Post A Picture Of Your Current Job (Part III) - Page 12 - General Discussion - Contractor Talk
Old 04-28-2019, 05:24 AM   #221
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Post A Picture Of Your Current Job (Part III)
Originally Posted by tjbnwi View Post
The stacked W/D cabinet complete.
Simple hook to hang the ironing board.
Well, that's better.
SmallTownGuy is offline
Old 04-28-2019, 07:25 AM   #222
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,669
Wish I had that kind of room. I have a soffit that is 29" that I have to keep under too.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 04-28-2019, 08:27 AM   #223
tjbnwi's Avatar
Rewards Points: 1,160
Nothing a checkbook and demo saw won't fix....
tjbnwi is online now
DaVinciRemodel (04-28-2019)
Old 04-28-2019, 08:53 AM   #224
LRG WoodCrafting
Leo G's Avatar
I build cabinets
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 04-28-2019, 08:59 AM   #225
tjbnwi's Avatar
I build cabinets
Sub it too Sno....make the mark up-----doh
Old 04-28-2019, 09:00 AM   #226
tjbnwi's Avatar
and it's all in a landfill somewhere in northwest Indiana.
SmallTownGuy (04-28-2019)
Old 05-01-2019, 05:14 PM   #227
Donohue Const's Avatar
Rewards Points: 1,620
finally got this old barn fixed back up!!!
its post and beam from the 1880's
new roof
rebuilt the cupola
new trusses for both lean to's
rebuilt one end of the barn
soffit and fascia
stripped and shimmed the roof to straighten it out
added rafter and collar ties after the new lvls
took about 2-1/2 months
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following 18 Users Say Thank You to Donohue Const For This Useful Post:
asevereid (05-01-2019), B.Johnson (05-01-2019), Frank Castle (05-02-2019), Idothat (05-01-2019), KAP (05-01-2019), mrcat (05-01-2019), NYgutterguy (05-11-2019), overanalyze (05-01-2019), pizalm (05-02-2019), Railman (05-03-2019), rblakes1 (05-01-2019), Robie (05-01-2019), Seven-Delta-FortyOne (05-02-2019), SmallTownGuy (05-01-2019), tgeb (05-01-2019), TheConstruct (05-02-2019), TxElectrician (05-03-2019), Xtrememtnbiker (05-01-2019)
Old 05-01-2019, 05:18 PM   #228
John the Builder
new roof
rebuilt the cupola
soffit and fascia
well done sir !
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Donohue Const (05-01-2019)
Old 05-01-2019, 07:00 PM   #229
LRG WoodCrafting
Leo G's Avatar
Looks nice inside and out.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-02-2019, 08:57 PM   #230
LRG WoodCrafting
Leo G's Avatar
Finally got to install that washer dryer cabinet. A stacked Blomberg set. I've struggled with the design because of the lack of space and odd (stupid, thoughtless) setup that they left me to deal with. The dryer vent to the outside was low to the ground on the left. The dryer is on top and the vent port was right in front of the water box in the wall. The soffit came out 29", if I had 30" it would have made my life a lot easier. There was a pipe in the wall that was more outside the wall and right at the right gable of the cabinet. Those were my initial worries.
When we got there we found the floor from the left side of the cabinet to the right dropped 3/8" over 37". The floor rose 1/8" from the front of the cabinet to the rear. The left hand wall tipped out by 7/8". Arrrrrrggg!!!!!
We adjusted for all that which took quite some time. Mounted the doors and screwed the cabinet to the wall and ceiling and adjusted the doors. I had it all adjusted in the shop but for whatever reason I had to do a major adjustment on one of the pocket door slides. Got that all done and the cabinet was installed.
Then the next 2 hours we had to deal with getting the washer/dryer setup with the vent hose, water lines and electrical. Had to flip the outlet over for starters. I used this vent system which worked out really good for our situation.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
We put it all together and hoped for the best. BTW, I didn't sleep well at all last night because I was so unsure that we could pull it off. So we pushed the set into the cabinet and about half way in we assessed what was there. Had to get a ladder to see what was going on, adjusted a few things and pushed it in the rest of the way. The dryer vent 90º was rubbing against the rubber water hose but everything fit and the doors worked perfectly. We're going to get braided SS hoses and a 45º adapter to get the hose out of the way from the 90º duct. We'll be happy after that.
Then we put the cabinet insert together, cut a slot for the dryer vent hose and electrical cord, slipped it into place and we were done for the day. Still have to go back and install the sink cabinet. Took a lot longer than expected, but IT FIT!!. So I was really happy.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
asevereid (05-02-2019), overanalyze (05-02-2019)
Old 05-02-2019, 09:38 PM   #231
tkrrox1's Avatar
Trade: general contractor
Rewards Points: 84
I had this built for an old craftsmen a bit ago
The bottom is removable, with stainless pan, the bead board back is removable to access power,drain, and water. The sides slide out for detergents knobs aren’t on in pic yet
Sent from my iPhone using Tapatalk Pro
tkrrox1 is offline
The Following 7 Users Say Thank You to tkrrox1 For This Useful Post:
asevereid (05-04-2019), DaVinciRemodel (05-03-2019), KAP (05-03-2019), overanalyze (05-03-2019), rblakes1 (05-02-2019), Robie (05-02-2019), TheConstruct (05-02-2019)
Old 05-02-2019, 10:03 PM   #232
LRG WoodCrafting
Leo G's Avatar
Looks nice. I like the way you faked the double doors in front of the washer/dryer.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-02-2019, 10:04 PM   #233
tjbnwi's Avatar
Leo,
Looks great.
Dumb question time;
Could you have set the washer/dryer, connected it, then slid the the cabinet shell in place then the insert in place?
Old 05-02-2019, 10:18 PM   #234
LRG WoodCrafting
Leo G's Avatar
No. If you look at the bottom of the cabinet you'll see a pc of 1/2" oak plywood. I needed to put that there to stabilize the bottom dimension of the cabinet and to provide a dado for the insert to slide into so it would stay put.
So the cabinet is locked in place. The washer/dryer is slid into place after connecting the vent, water and electrical. Then the insert is slid into place. Without the insert in there there is about 4 1/8" of space for wiggle room. The cabinet itself is pretty flimsy because it has no back, no bottom rail on the face frame and the left side is only 1/2 the depth of the right side. It's very reliant on being screwed to the wall and floor to make it rigid.
If the floor and walls weren't so out of wack, this would have been so much easier. My world for plumb, level and true.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-03-2019, 07:59 AM   #235
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 382
Leo, what pocket door hardware did you use?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 05-03-2019, 08:52 AM   #236
tjbnwi's Avatar
Thanks Leo.
Everyone’s world dealing with lack of plumb, level, square. New 6 mill home, a wall is 1-1/4" out of square in 27", 3 mill home I just measured all the walls getting casework are out of plumb and out of square, some by more than 2" in 8’.
Old 05-03-2019, 07:22 PM   #237
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Thanks Leo.
That's why it's nice to do your own framing.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Old 05-03-2019, 07:30 PM   #238
tjbnwi's Avatar
Once upon a time....
Old 05-03-2019, 07:48 PM   #239
LRG WoodCrafting
Leo G's Avatar
Dealt with all the details and upgrades to the washer/dryer cabinet. Traded out the rubber hoses that came with the machine to braided SS hoses. Added a 45º adapter to the hot and cold water spigots to make room for the vent 90º duct that was touching one of the hoses because of the placement of the water and drain box. Drilled some 1/8" holes through the water box and out the back wall so we can put an access to the valves because there is no way to turn them on or off currently. No real planning from the GC on this.
Then onto the sink cabinet. Floor was still not at all plumb, 1/8" higher on the right and another 1/8" from the front to back. Scribed it to the floor, couple of screws through the washer/dryer cabinet into the left style of the sink cabinet and a few more in the wall. Last thing to do was the end of the run panel. Scribed to the floor, removed the baseboard and reinstalled it tight to the panel and then a total clean up.
Still need to put a small molding to the ceiling and make a panel for the small refrigerator.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-03-2019, 08:29 PM   #240
rblakes1's Avatar
Rewards Points: 3,536
Thanks Leo.
You need a crew of Brazilians, they at least get it within an 1/8".
-Rich
rblakes1 is offline
Timber Frame vs Post & Beam Dustincoc Framing 18 06-26-2014 08:32 PM
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Post a video of your current job world llc General Discussion 36 10-19-2013 07:44 PM
