Post A Picture Of Your Current Job -- Part II - Page 62 - General Discussion - Contractor Talk
Old 09-05-2012, 09:29 PM   #1221
Dirtywhiteboy's Avatar
Rewards Points: 12,784
Re: Post A Picture Of Your Current Job -- Part II
Me likey can't wait to see the wood on top
Dirtywhiteboy is online now
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
CanningCustom (09-05-2012), overanalyze (09-05-2012)
Old 09-05-2012, 10:16 PM   #1222
Do Work!
martymc's Avatar
Trade: kitchen/bath remodeling
Rewards Points: 25
its looking good we just did one similar to this about 2 weeks ago with 2" walnut treads and LED lighting on the underside. i posted a pic of them on here.
martymc is offline
Old 09-05-2012, 10:30 PM   #1223
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,134
Thanks..just looked yours up. That's a cool look. We were going to do wire as well but switched to 5/8" rod instead. It looks like you just cleared the metal..all welds and grinds exposed..our client was the same way..did not want it painted.
overanalyze is offline
Old 09-05-2012, 10:52 PM   #1224
Do Work!
martymc's Avatar
Rewards Points: 25
they wanted an industrial look. Your going to use 5/8" cables? That's HUGE!! We just used a clear Lacquer on the steel as soon as it was cool enough to touch.
martymc is offline
Old 09-05-2012, 11:28 PM   #1225
CHRenewal's Avatar
Trade: Residential Design/Build Remodeler & Home Builder
Rewards Points: 75
Originally Posted by cranbrook2 View Post
This is my latest bird mansion . It will be 13 ft wide and have close to 200 rooms . It will weigh close to 1,000 lbs
WOW - That is awesome!!! My Purple Martins would love that
Very Nice work
CHRenewal is offline
Old 09-06-2012, 05:31 PM   #1226
Always Learning
No not cable..solid rod. We wire brushed everything with a grinder, cleaned it all with Laquer thinner, then shot it with two coats.
Here are the landings we worked on today. Had to make a hardwood sandwhich since the bottom is open. Laid the bottom layer upside down and glued and pinned it all together. Then glued and pinned the ply to that. Took the whole section off and installed the top layer. Then used our sweet new Festool to cut everything at once. The only thing we have to do yet is install the edge trim. The treads and floor are both 2" thick so the bulk works!
4 seasons (09-09-2012)
Old 09-06-2012, 08:59 PM   #1227
kyle_dmr's Avatar
Rewards Points: 998
About 2800 sqft.
Sunkens galore.
Windows will go in tomorrow, ran short by 10 sheets on the upper roof. Throw them on tomorrow.
This is after 7 days.
kyle_dmr is offline
The Following User Says Thank You to kyle_dmr For This Useful Post:
CanningCustom (09-07-2012)
Old 09-06-2012, 09:19 PM   #1228
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Originally Posted by kyle_dmr View Post
About 2800 sqft.
Sunkens galore.
do just cantilever the upperfloor for the brick to siding transition.
when you do the sunkens based on number of risers is there a specific riser height you are given or you just use say 7 1/2" and inform the stair guy?
roof would be a fun one to sheet.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
The Following User Says Thank You to FramingPro For This Useful Post:
Old 09-08-2012, 08:59 PM   #1229
Forming and Framing
FramingPro's Avatar
after going to pick up some nails and vents for my friends roof tomorrow i started this little project for my neighbour
He has an existing carport with posts and braces on the property dividing side.
So he got someone to come in and dig a footing and lay a course of block with anchor bolts.
I was to close this side in.
and the front too, with an opening for a garage door.
i never even thought i would see this happen but its gonna look sweet!
Blah blah, plumbed down from the beam and snapped my lines for the sills.
framed up the walls.
left openings for windows. and starting sheeting.
The dumbies at RONA shipped us 3/4" T&G OSB instead of 7/16" osb...
The block work is screwed up so i need to snap a level line and pull my sheeting up to that.
we poured a concrete footing to extend the block work farther at the front.
got to use my hilti to drill into the old piers to dowel rebar in
It was dark when i finished so i did not get pics of the garage box beam header i built.
After school i will work on installing the sheeting. and then it will be stuccoed.
Eventually we will demolish the back of the carport which has a shed and extend out the walls to have a bigger space.
we will get a clear window well to cover the window that is at eave level in the flat roof.
i am soo much better at running sill plates now
everything fit first try.
Tommorow i am off to supply LABOR to help my friend do his roof.
rip and tear and install. gonna have to move it, but well get it done.
Oh, the guy whos house i roofed last week asked me to come and do the back half of his other house (4sq gable, no vents no, chimneys)
and i also picked up a heavy duty Stanley hammer tacker for $20
Post A Picture Of Your Current Job -- Part II-amir-garage-framing-september-8.jpg   Post A Picture Of Your Current Job -- Part II-amir-garage-framing-september-8-1-.jpg   Post A Picture Of Your Current Job -- Part II-amir-garage-framing-september-8-2-.jpg
Old 09-08-2012, 10:23 PM   #1230
JesseCocozza's Avatar
Rewards Points: 810
About 2800 sqft.
Sunkens galore.
From slab to this in 7 days? How many guys on your crew? I'm not doubting, just curious.
JesseCocozza is offline
Old 09-09-2012, 07:18 AM   #1231
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
No slab, they would have had to build the floor system as well
www.dominionmasonry.ca
dom-mas is offline
Old 09-09-2012, 08:04 AM   #1232
Working
Cole82's Avatar
Rewards Points: 2,276
Cole's Custom Creations
Cedar Rapids Iowa
Azek trim For the WIN!
The boss of awesome
Cole82 is offline
The Following 2 Users Say Thank You to Cole82 For This Useful Post:
I Mester (09-09-2012), ohiohomedoctor (09-09-2012)
Old 09-09-2012, 08:07 AM   #1233
Working
Cole82's Avatar
Deck reskin on a 15 year old deck.
Replaced broken concrete patio with decorative gravel patio.
New front cedar and composite stairs.
The boss of awesome
Cole82 is offline
Old 09-09-2012, 10:24 AM   #1234
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
He has a 4 man crew Jesse and i can vouch for him
CanningCustom is offline
Old 09-09-2012, 10:56 AM   #1235
kyle_dmr's Avatar
Rewards Points: 998
4 man crew+telehandler.
Theres a ton of bearing walls in the basement, no steel beams except for second floor. slab would easily knock a day+off.
Best we've done this model in is 5 days with a 5man crew, but there were no sunken areas.
kyle_dmr is offline
CanningCustom (09-09-2012)
Old 09-09-2012, 11:05 AM   #1236
Rewards Points: 810
That's awesome. Things here take so much longer because of all the hurricane tie down. I look at a house like that and I see 5 days of tie down alone, let alone framing, sheathing, and truss set.
Old 09-09-2012, 12:21 PM   #1237
jstanton's Avatar
Trade: carpentry
Rewards Points: 214
started this one about two weeks ago. About 8000 sq ft, were doing the framing and cedar shakes with a bunch of sweeping roof ect.
Post A Picture Of Your Current Job -- Part II-imag0511.jpg   Post A Picture Of Your Current Job -- Part II-imag0518.jpg   Post A Picture Of Your Current Job -- Part II-imag0512.jpg
jstanton is offline
Old 09-09-2012, 01:22 PM   #1238
Right, it must be nice to live in a no wind no shake zone. I'm shocked that guys build on here and don't even own a tico nailer
Old 09-09-2012, 03:44 PM   #1239
Working
Cole82's Avatar
Here is a basement we did where the HO was in over there head they called us to bail them out. It sat torn apart for over 2 years before they called.
This is what it looked like when we got there.
This is finished ready for carpet.
Cole
The boss of awesome
Cole82 is offline
Old 09-09-2012, 06:33 PM   #1240
Resident Pain
Who doesnt have a tico nailer? Must be the deck guys eh Randy
The Following User Says Thank You to CanningCustom For This Useful Post:
Dirtywhiteboy (09-09-2012)
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
