Securing A Propane Tank To Wall.. - General Discussion - Contractor Talk
Old Yesterday, 11:42 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,912
I'm getting rid of my propane service and buying a 100 lb tank that I can take and get refilled. I've looked for straps made to keep this tank attached to the wall but have come up empty.
The diameter is 15" and the circumference is 47".
Anyone know of anything? Thanks.
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
Old Yesterday, 12:03 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,938
Re: Securing A Propane Tank To Wall..
Water heater straps?
Chain/cable with a coiple of turnbuckles to make R&R easier...
griz is online now
Robie (Yesterday)
Old Yesterday, 02:57 PM   #3
tjbnwi's Avatar
Rewards Points: 5,724
Piece of e-track or two single links on the wall, ratcheting strap, done.
https://www.uscargocontrol.com/shop/...cet=Horizontal
tjbnwi is online now
Robie (Yesterday)
Old Yesterday, 03:02 PM   #4
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,800
Tried to push the thanks button but it's covered by ads.
TheConstruct is online now
Old Yesterday, 04:23 PM   #5
Robie's Avatar
Thanks. I was thinking something commercial and wasn't thinking outside the box.
Straps and e-tracks it is.
― Will Durant
Robie is online now
Old Yesterday, 04:25 PM   #6
tjbnwi's Avatar
You’ll have to spray the ratchet with a good lube about 4 times a year.
Robie (Yesterday)
Old Yesterday, 05:39 PM   #7
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 210
Dittos with above but could also look for RV propane carriers based on gallon size
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Robie (Yesterday)
Old Yesterday, 07:54 PM   #8
Fire up the BBQ
griz's Avatar
any fire code issues being that close to the house?
griz is online now
Old Yesterday, 08:03 PM   #9
Robie's Avatar
The big one there now is probably 2" away. Don't think so.
I'm having it professionally hooked up as there are some different regulators I'm not sure about.
The only propane appliances in the house are the stove and oven. I was "prepping" almost 12 years ago (still am) and decided to go with a big tank...just in case. They topped it off 5 years ago with 7 lbs or gallons. It's almost empty now.
The reason I'm changing is...they get you coming and going. I didn't use enough for watchdog service so let's charge him $75 for the wasted non-delivery. I stopped that so they decided to charge me $50 per year for tank rental. Plus, I called about propane a few months ago and since I'm not buying that much....almost $5.00 per gallon.
I know they have to cover costs so that's not a complaint. I can get this 100 lb tank filled for $67.00. Move it onto my trailer...tie it down vertically and off to the station.
― Will Durant
Robie is online now
Old Yesterday, 08:09 PM   #10
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 16,677
How about a 100lb propane tank bracket.
https://www.amazon.com/4Bs-Bracket-T...MKZXKBC3D61N1F
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old Yesterday, 08:11 PM   #11
Robie's Avatar
I searched a couple of different nights using different search terms and never found that.
Thanks.
― Will Durant
Robie is online now
Old Yesterday, 08:13 PM   #12
LRG WoodCrafting
Leo G's Avatar
$2.80ish a gallon. Still kinda high. But then again I'm buying 300+ gallons at a time.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old Yesterday, 08:15 PM   #13
LRG WoodCrafting
Leo G's Avatar
"100lb propane tank straps" is what I searched in Amazon.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Robie (Yesterday)
Old Yesterday, 08:16 PM   #14
Robie's Avatar
I guess "gizmo" was the wrong search word.....
― Will Durant
Robie is online now
Old Yesterday, 08:21 PM   #15
LRG WoodCrafting
Leo G's Avatar
If you're looking for this fella, Gizmo is the perfect term
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old Yesterday, 08:44 PM   #16
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,622
I was paying 1.99/gallon at TSC to fill tanks pre corona.
Big Johnson is offline
Old Yesterday, 09:12 PM   #17
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,162
Feelin' yer oats? That 100 lb tank will weigh ~170 lbs when full. How are you planning on wrassling it?
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
griz (Yesterday), Rio (Today), rrk (Today)
Old Yesterday, 09:14 PM   #18
Robie's Avatar
Appliance cart and helper.
Trailer hinges down in the front.
Tailgate almost lays flat on the ground.
― Will Durant
Robie is online now
Tinstaafl (Yesterday)
Old Yesterday, 09:15 PM   #19
LRG WoodCrafting
Leo G's Avatar
Just like anyone does. You roll it at a 20º angle from vertical.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
hdavis (Today)
Old Yesterday, 09:21 PM   #20
Capra aegagrus
Tinstaafl's Avatar
Buddy of mine has a pair of those tanks that live behind some shrubberies. He uses his little John Deere backhoe to hoist them in & out.
griz (Yesterday)
