Probably The Stupidest Question Ever Posted Here - General Discussion - Contractor Talk
Old 01-28-2017, 10:04 PM   #1
Jayhawk Steve's Avatar
Rewards Points: 290
I've been in construction off and on for 40 years, 95% of which was residential building and remodeling involving wood.
Two months ago I started working for a commercial sub that specializes in restroom partitions, hanging doors and installing door hardware.
No matter what I do I cannot seem to successfully drive ss screws into hollow wall anchors in restroom tiles without snapping about 5% of the screws. I don't know what the typical failure rate is, but my boss acted as if he'd never had a screw break on him.
And I'm really, really bad at using self drilling screws in metal doors and frames. For example, the other day I had to install about a half dozen continuous hinges to hang some large metal doors. My boss had me use a Vix bit to dimple the holes and then gave me self drilling screws to complete the installation.
I tried using a lot of pressure at low rpm to a little pressure at high rpm and every combination in between, and it took me forever to drive most of the screws. I also had many issues with the bit slipping out of the screw head and scratching the door or hinge.
(In my previous limited experience with self drilling screws, I always used a fairly large drill bit and drilled all the way through the metal, them let the screw do the rest. This seemed to work out fine)
My boss was also driving screws at the same time and was moving at least 5 times faster and never had a bit jump off the screw.
I did have much better success when I was driving screws from about waist to chest level where I could really get good pressure behind the impact driver and could eyeball the straightness of the apex real well.
Needless to say, all of this was extremely embarrassing and if I don't step my game up real soon, I'll probably be canned.
HELP!
Jayhawk Steve is offline
Old 01-28-2017, 10:20 PM   #2
Mordekyle's Avatar
Rewards Points: 6,010
Re: Probably The Stupidest Question Ever Posted Here
I have a GC friend who hangs commercial doors and all associated hardware- handsets, locksets , closers, stops, kick plates, etc. I help him occasionally.
I also experience frustration at how slow I am compared to how fast he is.
It sure makes you feel stupid when your bit slips out and dings the door frame. I know that one full well.
A couple things I noticed: he's very particular about his Phillips bits that he uses. It looks like they're almost serrated at the end. Use whatever your boss does.
He Tends not to change bits. He has a drill and impact both chucked up with what he needs. It's not a bad idea to have two or three impacts. On a cart, preferably.
He tends to drill before running the self tapping screws in. For kick plates anyway, that have over 10 screws.
Also he tends to work in stages:
Hang all the frames, hang all the doors, adjust all the doors, install all the locksets, install the kick plates, install the stops and closers,etc. I think the idea is you can get in a groove and do the same process several times.
Finally, like your boss, he's got the experience. If you could do what he does after a couple of weeks, he probably wouldn't be in business.
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Jayhawk Steve (01-28-2017)
Old 01-28-2017, 10:32 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
The stupidest question is "The one you never asked". (There wasn't a question mark in your entire post.)
Self drilling screws usually means no pre-drilling. Why not just punch the hole thru the material before switching to a screw?
Try switching to a drill for the self drilling screws, and see if that helps. Also change your driving bit if it is camming out. High speed, medium pressure has worked for me. Once it starts to thread in, slow it down a little and drive it like a regular screw.
Stainless screws are weaker and will break easily, especially if they are of low quality. Could you be over tightening them? Maybe switch again from an impact to a drill, or even finish them off by hand.
Would be good to let your boss know you are interested to learn how he does them.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
Old 01-28-2017, 10:34 PM   #4
Rewards Points: 290
The company has incredibly well organized carts (two identical carts per van) - each with two drills and two impacts and a board containing holes for all the drill bit sizes we use, apexs set up with all the different drive bits etc. so I am using the same everything that he uses.
No one in the company through drills their holes, they only dimple each spot with a self-centering Vix bit. I wish we could drill all the way through. When I've done that in the past, I seldom had any issues.
I know if I don't get fired first, I will eventually become proficient. But I'm hoping someone can explain what I'm doing wrong so I can come up to speed faster.
Old 01-28-2017, 10:37 PM   #5
Unger.const's Avatar
Rewards Points: 3,050
If you have m18 line up. The new hydraulic impact driver has a setting just for self tapping screws. Starts off high speed and once it breaks through cuts the power down quick to prevent stripping. Also so fricken quiet is silly. (No really you could talk on the phone and still drive screws and talk) $150 bare tool if you have the batteries already.
Good bits help. Also magnetic tends to help too.
Unger.const is offline
Old 01-28-2017, 10:44 PM   #6
Rewards Points: 290
Good catch. You're right, I never did ask the question.
What am I doing wrong?
I sure wish I could experiment with different methods to do the job, especially drilling 1/8" through holes before running the screw. Unfortunately, the company has been doing this for years and the owner of the company wants absolute consistency in regards to exactly how each task is preformed.
I have asked the various superintendents I've worked with for help and advice and they all seem completely disinterested in teaching but very interested in criticizing my speed / accuracy. (It's my understanding that they make a lot of bonus money if the jobs come in under the estimated man hours)
Old 01-28-2017, 10:50 PM   #7
Rewards Points: 290
That sounds like an incredible tool. Unfortunately all our drills and impacts are DeWalt so we don't have any batteries. (Heck, if we did, I'd buy that out of my own pocket - it sounds like it would help a lot)
We use magnetic apexs and I use the same bits everyone else uses.
Old 01-28-2017, 10:57 PM   #8
Peter_C's Avatar
Rewards Points: 412
None of us want to hear you lost your job.
Maybe you can just watch and mimic them? Not very nice to not offer help at all, especially since you asked.
Are they using the exact same impact drivers as you?
FWIW I have a nice Makita brushless impact that became my secondary when they came out with the newer brushless version. I used to break screws often and more often, while installing drywall, over-drive them, breaking thru the paper. With the new driver that offered better control I was able to slow down (It will shift automatically if so desired) and gently set the screws. hard to believe how much of a difference an impact driver can make. The driver could be part of the issue with the stainless screws breaking, which is why I suggested switching to a drill (And set it on low speed for control).
Bits and their quality are very important. Swap to a new bit quicker. Try a few Wiha bits and see if that doesn't help keep the screw in place. As mentioned above the bits with ridges on them help hold the screw. The cheapo bits from Home Depot, etc aren't going to help you make a good impression.
Peter_C is offline
Jayhawk Steve (01-29-2017)
Old 01-28-2017, 11:04 PM   #9
Designer/Contractor
Rio's Avatar
Rewards Points: 1,108
Maybe get some stock and equipment and practice at home?
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
sparehair (01-29-2017)
Old 01-28-2017, 11:08 PM   #10
Also learning to let off the throttle helps me alot. I see alot of guys go full throttle then off all the way. Then full throttle, off, full throttle, off. Most of the time it snaps the screw on the 2nd and 3rd full throttle triggered.
The Following 2 Users Say Thank You to Unger.const For This Useful Post:
Jayhawk Steve (01-29-2017), MarkJames (01-29-2017)
Old 01-28-2017, 11:34 PM   #11
dutchroots2's Avatar
Trade: Residential Builder / Carpenter
Rewards Points: 388
Maybe it's a case of "give the new guy the crappy drill".
dutchroots2 is offline
The Following User Says Thank You to dutchroots2 For This Useful Post:
Peter_C (01-29-2017)
Old 01-29-2017, 12:20 AM   #12
Mordekyle's Avatar
Maybe it's a case of the new guy is doing awesome and knows what a board stretcher is, so let's pretend he's incompetent.
CharlieDelta (02-01-2017)
Old 01-29-2017, 09:58 AM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Practice.
Inner10 is offline
Old 01-29-2017, 10:22 AM   #14
TristenConst's Avatar
Rewards Points: 8
Have you tried using his drill/impact to see if its the drill, the bit or what. You have been at it two months with him and he hasn't fired you yet, hang in there. By now I'm sure you have voiced your concern with him, is he a decent boss or a putz? He shouldn't have a problem giving you 5 minutes of his time to work out the kinks.
TristenConst is offline
Old 01-29-2017, 10:31 AM   #15
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,236
I have trouble with self tappers too. Sometimes simply changing how you grip the drill can help. I'll often hold the impact like a pistol grip instead of a T-handle. This way when you're putting forward force it's inline with the screw.
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
Railman (01-29-2017)
Old 01-29-2017, 10:49 AM   #16
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 60
Ask to see how deep the boss-man is dimpling with the vix... he might be cheating by almost breaking through, while you might be just kissing the surface.
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Old 01-29-2017, 10:52 AM   #17
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,482
After you start the dimple with a vix, maybe try giving it a tap or two with pointed set to deepen the dimple and get it really close to puncturing. Should help the tip stay in the profile.
Sent from my SM-N910T using Tapatalk
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
Stevarino (01-29-2017)
Old 01-29-2017, 11:59 AM   #18
Railman's Avatar
Trade: Railing
Rewards Points: 1,161
Sounds like a t handle driver problem. I prefer a pistol grip so the force applied to the screw is in line with the fastener. That's why you're flopping the screws over. It's by far and away the biggest problem with virtually all cordless drills, & drivers. If you have problems with breaking very small drill bits, it's the same issue. The web of your index finger & thumb should lay in the groove on the back side of the driver. You pull the trigger with your middle finger. The index finger lays alongside the tool. It's why all drywall guns are pistol grip.
http://www.northerntool.com/shop/too...FUc2gQodcdQP6w
Or the one I just bought:
http://www.dewalt.com/en-us/products...40-ah/dcf622m2
Joe
Railman is offline
The Following 4 Users Say Thank You to Railman For This Useful Post:
JAH (01-31-2017), Jayhawk Steve (01-29-2017), Justin Huisenga (01-31-2017), Philament (01-29-2017)
Old 01-29-2017, 12:11 PM   #19
Rewards Points: 290
Originally Posted by Inner10 View Post
Practice.
I wish I could somehow practice. If I could have a chance to work alone on the other side of the building for a day or two and take my time without all the "hurry up, hurry up you gotta move much faster" I'm sure I'd come up to speed pretty quickly.
Old 01-29-2017, 12:13 PM   #20
Rewards Points: 290
Nope, on the contrary he barely makes a dimple. I made mine twice as deep and he was still 5 times faster. It's so frustrating.
When no one was looking I drilled all the way through a couple of times and the screw went in like butter.
The Following User Says Thank You to Jayhawk Steve For This Useful Post:
Defenestrate (01-29-2017)
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
