Post A Picture Of Your Current Job -- Part II - Page 69 - General Discussion - Contractor Talk
Old 09-25-2012, 08:47 PM   #1361
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Post A Picture Of Your Current Job -- Part II
Originally Posted by overanalyze View Post
Had a large install at UCLA last week. That place was impressive! We had 8- 12' x 18' frames to assemble and mount. Then 9 graphic panels per frame and then the 36' long "easel" at the bottom. Also had some locker room fixtures. There is another install in a few weeks to put up more items. The company we install for does the design and engineering work. it's a nice little break from residential.
Attachment 78420
Attachment 78421
Looks like fun
UCLA's in NW Ohio??
-Steve
TimelessQuality is offline
Old 09-25-2012, 09:00 PM   #1362
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,472
Lol..no still in LA. We travel for this company. They specialize in impact graphics for universities. They have full time installers but call us when they have a difficult install or if they are slammed. It's a nice gig!
overanalyze is online now
TimelessQuality (09-26-2012)
Old 09-29-2012, 03:26 PM   #1363
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
i built this set of winders today in that garage i roofed.
reallly happy with how they went together.
i built my landing 3 1/2" larger to allow for the upper staircase bearing.
tapcons suck..or atleast this batch did.
so i just used my hilti and drilled a 1/4" hole with a bunch of nails
Cut the stringers, fit like a glove!!.
i assembled the whole unit and lifted it up...lets just say i won't do that again!. Heavy, i dropped it, and it sucked.
there is a tiny gap at the bottom on 1 stringer, i just cut the wrong side of the line.
He was impressed and i was too
A 3 stair winder would not have worked, because of the window. but im thrileld with this.!
Post A Picture Of Your Current Job -- Part II-picton-winder-sept-29-14-.jpg   Post A Picture Of Your Current Job -- Part II-picton-winder-sept-29-11-.jpg   Post A Picture Of Your Current Job -- Part II-picton-winder-sept-29-13-.jpg   Post A Picture Of Your Current Job -- Part II-picton-winder-sept-29-10-.jpg   Post A Picture Of Your Current Job -- Part II-picton-winder-sept-29-8-.jpg
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 09-29-2012, 03:32 PM   #1364
Kent Whitten's Avatar
Rewards Points: 2,040
Good and bad Nick. Where the stringers are setting, you need to hanger those. The stairs will eventually crack and fail right where your birdsmouth is. They look sweet though Nick, proud of ya. Doing well.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following User Says Thank You to Kent Whitten For This Useful Post:
CanningCustom (09-30-2012)
Old 09-29-2012, 03:33 PM   #1365
Dirtywhiteboy's Avatar
Rewards Points: 14,606
Looks good You guys up there don't use a middle stringer?
Dirtywhiteboy is offline
Old 09-29-2012, 03:34 PM   #1366
Forming and Framing
FramingPro's Avatar
i knew someone would point that out.
but those notches have full bearning. horizontally and vertically. its not just bearing on top.
Old 09-29-2012, 03:35 PM   #1367
Forming and Framing
FramingPro's Avatar
28" wide with a 2x10 tread... client and me didn't see a need
Old 09-29-2012, 03:37 PM   #1368
Not sure if you can see it in the marked up photo here Nick. Your stringer will have a great chance of cracking right where the circled part is, causing the whole set of stairs to come down. The fix is snub off the bottom points and ledger it, or hanger it.
The Following 3 Users Say Thank You to Kent Whitten For This Useful Post:
CanningCustom (09-30-2012), mgb (10-21-2012), TimelessQuality (09-29-2012)
Old 09-29-2012, 03:37 PM   #1369
Oh we never build them that narrow here , it doesn't meet code.
Old 09-29-2012, 03:38 PM   #1370
I don't see it. Sorry.
Old 09-29-2012, 03:39 PM   #1371
Not picking on you Nick, but there is some tweaking to do. You have to understand, once you build them, you are the one responsible for something happening if it's not up to code. A fire or someone falling....bad mojo mon.
Old 09-29-2012, 03:48 PM   #1372
Forming and Framing
FramingPro's Avatar
no i hear ya.
well we are gonna post it and built a wall sloping with the stairs.
i don't see what you mean tho, if it was just top bearing then ya, but its hard against both vertical and horizontal surface.
Old 09-29-2012, 03:51 PM   #1373
no i hear ya.
Here the top and bottom would have to have metal on it to pass code. If a wall will go under that outside stringer, that will stiffen it up and the world will be good
Old 09-29-2012, 03:57 PM   #1374
no i hear ya.
I understand your thinking Nick, but it's not good enough. There has to be a fail safe for the bearing. If that sucker cracks where I show it, she's coming down sooner or later. It's a simple fix. A 2x6 with the angle ripped and RS screwed underneath.
However, if there's a wall under like you said, the outside will be fine and the inside should be too. RS screws are your friend there, but not absolutely necessary.
Old 09-29-2012, 04:00 PM   #1375
Nice radio.
How does that top attach? That I hate to say looks suspect too. Man I feel like I'm picking on you today. They look good, but that doesn't count if it's not completely right. Sorry mon.
Old 09-29-2012, 04:00 PM   #1376
Forming and Framing
FramingPro's Avatar
can i get a 90 degree bracket and put them on the inside corners?
im not seeing this angled thing, as in cut it to fit under the point on the vertical area of bearing so its like an additional ledger?
Old 09-29-2012, 04:04 PM   #1377
Forming and Framing
FramingPro's Avatar
Nice radio.
half inch ply hanger board, with a 2x12 screwed to the bakc and screwed to the joists.
Old 09-29-2012, 04:12 PM   #1378
Ledger
Old 09-29-2012, 04:13 PM   #1379
Forming and Framing
FramingPro's Avatar
Ledger
tis what i thought, meh, easy enough to do. when i go back i will
Old 09-29-2012, 04:14 PM   #1380
If there's a wall going under, you will be fine without it.
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
