Is This Right? - General Discussion - Contractor Talk
Is This Right?
Old 05-22-2012, 02:18 PM   #1
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
Is This Right?
I'm not real sure if this is right...
Shouldn't that rim joist [?] be 100% on top of the block foundation?
This a 2 story wood frame job...
Comments...
Celtic is offline
Old 05-22-2012, 02:42 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: Is This Right?
That looks like a plate to me, not a rimjoist.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
Celtic (05-22-2012)
Old 05-22-2012, 03:06 PM   #3
jb4211's Avatar
Rewards Points: 2,306
Re: Is This Right?
Correct. Looks like a double plate.
It also looks like the block bumps out a few inches further down so the plate would sit more on then off. Not sure what's going on here.
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
Celtic (05-22-2012)
Old 05-22-2012, 03:14 PM   #4
Tom M's Avatar
Rewards Points: 8,034
Re: Is This Right?
That dont look good, I think it will fail inspection.
By the looks of the roof I think the floor joists likely run the same direction. If that be the case they should have left full bearing of the sills and anchor bolts and cantilevered the floor beyond the block if it was a "squaring" problem.
Tom M is online now
Celtic (05-22-2012)
Old 05-22-2012, 04:02 PM   #5
Fentoozler
Celtic's Avatar
Re: Is This Right?
Thanks for the input guys...
Yes...the block work further back is a larger dimension than in the front...they also neglected to install the metal tabs [?] the brickies will need later.
The floor joists are perpendicular to the eve.
I'll wander up the street and shoot a few more shots.
Celtic is offline
Old 05-22-2012, 04:13 PM   #6
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Is This Right?
Well in the second picture it's more to the left...
RobertCDF is offline
Old 05-22-2012, 04:33 PM   #7
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
Re: Is This Right?
what's that got to do with pies???
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
GRB (05-22-2012)
Old 05-22-2012, 06:17 PM   #8
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
Re: Is This Right?
They probably left room for the bricks to be laid up under.
dave_dj1 is offline
Old 05-22-2012, 06:54 PM   #9
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Is This Right?
Without knowing all the details, it's hard to say what's beneath the sheathing. There was obviously a mistake somewhere, but mistakes aren't always catastrophic. In reality, there's probably enough sill plate bearing on the block as is.
It sure looks screwed up, but there are structural details that could have been used which would make that situation completely acceptable, such as a double rim cantilevered out off the protruding block further back with joists hung off of it.
Simply adding a sill plate behind the existing one to bear on the block wall would have done the trick too, assuming the joists actually run in that direction in the first place.
Too many unknowns to make assumptions IMO.
loneframer is offline
Old 05-22-2012, 07:00 PM   #10
GRB's Avatar
Trade: Carpentry Contractor
Re: Is This Right?
The hell with the floor system - the 2nd floor windows plopped on top of the porch roof are likely a bigger issue.
GRB is offline
Old 05-22-2012, 07:03 PM   #11
KemoSabe
loneframer's Avatar
Re: Is This Right?
Probably why they pulled the wall forward 2 feet. So the roof wouldn't interfere with the windows.
Old 05-22-2012, 07:06 PM   #12
GRB's Avatar
Re: Is This Right?
They should have pulled it forward 2 1/2 feet.
GRB is offline
Old 05-22-2012, 08:20 PM   #13
Tom M's Avatar
Re: Is This Right?
If that sill plate wasnt planned like that its not going to fly unless there is a lazy inspector. There is strict rules on anchor bolts for shear walls.
Tom M is online now
Old 05-22-2012, 09:07 PM   #14
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Is This Right?
Looks like maybe the brick veneer is supposed to make it up
-Steve
TimelessQuality is offline
Old 05-22-2012, 09:58 PM   #15
AustinDB's Avatar
Rewards Points: 1,426
Re: Is This Right?
is a brick ledge present on the foundation (juts out about 3-4")? I've laid up houses looking just like that, where we came in and laid brick to the bottom of the floor system. That was a long time ago, not sure if it's typical practice these days.
AustinDB is offline
Old 05-22-2012, 10:52 PM   #16
kiteman's Avatar
Rewards Points: 16
Re: Is This Right?
Pretty sure there's a brick ledge under there, then that'll be ok, but it looks like the front was pulled 2' out over the stoop. You can see a void to the left of the sill plate. Maybe the joist will span the stoop okay, can't tell. Need to be sure that gets insulated and sealed off from the dirt before they pour the stoop. Probably a change after the foundation was in.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 05-23-2012, 01:56 PM   #17
Five Star's Avatar
Rewards Points: 1,010
Re: Is This Right?
Looks like a job for Holmes on homes to check out ! Better wait till the house is more finished so he can tear it all apart !
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
The Following User Says Thank You to Five Star For This Useful Post:
GRB (05-23-2012)
Old 05-23-2012, 02:33 PM   #18
Tom M's Avatar
Re: Is This Right?
Hope he follows up, I wanna hear the outcome
Tom M is online now
Old 05-23-2012, 08:47 PM   #19
Dmitry's Avatar
Trade: Framing,Siding.
Rewards Points: 536
Re: Is This Right?
Every single picture looks wrong to me... but I am still young and tend to jump to conclusions)
Dmitry is offline
Old 05-24-2012, 09:02 AM   #20
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: Is This Right?
Good eye on the windows, that would not fly up here, snow would be half way up the windows and water intrusion for sure. The wall and roof would be rotted in a matter of a couple yrs. Personally i would run ice/water shield on the porch roof and right up the wall surrounding the windows. But even then if they ever get a good snow fall the heat loss through the glass will test the seals of the window.
woodchuck2 is offline
