpress.com/2010/...wall-erecting/
Good stuff.
SmallTownGuy is offline
Old 04-12-2014, 11:16 AM   #36
Originally Posted by rosethornva View Post
Thanks!
I don't really know if it's more prevalent; I work primarily in the City, where I've never seen it. I can say that right now, many of the commuting homes built within 75 miles of SF in the 80s, 90s, and early 00s seem to be falling apart, sinking, racking, cracking, peeling, leaking, collapsing, etc.
- Bob
Old 04-13-2014, 05:13 AM   #37
KemoSabe
loneframer's Avatar
We've used T braces in the past, as well as coiled strap by Simpson. The coiled straps were installed in an X configuration, wherever we could fit them on a wall. The T straps couldn't be overlapped due to design, so we alternated direction so that a minimum of one would be in tension while another was in compression. We always installed as many as would fit in the wall, which was typically 52 - 56 feet long, depending on the lot size.
The Following User Says Thank You to loneframer For This Useful Post:
Old 04-13-2014, 07:08 AM   #38
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
They have it on this older apartment complex in my area built in the 60's. They have had a lot of fires over there too.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 04-13-2014, 09:43 AM   #39
Needles's Avatar
Trade: Finish Carpenter
Rewards Points: 1,682
How does that work? Wouldn't think it'd give any support to keep the wall from going out of square - diagonal support, isn't that one of the jobs of wall sheathing? Even blackboard is structural if you nail it enough.
Let in bracing should be used.
In the 90's installed a lot of that ext type x on condo/apts buildings while framing. Would use it in combination with osb.
Needles is offline
Old 04-13-2014, 05:43 PM   #40
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
one i've run into recently..notice the fancy wiring
Sheetrock on the *exterior* of a house?-0514020912.jpg   Sheetrock on the *exterior* of a house?-0523021023.jpg   Sheetrock on the *exterior* of a house?-0514020931a.jpg
Tom Struble is offline
1900's House discovery greg24k General Discussion 9 12-16-2012 07:43 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Beach House Mitch M Painting & Finish Work 8 05-01-2011 07:16 PM
Adding a new chimney on an existing house Desdevinc Masonry 7 03-20-2011 11:14 AM
House in Disarray need help Chris22298 General Discussion 21 03-29-2009 03:06 PM
