Post A Picture Of Your Current Job (Part III) - Page 28 - General Discussion - Contractor Talk
Old 07-10-2019, 10:25 AM   #541
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,134
Re: Post A Picture Of Your Current Job (Part III)
Originally Posted by Leo G View Post
Do you have to slam the Movemento drawers like that to reset them? Or can you just shut them like a regular Blumotion drawer?
You do have to lightly slam them currently. They have 3 TipOn models for different weight drawers. These are a little light right now until loaded and until I get the solid fronts on them. If you push them closed there is a slight amount of back pressure to get past the reset of the TipOn.
If they have pulls on the drawer and you just pull open the drawer like normal, the TipOn is not activated and then it self closes like a regular Tandem without the resistance of the TipOn.
overanalyze is offline
Old 07-10-2019, 10:29 AM   #542
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,883
Makes sense. Loading the drawer will give it some inertia. That would help it get by the resistance of the Tipon mechanism.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
overanalyze (07-10-2019)
Old 07-10-2019, 10:37 AM   #543
Always Learning
I did the ones rated for 44-88lbs. These drawers are 32” wide and will have solid 3/4" oak fronts. I used Salice glides on the last ones I did and they just barely kicked them open and didn't want that problem again.
Old 07-10-2019, 11:33 AM   #544
tjbnwi's Avatar
Rewards Points: 1,274
Looks great Andrew.
tjbnwi is online now
Old 07-11-2019, 03:13 PM   #545
LRG WoodCrafting
Leo G's Avatar
Had to fix a bastardized set of dresser drawers. My clients mom thought it would be a good idea to put ball and claw legs onto the dresser. I assume it had some type of bun foot on the front, probably about 6-8" long. So at one time they cut the bun foot off and put the ball and claw legs on.
I'm not sure who put them on backwards the mom or the woodworker commissioned to repair it after the moving company screwed it up. Either way I was told the legs were on backwards. The front legs needed to be on the back and vice versa.
So I didn't have a thin kerf saw so I went out and got a Japanese Razor Saw which has a .02" kerf and sawed the legs off.
Then I measured the stubs and one of them was a 1/4" shorter than the rest. The legs were close to about the same size as each other, one was about 1/8" longer, the wrong one.
So I took my belt sander and got three of the to the same length and the other shorter one I just left. I corrected it for the slight angled cut, but that was all.
That was yesterday. Wanted to let this filter through my brain overnight so I could come up with some sort of attack to put these back on.
So this morning I resquared the top of the legs back up as the saw made them uneven. And I think the other guy also didn't do such a great job of squaring them up. When I did it I made sure that I made one of the rear legs 1/16" longer to take up the stubbiness of that post the leg would be attached too.
Drilled a shallow 3/8" hole in the center of the leg, the previous dowel wasn't even close. Then I drilled a 1/4" hole about 1/2" deep and I put a dowel center finder into the hole and put the leg in place and gave it a whack. This put a corresponding dimple in the leg where I would drill the hole.
I free handed the holes in the dresser. Started with a 1/4" hole and went up through the bits 1/16" at a time til I got to the last row where I went up 1/64" at a time. Did this to try to keep the hole from wandering much, they always do. I was shooting for a 5/8" hole about 1 1/2" deep.
I made a jig for my drill press to do the legs. Did the same thing on the drill press but skipped a lot of bits because it was more stable and the jig made it square.
You can see otherS were here before me because of the two different set of dowel holes, mine make the third.
This was the first one I did on the drill press. I used two squares taped to the sides to make it square. Wasn't very stable and chewed up the entry hole a bit. That's when I decided to make that jig.
Made my own 5/8" dowel and put 2 saw kerfs in them to let glue escape as it was pushed into the hole.
Glued the top set of legs on first and then worked the holes for the rear legs as they dried.
Here's the glue up of the rear legs. Front and rear required different clamping methods because of access.
Took it out of the clamps and stood it up. Nice and stable, so I got the leg lengths right.
And now I have to do a bit of finishing on the parts that I had to remove some wood from.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 7 Users Say Thank You to Leo G For This Useful Post:
asevereid (07-12-2019), Calidecks (07-11-2019), Idothat (07-11-2019), overanalyze (07-11-2019), Robie (07-11-2019), tgeb (07-12-2019), TheConstruct (07-11-2019)
Old 07-11-2019, 04:26 PM   #546
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 678
We did the last hour and a half of this beast in the rain.
NYgutterguy is offline
The Following 8 Users Say Thank You to NYgutterguy For This Useful Post:
asevereid (07-12-2019), Calidecks (07-11-2019), Idothat (07-11-2019), KAP (07-11-2019), mrcat (07-11-2019), overanalyze (07-11-2019), TheConstruct (07-11-2019), Tom M (07-12-2019)
Old 07-11-2019, 04:37 PM   #547
LRG WoodCrafting
Leo G's Avatar
And now the touching up is complete. Came out nice. The color stain I had was damn close. Gotta love that Mohawk Precat Lacquer Spray. I started out with satin and I think it was a bit shiny. Last coat was done with a matt sheen. Really can't tell til it dries for a day or so when the true sheen comes out.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 8 Users Say Thank You to Leo G For This Useful Post:
asevereid (07-12-2019), Calidecks (07-11-2019), Idothat (07-11-2019), KAP (07-11-2019), overanalyze (07-11-2019), Robie (07-11-2019), tgeb (07-12-2019), TheConstruct (07-11-2019)
Old 07-11-2019, 08:03 PM   #548
LRG WoodCrafting
Leo G's Avatar
That's a lot of gutter. At least you could see your work in action with the rain.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-11-2019, 08:16 PM   #549
water re-locater
Rewards Points: 678
Had to take the old gutter and leaders down too. I still love to see them in action. Even after doing this for so long.
The Following User Says Thank You to NYgutterguy For This Useful Post:
Old 07-11-2019, 08:23 PM   #550
LRG WoodCrafting
Leo G's Avatar
You are easily amused.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-11-2019, 09:58 PM   #551
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,296
They need a footblock under that rail.
Mike.
_______________
Calidecks is online now
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
META (07-11-2019), TheConstruct (07-11-2019)
Old 07-12-2019, 05:39 AM   #552
water re-locater
Rewards Points: 678
Mike.
_______________
What’s that ? Little block of wood to prevent the sag?
Old 07-12-2019, 06:06 AM   #553
KAP's Avatar
Trade: Custom
Rewards Points: 36,718
Yup, but usually decorative (not just a block) and capped with same material in most cases...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
NYgutterguy (07-12-2019)
Old 07-12-2019, 12:20 PM   #554
GC/carpenter
Calidecks's Avatar
Yup, it's called a foot block because that's where everyone puts a foot when leaning on the rails.
Mike.
_______________
Old 07-12-2019, 05:28 PM   #555
Lady Dreamer's Avatar
Trade: Roofing and General Contracting
Rewards Points: 896
When we can't find the Hammer we use the tiny one!! Lol
Lady Dreamer is offline
Old 07-12-2019, 05:32 PM   #556
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 708
Originally Posted by Lady Dreamer View Post
When we can't find the Hammer we use the tiny one!! Lol [IMG]https://uploads.tapatalk-cdn.com/20190712/406fff0ced7fcd9aa931c866fa8e6344.jpg[/IM
That roof doesn’t look very flat.
Big Johnson is offline
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
B.Johnson (07-12-2019), Lady Dreamer (07-12-2019)
Old 07-15-2019, 07:43 PM   #557
Radical Basement Dweller
Robie's Avatar
Rewards Points: 6,140
Finished this up a few weeks ago. This is just the vanity I made and Leo made the drawer. Beautiful work Leo!
I'll get some pics of the rest of the powder room next time I'm back.
Wall tile border, wainscot, crown molding, new paint, etc.
She wanted something that looked old. Her cleaning lady mentioned making it out of pallet wood and she liked that idea...so I knew she really wanted something rustic.
I found some of the nastiest, dirtiest poplar with worm and bug holes at the lumber yard. Stuff I wouldn't use to make a chicken coup. Didn't do a thing to it except cut it and join in together. The cabinet is made from 3/4" birch but everything seen is this poplar
She loved it. I put a coat of boiled linseed oil to darken it up.
Made a mirror to match...all lap joints on the joinery...simple and old construction.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
The Following 9 Users Say Thank You to Robie For This Useful Post:
asevereid (07-16-2019), Calidecks (07-15-2019), DaVinciRemodel (07-16-2019), Easy Gibson (07-15-2019), Idothat (07-15-2019), overanalyze (07-15-2019), rblakes1 (07-19-2019), tgeb (07-15-2019), Xtrememtnbiker (07-15-2019)
Old 07-15-2019, 07:51 PM   #558
Tom M's Avatar
Rewards Points: 7,554
Looks nice and clean, good job Rob
Tom M is offline
Robie (07-15-2019)
Old 07-15-2019, 08:00 PM   #559
LRG WoodCrafting
Leo G's Avatar
Looks great Robie! The gnarly wood looks great.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Robie (07-15-2019)
Old 07-15-2019, 08:21 PM   #560
GC/carpenter
Calidecks's Avatar
Nice!
Mike.
_______________
Robie (07-15-2019)
Timber Frame vs Post & Beam Dustincoc Framing 18 06-26-2014 08:32 PM
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Post a video of your current job world llc General Discussion 36 10-19-2013 07:44 PM
