Removal Of An Under Counter Sink - General Discussion - Contractor Talk
Old 03-19-2012, 06:32 PM   #1
rservices's Avatar
Rewards Points: 376
I know this should go pluming but I need a fast answer.
I need to remove an under counter sink, it's mounted to either marble or granite.
Question...
Whats the best way to get the adhesive to release the sink and then clean it off so I can mount the new sink?
Whats the best adhesive to use in iinstall the new sink?
Thanks
rservices is offline
Old 03-19-2012, 06:36 PM   #2
Box Builder
Morning Wood's Avatar
Rewards Points: 9,958
Re: Removal Of An Under Counter Sink
I just had to do this to a brand new sink. It was siliconed on to a piece of granite. Sink broke after install. I had to break the sink to get it off. It sucked.
Clear silicone and mechanical fasteners to attach it. Clean surface with acetone or denatured alcohol if it is solid surface.
Morning Wood is online now
Old 03-19-2012, 06:38 PM   #3
Kent Whitten's Avatar
Rewards Points: 2,040
Just about every under counter sink I have heard of uses silicone for the "adhesive". One granite company around here doesn't even use any clips. Purely held up by silicone. I wouldn't recommend that though, but silicone is some amazing stuff.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 03-19-2012, 06:41 PM   #4
Hmbldr's Avatar
Trade: Residential contractor
Rewards Points: 150
Is this a kitchen or bath sink? Stainless or china bowl? Depending o the application, there should be some screws, clips or other mechanical device that hold the sink in place. As for the adhesive, silicone or other? Best to knife in along teh edge as best you can. If you can't reach all the way thru the adhesive, then putty knife the rest for a deeper reach. Cleaning depends on the type adhesive. Silicone is the toughest to clean. I use a 'contractor's solvent' that works pretty effectively, but it is still a lot of work. Follow up with as good wash with soap and rinse so you get good bond on the next install.
I'm sure there are good plumbers here on CT,, but I would never trust this to a plumber. I've fixed too many from plumbers and granite guys poor installs.
Hmbldr is offline
Old 03-19-2012, 06:44 PM   #5
rservices's Avatar
Rewards Points: 376
It's a Kolher ceramic vanity sink.
Old 03-19-2012, 06:45 PM   #6
Box Builder
Hammer
Old 03-19-2012, 06:46 PM   #7
Hmbldr's Avatar
Rewards Points: 150
Yes, I have seen this and agree silicone is some tough stuff and holds very well. BUT, I have repaired kitchen stainless undermounts that have come loose from silicone and only partial clips installed. Getting all those clips in place must have been too tough for the original installer to bother with. Fill up a big sink bowl with water, throw in the pots and pans, and add the vibration of a garbage grinder, plus a few years of abuse..... when they called me it was just barely holding on!
I've seen this more than once.
Hmbldr is offline
Old 03-19-2012, 06:49 PM   #8
Hmbldr's Avatar
Rewards Points: 150
Originally Posted by Morning Wood View Post
Hammer
No, no, no. Risk to crack the granite or marble.
You were joking weren't you?
Hmbldr is offline
Old 03-19-2012, 07:29 PM   #9
Talking Head
EthanB's Avatar
Rewards Points: 338
Ugh, I hope someone on here has a better technique than mine but I'll share. I hate when I find the sinks installed using half a tube of silicone.
I usually put a couple layers of painters tape around the inside edge and top of the sink to protect it because you're gonna be there for a while I work around the rim of the sink with a utility knife until I have cut as far in as the knife will go. I then work in a sharpened metal flat bar I have that is really thin, almost a spatula, and start to work that around the perimeter. Once you've cleared a few inches start working a slightly thicker flat bar or wedge into the clear area and keep cutting your way around with the sharpened flat bar.
I use put a stick across the top of the opening and a block below the drain with a wire wrapped around them both to keep the sink from dropping when it's free.
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
Miss Brown (03-19-2012), rservices (03-19-2012)
Old 03-19-2012, 07:33 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 36
I wonder, if you could get it started, whether something like a guitar string might work for sawing your way through the adhesive?
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
DavidC (03-20-2012), EthanB (03-20-2012)
Old 03-19-2012, 07:38 PM   #11
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
No ones tried a MM with either a scraper blade or bi metal blade to get between the sink and top?
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 03-19-2012, 07:38 PM   #12
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Tape off the inside edge and use a knife to get it started, then try a fein took with a scraper blade, we've had to do it before when our granite guy installed the wrong color sink
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 03-19-2012, 07:46 PM   #13
Hmbldr's Avatar
Rewards Points: 150
I forgot to menton this also. It is a very good idea for the countertop, the bowl and the cabinet below.
Hmbldr is offline
Old 03-19-2012, 07:50 PM   #14
Box Builder
That's how i ended up doing it. I tried knife, fein tool, putty knife, sawing it with guitar string. China sink. No give whatsoever. It didn't harm the top; at least in my case. I got lucky
Old 03-19-2012, 09:07 PM   #15
Miss Brown's Avatar
Trade: Wood n' concrete finishes
Rewards Points: 150
I really like the guitar string idea. Acetone filled syringe? Next time...last time I just broke the sink. But somehow, not the counter, oddly.
Miss Brown is offline
Old 03-19-2012, 09:23 PM   #16
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
sharp putty knife and patience...this isn't a big deal
rex is offline
Old 03-19-2012, 09:31 PM   #17
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Rex just smiles at them and they run off the top towards him.. :
ohiohomedoctor is offline
Old 03-19-2012, 11:16 PM   #18
Box Builder
I actually didn't use a guitar string but a plumbers cable cutter for PVC pipe. It didn't work. The sink was preinstalled on the countertop when I got it so they got it on very tight.
Old 03-20-2012, 09:15 AM   #19
DavidC
DavidC's Avatar
Rewards Points: 2,006
I carry a guitar string on my tool box when there is a concrete counter top and silicone involved.
I have yet to use it, but I've got it with me. The only uninstall I've had to face was preplanned and we set it up to come off easy.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 03-20-2012, 07:58 PM   #20
Talking Head
EthanB's Avatar
Rewards Points: 338
Last time I did this I told the customer's that the whole process was going to be a half day of my labor but I'd throw in an hour of me using every swear word I know. They enjoyed the show.
Planer.....
EthanB is offline
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 06:06 PM
Urgent: help on under mount sink on tile counter top unhique Kitchens & Baths 17 10-23-2010 10:04 AM
Refinishing or Stain Removal for Marble counter tops Joemimosh Kitchens & Baths 2 02-11-2010 05:02 PM
Standard setback of sink hole Leo G Kitchens & Baths 13 01-18-2010 07:56 PM
Replacing a Porcelain Sink jerome8283 Plumbing 2 06-06-2009 09:10 PM
