Pouring A Small Slab For Storage Shed - General Discussion - Contractor Talk
Old 09-02-2018, 06:50 AM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 10,380
Iím replacing an old shed on my property. Probably going to pour a slab for it as Iím on ledge everywhere. Iím thinking about coloring the concrete for fun. Either that or doing some kind of epoxy coating on it after itís dried in. Iíve never been involved in coloring slabs before. Is it safe to assume that there arenít many color options available? Ideally, Iíd go white, but Iíd imagine that is tough to achieve.
Morning Wood is online now
Old 09-02-2018, 07:07 AM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,904
Re: Pouring A Small Slab For Storage Shed
I used a couple of bottles of the stuff I think Quikcrete sells for concrete many years ago.
It has faded over time but is still brown.
An appeaser is one who feeds a crocodile, hoping it will eat him last.
Winston Churchill
Robie is online now
Old 09-02-2018, 08:05 AM   #3
Designer/Contractor
Rio's Avatar
Rewards Points: 1,272
You can use white portland cement which will help lighten the color.
Rio is offline
The Following User Says Thank You to Rio For This Useful Post:
hdavis (09-02-2018)
Old 09-02-2018, 08:35 AM   #4
hdavis's Avatar
Rewards Points: 2,000
You can go as far as you want to get a white slab. White portland cement and "pool mix", which is crushed marble gets you white all the way through. Marble isn't as strong as regular aggregate.
A better option may be to use something like white stucco to coat a regular cement slab.
hdavis is online now
Old 09-02-2018, 08:40 AM   #5
hdavis's Avatar
There are a variety of bulk tinting colorants available, but the widest variety of colors are sold as mortar and stucco colorant.
Old 09-02-2018, 09:03 AM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
look at these:
https://www.concretenetwork.com/conc...lor-chart.html
griz is online now
hdavis (09-02-2018)
Old 09-02-2018, 09:43 AM   #7
hdavis's Avatar
Bulk colorants
https://www.quikrete.com/productline...ortarcolor.asp
Old 09-02-2018, 09:54 AM   #8
hdavis's Avatar
Mote bulk
www.solomoncolors.com/ColorCard.aspx?ColorCardID=24
Old 09-02-2018, 09:55 AM   #9
Fire up the BBQ
griz's Avatar
you will achieve more creativity using concrete stains rather than trying to color the mud.
you won't get white but you can make all sorts of variegated colors happen.
use a router bit or saw blade to cut lines to create patterns or specific areas.
good luck.
griz is online now
hdavis (09-02-2018)
Old 09-02-2018, 10:30 AM   #10
hdavis's Avatar
Cheapest and easiest to get a white slab is probably just fog coat it.
It won't be the same as staining plain old concrete, but if you're looking for a white canvas to work on, you'll have it.
Old 09-02-2018, 01:40 PM   #11
Box Builder
Cool. Thank guys.
Old 09-02-2018, 04:46 PM   #12
rondon's Avatar
Trade: carpenter
Rewards Points: 102
How many days after pouring a concrete slab do you have to wait before you acid stain it?
rondon is offline
Recessed Slab Question (1 or 2 pours) jb9 Concrete & Paving 5 05-31-2017 02:55 PM
Point loads on 4" reinforced concrete slab VanIsle Construction 7 01-26-2016 01:54 AM
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
Ply on Slab ....yeah I know InterCounty Flooring 1 02-05-2013 10:34 PM
Pouring a slab help Bradracer18 Concrete & Paving 14 09-17-2012 03:56 PM
