Reducing Sound In Bathroom. - General Discussion - Contractor Talk
Old 01-21-2014, 12:11 AM   #1
NestoG510's Avatar
Trade: General
Rewards Points: 14
hEy Everyone,
Im sure this subject has been covered.
Client has asked me if theres anything that we can do to reduce sound from the bathroom that we are in the middle of remodeling.
Ive thought about filling walls with insulation.
Any recommendation ??
If someone else can do it, why can't you.
NestoG510 is offline
Old 01-21-2014, 12:15 AM   #2
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Reducing Sound In Bathroom.
Sound deadening drywall
jlsconstruction is offline
Old 01-21-2014, 12:20 AM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Sound system.
Inner10 is offline
Old 01-21-2014, 12:30 AM   #4
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Sound deadening drywall and a solid core door.
Or just install a noisy fan!
m1911 is offline
Old 01-21-2014, 12:44 AM   #5
Talking Head
EthanB's Avatar
Rewards Points: 392
Use staggered 2x4 studs on a 2x6 base plate if you can fit it. Pack the cavity with fiberglass batts. Insulation helps, sound deadening drywall helps, reducing the acoustical bridging is a BIG help. If you aren't messing with the other side of the bathroom walls then you could just tack a shim piece to the inside and add new studs on the inside only.
Planer.....
EthanB is offline
Old 01-21-2014, 12:51 AM   #6
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Anything is better than nothing, it amazes me that builders don't even think to at least offer insulation at bathroom walls (IMHO it should be standard in any "nice home"). Who wants to hear/be heard in the bathroom anyways?
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
m1911 (01-21-2014)
Old 01-21-2014, 12:59 AM   #7
m1911's Avatar
That's key. If you hang sound deadening drywall from metal studs staggered between the existing wood studs it helps, since there is less mechanical transfer than wood studs.
m1911 is offline
Old 01-21-2014, 02:36 AM   #8
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,990
Sill gasket, ripped to 1/1/2 stapled to the studs can help with the bridging issue.
B.D.R. is offline
Old 01-21-2014, 07:11 AM   #9
slowsol's Avatar
Rewards Points: 2,248
If you any modify the wall to get staggered studs, I'd fill with sound batts (no vapor barrier) and use resilient channel on the walls. Then hang board.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
fourcornerhome (01-21-2014)
Old 01-21-2014, 07:38 AM   #10
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,520
Resilent channel on the walls...fairly cheap and effective solution!
mstrat is offline
The Following User Says Thank You to mstrat For This Useful Post:
m1911 (01-21-2014)
Old 01-21-2014, 02:05 PM   #11
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 148
Less fiber....
fourcornerhome is offline
The Following 3 Users Say Thank You to fourcornerhome For This Useful Post:
amreiley (01-23-2014), PoleBarnsNY (01-21-2014), ScipioAfricanus (01-22-2014)
Old 01-21-2014, 05:45 PM   #12
huggytree's Avatar
Trade: plumber
Rewards Points: 1,418
I remodeled my own bathroom last winter and insulated all the walls....I changed my floor from vinyl to tile and put in a solid core door....its probably louder than my old bath..its like a eco chamber in there....I think all the sound goes through the door..doesn't matter how much you insulate
huggytree is offline
Old 01-21-2014, 05:53 PM   #13
mstrat's Avatar
I'd agree with just insulation doing little to nothing...the resilient channel is what separates the two layers of drywall from being a vibration microphone for each other (think of the kid's styrofoam cup & string phone...yarn transmits sound great...). The resilient channel separates the two surfaces, creating a sound barrier. Does it soundproof the room? absolutely not...but it sure does help!
mstrat is offline
Old 01-21-2014, 10:44 PM   #14
whatsacubbard?'s Avatar
Trade: cabinetry design, installation.
Rewards Points: 75
Rockwool or the insulation from Menards made out of blue jeans are the only insulations I know of that help with sound. There's not any "one" thing that completely works. It's usually a combination of steps that work best. Adding resilient channel will help. Double the drywall. Use "green glue" from Menards between the two layers of drywall. All these things will do the trick.
whatsacubbard? is offline
Old 01-21-2014, 10:52 PM   #15
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Oh god, I've gotta follow a scrap blue jeans menards insulation post?
So....my experience with bathroom soundproofing is to make sure the hvac vents are closed or else everyone else in the building will hear what you two are doing in the bathroom......
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
The Following User Says Thank You to CO762 For This Useful Post:
Dustincoc (01-26-2014)
Old 01-21-2014, 11:19 PM   #16
JackP23's Avatar
Rewards Points: 614
Almost forgot about these!!!!
http://www.weirdasianews.com/2008/12...fart-silencer/
JackP23 is offline
Old 01-22-2014, 11:09 AM   #17
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
Bathrooms are usually an echo chamber because of all the hard dense surfaces. Maybe some rugs or something similar will help deaden the echoes.
How about an elevator radio?
MJW is offline
Old 01-22-2014, 06:50 PM   #18
EarthQuakens's Avatar
Trade: Project Manager
Rewards Points: 206
Use these panels and you could yell in there if you felt the need to hahaha
EarthQuakens is offline
Old 01-22-2014, 08:31 PM   #19
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
#2 post is the answer, Also cast iron pipes. Fiber glass batts have no real sound deadening efffect
sunkist is offline
Old 01-22-2014, 08:55 PM   #20
Big Shoe's Avatar
Rewards Points: 2,070
What?
You're kidding, I hope. I've been in a lot of homes with batts in walls................big difference. One of many ways to deaden sound. probably the most common and least costly.
Where's Ted White when you need him?
Expect the Unexpected
Big Shoe is offline
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 19 09-08-2016 11:40 AM
Unleveled bathroom floor in small bathroom. andeeznuts Tiling 33 03-30-2013 05:43 PM
Searching for partition system without hollow sound HassaanAbdeen Drywall 10 08-08-2012 04:27 AM
Sound rated walls Architect Drywall 13 06-30-2009 08:53 AM
