Pros And Cons Of Insulating Interior Walls - General Discussion - Contractor Talk
Thread Tools
Old 02-11-2010, 12:32 AM
New and Remodel Carpentry
cooks's Avatar
Trade: General Contractor/Remodelor
Rewards Points: 75
I am looking into the use of insulation in interior walls as a noise reducer and thermal value. Is there any major pros or cons of using this practice. Is it worth the extra $ vs savings in the future heat/cooling bills
cooks is offline
Old 02-11-2010, 01:07 AM
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Pros And Cons Of Insulating Interior Walls
if it was you would probably already be doing it
Tom Struble is offline
Old 02-11-2010, 01:12 AM
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Other than noise reduction or if you plan to zone each room for heating and cooling there is no reason to spend the money or effort.
naptown CR is offline
The Following User Says Thank You to naptown CR For This Useful Post:
custrel (02-11-2010)
Old 02-11-2010, 06:57 AM
General Contractor
greg24k's Avatar
Rewards Points: 8,480
Waste of time and money and as sound-proofing goes, it will muffle the sound some what, but its not the right way to do it.
greg24k is offline
Old 02-11-2010, 07:28 AM
genecarp's Avatar
Rewards Points: 2,000
There are better ways to soundproof, and you dont want thermal value, GMOD
genecarp is offline
Old 02-11-2010, 08:18 AM
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I was supprised to find that the internal walls in my mother in laws house are all insulated. Works out well for them because they have 5 empty rooms that get used maybe 2-3 times a year so they shut the doors and leave the heat down low on each room. You can notice the difference when walking into them compaired to the hallway and other rooms. Def helps with sound also. Not sure if it's worth the money or hassle though.
www.bcconstructionllc.com
BCConstruction is offline
Old 02-11-2010, 09:21 AM
Cjeff's Avatar
Trade: Renovations
Even with insulated walls, lots of sound can still come out the door, open or closed.
Cjeff is offline
Old 02-11-2010, 10:20 AM
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
Actually, in NYC projects, especially commercial, but even in high end residential; all partitions are insulated with Therma Fiber or non faced f.g. batts. When I worked in the burbs, in houses, we didn't do it on interior walls.
Therma Fiber certainly should be used at bathroom walls (minimally), and when used at interior walls it does help for sound transmission, however do not expect it to be soundproof( i prefer it b/c it's better than nothing). Technically, to create a proper 1 hr rated partition, the assembly should be insulated. You can do this where customers are willing to pay for it. More than likely in the burbs, HO's will not be willing to pay extra, unless they have doe to toss around. If you do find yourself doing it, try not to use paper faced or foil faced for interior partitions, it costs more and does not add anything to the assembly.
d-rock is offline
Old 02-11-2010, 12:04 PM
cooks's Avatar
Rewards Points: 75
Thanks for the answers and suggestions. I never thought about the whole joining idea of heating and cooling. That could get expensive real fast. Thanks again.
cooks is offline
Thread Tools
Rate This Thread
