Scissors Truss Installation In An Existing Roof. - General Discussion - Contractor Talk
Old 06-25-2007, 08:24 AM   #1
JohnnyS's Avatar
I have a customer wanting to raise the ceiling in the garage. The garage backs up to a family room and the current truss system spans both the garage and family room.
Has anyone replaced the usual W truss with a scissors truss and done this without pulling the roof off? I should also mention the wall between the family room and garage is currently built to be a load bearing wall but the trusses are not putting much weight on that wall.
Current trusses are on 24 in centers. What do you think? Re-engineer the roof support or modify the current trusses?
JohnnyS is offline
Old 06-25-2007, 08:31 AM   #2
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
Re: Scissors Truss Installation In An Existing Roof.
I get an engineers design to modify the existing. We have a great engineer in this area to do that but finding an experienced engineer in other areas could be difficult... It's one of my favorite jobs but I can't find enough of it to keep busy.
K2 is offline
Old 06-25-2007, 01:42 PM   #3
Tmrrptr's Avatar
Rewards Points: 250
If it for a client, wouldn't it be wise to get an engineer to draw up, and stamp structural changes?
That is wisdom.
Once, I needed to make a buck.
I built an I beam up in an attic, and improved support at each end of it to redistribute the load when a client HAD to have part of a bearing wall removed, for architectural design reasons.
I used plenty gussets and metal, based on my own thumbnail experience. It worked out well and I got paid.
I have no doubt I may be sued when the big one hits!
You did not mention enough details such as span and roof loading.
It's important.
How bad do you need the bucks!
r
Tmrrptr is offline
Old 06-25-2007, 03:53 PM   #4
JohnnyS's Avatar
An engineering design is my next step. Just wanted to know if it was possible, or if the engineers tend to balk at truss mods.
JohnnyS is offline
Old 06-25-2007, 07:17 PM   #5
Big Bob's Avatar
Rewards Points: 75
CYA, engr: even if you were doin this for your moma
Big Bob is offline
HELP -Add a patio roof to existing roof Jeffrey442 Roofing 5 04-27-2007 07:13 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 09:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 09:47 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
