Power Tool Maintenance - General Discussion - Contractor Talk
Old 01-31-2015, 03:39 PM   #1
Chopsaw Chick's Avatar
Rewards Points: 589
So, I own the usual assortment of home remodeling tools in all shapes, sizes and colors. Yesterday, I was using my jig saw to cut backerboard and it started leaving some black residue behind. As I kept cutting and wondering what was going on, I started thinking about how I pretty much never do anything to maintain my tools. Aside from adding bar oil to my chainsaw when I add gas, I generally do nothing until my tools break. It's not a good system.
So, I was wondering if any of the experts around here have advice for those of us who are not naturally inclined to do a lot of power tool maintenance. If you were going to spend, oh say 30 minutes per month, where would you focus your efforts? The tools I use the most are probably my chopsaw, cordless drill, sawzall and multimax. Thanks in advance!
Chopsaw Chick is offline
Old 01-31-2015, 03:55 PM   #2
FrankSmith's Avatar
Rewards Points: 5,124
Re: Power Tool Maintenance
All I can say is put the tools back on the shelf in working condition and oil your nail guns. If they are clean enough, with good cords and sharp blades I would call it good.
FrankSmith is offline
The Following User Says Thank You to FrankSmith For This Useful Post:
Chopsaw Chick (02-01-2015)
Old 01-31-2015, 04:19 PM   #3
fjn's Avatar
Trade: mason
Rewards Points: 10,718
For any tools that cut wood or masonry,an air compressor is an invaluable aid. Blowing the saw dust and masonry dust out of tools will extend their service life in a big way.I blow out my masonry saws every day,especially the air filter.
fjn is offline
The Following 5 Users Say Thank You to fjn For This Useful Post:
66 Shelby (02-01-2015), Chopsaw Chick (02-01-2015), EricBrancard (02-02-2015), J L (02-03-2015), JAH (02-02-2015)
Old 01-31-2015, 10:24 PM   #4
Manager/Diplomat/Builder
darthdude's Avatar
Trade: Lead Carpenter
Rewards Points: 392
This times 100! I oil my nail guns everytime I use them and check air compressor oil maybe every month, but I use an air blower every chance I get to blast debris off all my tools, or to dry things out if its been a rainy day/week. (Including tool bags, what good is cleaning a tool if you put it back in a dusty bag?) I can honestly say my daily use tools do not often need repair and I generally want to replace them for reasons other then being broken.
darthdude is offline
The Following User Says Thank You to darthdude For This Useful Post:
Old 01-31-2015, 10:29 PM   #5
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
What's already said, and wax all tools with tables. I use bowling ally wax.
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
Old 01-31-2015, 10:32 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 2,378
Rain days, short days or I had the crew over for a Saturday BBQ.
Couple of hours on tool maintenance and all was good.
griz is offline
Old 02-01-2015, 03:00 PM   #7
Rewards Points: 589
I like that idea! My crew would totally work for food!
Old 02-01-2015, 03:10 PM   #8
Lettusbee's Avatar
Rewards Points: 848
Oil Nail guns before every use.
Blow off all saws etc with air compressor or cordless blower before they go back in the trailer.
Dump out tool pouches once a week or so and filter fasteners, and blow out or vac out the bags.
Drain air compressors- should be daily
The DW745 Table saw has plastic gears and other moving parts that work much better when I use the plastic lube from PB on it, after a thorough cleaning of course.
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
m1911 (02-03-2015)
Old 02-02-2015, 01:29 PM   #9
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Clean your air compressor intake filter.
JAH is offline
Old 02-02-2015, 04:19 PM   #10
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
The black stuff was probably something left over from the last job. Unless paint is coming off. But on surfaces you want to remain clean you can tape the bottom of the foot. I don't do much besides blowing off dust crap if it gets built up. A little oil here or there. I used the rubber dealy (looks like a big rubber eraser) to clean sanding belts off from buildup.
RangoWA is offline
Old 02-02-2015, 04:29 PM   #11
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,116
I do very little.
Inner10 is offline
Tom Struble (02-02-2015)
Old 02-02-2015, 07:49 PM   #12
pizalm's Avatar
Rewards Points: 810
I blow out my chop saw and table saw once in a while, oil guns when I remember. I should wax the table saw and clean my planer sometime though.
Sent from my iPad using Tapatalk
pizalm is offline
Old 02-03-2015, 01:22 AM   #13
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
I've pulled my jigsaw head apart a couple times to re-grease it.
It doesn't make a lot of sense on most tools. By the time the bearings go the tool as a whole has seen its service life anyway.
I've had my miter saw apart a few times to clean it, grease up a few bearings. I'll oil most moving parts every few months.
I absolutely cannot stand a miter saw with gummed up slides/bevel/miter adjustments e.t.c.
mgb is offline
Old 02-03-2015, 01:43 AM   #14
VinylHanger's Avatar
Rewards Points: 10,346
I hate to admit it, but I pretty much do nothing until it dies. Though, most tools these days last a long time. I am pretty hard on tools and don't have too much trouble.
I have been using Lucas Gun Oil on stuff that needs a quick lube. That stuff is magic.
VinylHanger is online now
Old 02-03-2015, 01:55 AM   #15
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I oil my nail guns each time I use them, a few drops is all it takes. I blow out the saw dust on miter saw after job is complete. Drain the compressor each day.
My compressor stopped filling all the way to max pressure a couple days ago. I took the head off today and found the exhaust reed valve was bad. Fixed it, and back in business. I use my tools, but don't abuse them usually. Sharp bits and blades help. I have backups of most tools.
m1911 is offline
Old 02-03-2015, 04:41 AM   #16
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Sharp blades/bits and oil. Blow them off and store in case. Just my 2 cents.
kingcarpenter is offline
Old 02-03-2015, 05:00 AM   #17
Agility's Avatar
Trade: Carpentry; Kitchen & Bath Reno
Rewards Points: 1,016
I just try to get the tools to and from the site as gently as possible. And sometimes oil the nail guns before every use.
Agility is offline
Old 02-03-2015, 10:22 AM   #18
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
use a blow tool to blow dust out of saws and grinders regularly so the dust doesnt begin to gum up in the grease or any water if being used outside in the rain.
i wipe down all the framing guns every couple months, and finish guns after a house. inpsect the driver pins for deformation and file them down if needed otherwise replace the driver.
replace bad plug ends and air hose fittings as they start to show signs of wear.
lubricate the blade chuck on recip and jig saws.. remove and clean gummed up mitre saw and table saw blades to prolong their life before either being replaced or sent in for sharpening
woodworkbykirk is offline
Old 02-03-2015, 01:08 PM   #19
Inner10's Avatar
Although a lot of dust comes out I think blowing with an air gun just drives the dust further into the mechanism. Probably best to employ what we use for electronics, vac and paint brush.
Inner10 is offline
The Tool Belt Thread... 2ndGen Tools & Equipment 1730 03-02-2019 07:54 PM
Disabled Cruise ship stuck in Gulf... Stinks! CarrPainting Off Topic (Non Trade) 53 02-16-2013 12:36 AM
Nationwide hotel maintenance idea. wallmaxx Remodeling 1 11-11-2012 10:50 PM
Tool GPS HomeProConsult Technology 4 09-23-2012 08:54 AM
