PVC Beadboard Wainscoting - General Discussion - Contractor Talk
Old 03-13-2015, 08:21 PM   #1
JerseyJ's Avatar
Trade: General contracting
Rewards Points: 148
Thumbs down
I am considering using 1/2"Versatech PVC t&g beadboard wainscoting in two bathrooms in a house I'm remodeling. I'm not sure how much it will expand and contract.i would like to set the panels on 3/4" wood base. The top trim is also 3/4" which will sit on top of panels. I'm afraid it will move and create gaps where trim meets panels. I guess my question is do I need to use or make a dato in my trim to over Lapp panels . I don't like seeing holes where bead transitions behind trim that is Datoed.anither concern is trim boards slightly out of level causing to much effort to make trim work without datoing the back.
JerseyJ is offline
Old 03-13-2015, 08:46 PM   #2
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: PVC Beadboard Wainscoting
I'm still trying to figure out what a datoe is?
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 03-13-2015, 09:21 PM   #3
JerseyJ's Avatar
Rewards Points: 148
Ok.I deserved that.I Meant dado.
JerseyJ is offline
Old 03-13-2015, 09:25 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,230
I've always rabbeted the top trim to fit over the bead board and installed baseboard on the face of the bead board.
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Old 03-13-2015, 09:31 PM   #5
m1911's Avatar
I'm not sure what you're getting at.
Assuming you are using the 1/2" thick PVC, you would rabbet the top and bottom rail to receive the boards. If you treat the material like any other, and let it acclimate in the house for a couple days, I would think the expansion and contraction would be limited to around 1/16-1/8" in those lengths.
m1911 is offline
Old 03-13-2015, 09:33 PM   #6
m1911's Avatar
If you like the look, or use different thickness base.
m1911 is offline
Old 03-13-2015, 09:55 PM   #7
JerseyJ's Avatar
Rewards Points: 148
My casing is 2 1/2" col. With 11/16" thickness. I'm trying to not build out past casing to much. I like the look of panels sitting on top of 3/4" but am not sure if it will stay tight or contract making a gap during different temps. I like the idea of rabbiting top trip considering that I won't see holes from beads.the base can be perfectly level with a PVC shoe covering space needed on floor.
JerseyJ is offline
Old 03-13-2015, 10:04 PM   #8
m1911's Avatar
Backband.
m1911 is offline
Old 03-14-2015, 07:30 AM   #9
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
pvc expands and contracts because of temperature variation. if those rooms are kept at roughly the same temperature shouled be a issue
woodworkbykirk is offline
Old 03-14-2015, 10:46 AM   #10
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,348
I do what Robie does, IF I didn't already get a cap rail from the get go.
OP, is this your house or your customer's? I've found most customers that want the pvc wainscote also want that rail that they saw right next to the paneling in the Lowe's. Works great. Ugly as sin.
Good luck!
Easy Gibson is online now
beadboard wainscotting for bathroom MarkJames Finish Carpentry 10 05-26-2013 06:21 PM
raised panel wainscoting Brandito Carpentry Picture Post 15 02-23-2011 09:11 PM
box wainscoting & chair rail timrev8 Finish Carpentry 32 10-28-2010 05:03 PM
Wainscoting for GC William James Finish Carpentry 23 04-12-2010 12:35 PM
sourcing wide beadboard cdiamond Finish Carpentry 7 03-14-2010 04:35 AM
