Roof-To-Wall Flashing Detail With Flat Siding - General Discussion - Contractor Talk
Old 09-06-2019, 10:20 AM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 154
T&G siding.
Just straight L-Metal will divert water behind the siding.
Only thing I can think of, is a piece of kick-out flashing, just like on a stucco wall.
Or maybe there's something else I'm missing?
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 09-06-2019, 02:16 PM   #2
TimNJ's Avatar
Rewards Points: 4,854
Re: Roof-To-Wall Flashing Detail With Flat Siding
Kickout is what I have on my house.
TimNJ is online now
The Following User Says Thank You to TimNJ For This Useful Post:
Seven-Delta-FortyOne (09-07-2019)
Old 09-07-2019, 03:03 AM   #3
VinylHanger's Avatar
Rewards Points: 10,842
There is no real good way to do it. It always leaves a gap where you cut it in. I try and belly band just below if I can get away with it, that way at least the belly band flashing will help add some protection.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 09-07-2019, 12:27 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,826
There's plenty of good ways to do kickouts...and you need one!
Roof-To-Wall Flashing Detail With Flat Siding-img_8525.jpg   Roof-To-Wall Flashing Detail With Flat Siding-img_8526.jpg
supersealconstruction.com
superseal is online now
The Following User Says Thank You to superseal For This Useful Post:
Old 09-07-2019, 02:23 PM   #5
Trade: Highwayman
Rewards Points: 154
That's what I ended up doing.
It's just a little 7x5 gabled door covering.
Main house has horizontal T&G cedar.
I folded and bent a little kickout from a piece of L-metal for each side. I don't like to cut it, and end up depending on caulk.
I got it pretty tight to the wall, with a little finesse.
Get Off My Lawn.
