Post A Picture Of Your Current Job -- Part II - Page 571 - General Discussion - Contractor Talk
Old 03-22-2019, 06:34 AM   #11401
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,760
Re: Post A Picture Of Your Current Job -- Part II
Stairs just in on one of our on going additions. Now we Clean up / close out this puppy out.
Sent from my E6810 using Tapatalk
CityDecks is offline
The Following 4 Users Say Thank You to CityDecks For This Useful Post:
A&E Exteriors (03-22-2019), asevereid (03-22-2019), overanalyze (03-22-2019), SmallTownGuy (03-22-2019)
Old 03-22-2019, 06:46 AM   #11402
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 15,168
Originally Posted by CityDecks View Post
TPO? Can't tell from pic
Yep, 60mil Carlisle... get to put my robot to use
A&E Exteriors is online now
The Following User Says Thank You to A&E Exteriors For This Useful Post:
CityDecks (03-22-2019)
Old 03-22-2019, 09:06 AM   #11403
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,592
Originally Posted by asevereid View Post
How do you mean? How do we terminate the siding at the top of the window?
Sent from my SM-G903W using Tapatalk
Are you using a drip cap or just caulk?
Randy Bush is online now
Old 03-22-2019, 11:41 AM   #11404
Hack
asevereid's Avatar
Rewards Points: 346
There's drip cap with end dams installed prior to the siding installation.
It gets cut tight and notched to fit over the end dams.
I'm heading out to that site soon... Just need to finish hanging a door. I'll take a picture.
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 03-22-2019, 04:58 PM   #11405
Hack
asevereid's Avatar
Rewards Points: 346
Originally Posted by ksc1 View Post
I've never seen that. Usually the goal is to eliminate unnecessary trim. A small rabbet or even a bead of caulking would look nicer imo.
That said I never use flat stock for the sill. I'd use sill stock...
Builders choice....
Standard around here is vinyl windows with Smart Trim casing.
I haven't installed a sill on the exterior... Ever.
I'd like to start recommending some other room options though.
http://goo.gl/Il8c2
Old 03-22-2019, 06:53 PM   #11406
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Something different for us. One of my favorite installations so far.
Home Designer Series Software
B.Johnson is offline
The Following 10 Users Say Thank You to B.Johnson For This Useful Post:
A&E Exteriors (03-23-2019), asevereid (03-22-2019), CityDecks (03-22-2019), DaVinciRemodel (03-23-2019), Idothat (03-24-2019), KAP (03-22-2019), overanalyze (03-22-2019), SmallTownGuy (03-22-2019), TEnglish14 (03-24-2019), Xtrememtnbiker (03-22-2019)
Old 03-22-2019, 07:36 PM   #11407
Hack
asevereid's Avatar
Rewards Points: 346
Here's a pic of the first couple windows. Didn't make a ton of progress today.
The notches get caulked after all the siding is installed.
http://goo.gl/Il8c2
The Following 2 Users Say Thank You to asevereid For This Useful Post:
Idothat (03-24-2019), Randy Bush (03-24-2019)
Old 03-22-2019, 07:40 PM   #11408
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,504
Awesome!!
overanalyze is online now
Old 03-22-2019, 09:39 PM   #11409
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,923
Working on a small pantry for the client of my kitchen before last. Had the small complication of the door trim being in the way for a wall to wall cabinet. So I built the cabinet and left the face frame off.
So we marked the wall where the FF and scribed it in. Then we put the cabinet, which is 1 1/4" smaller than the OD of the FF so it fit between the door trim and wall. Used a pair of 3rd hands to hold the cabinets up.
So we installed the alignment biscuits and mounted the FF on the cabinet temporarily. this put the box where it needed to be and we screwed it to the wall. Removed the FF, applied glue and reinstalled and used some creative techniques to clamp it tight.
Then we did the same for the lower
Put up the rest of the 3 cabinets, 2 uppers an 1 lower. The lower was a great thing at the end of the day. Just put it in and it was snug between the wall and door trim, level and plumb. Just screw it to the wall.
Thanks Sno!
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 5 Users Say Thank You to Leo G For This Useful Post:
asevereid (03-22-2019), Bull Trout (03-22-2019), Idothat (03-24-2019), META (03-24-2019), overanalyze (03-22-2019)
Old 03-22-2019, 10:13 PM   #11410
Bull Trout's Avatar
Rewards Points: 132
Originally Posted by Leo G View Post
Working on a small panty for the client
We talking thong or g sting?
Bull Trout is offline
The Following 2 Users Say Thank You to Bull Trout For This Useful Post:
B.Johnson (03-23-2019), SmallTownGuy (03-23-2019)
Old 03-22-2019, 10:14 PM   #11411
META's Avatar
Trade: General and Trades
Rewards Points: 7,146
Approximately 700' of 2'x6" slab at various lengths. What a freaking mess this slab is.
The building has about 14, 56' footings every 10' going perpendicular to length of the building.
META is offline
The Following 3 Users Say Thank You to META For This Useful Post:
asevereid (03-22-2019), Bull Trout (03-22-2019), tgeb (03-23-2019)
Old 03-22-2019, 10:38 PM   #11412
LRG WoodCrafting
Leo G's Avatar
Whoopsie.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-22-2019, 11:03 PM   #11413
tjbnwi's Avatar
Rewards Points: 4,142
Leo,
You do absolutely beautiful work.
tjbnwi is online now
KAP (03-23-2019)
Old 03-23-2019, 09:07 AM   #11414
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,062
Thanks Sno!
Nice stuff there Leo
In the last picture, what are the vertical dividers intended for?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 03-23-2019, 11:31 AM   #11415
LRG WoodCrafting
Leo G's Avatar
I have no idea what they are going to be used for. She gave me the design and I made it. I suspect it's going to be for individual canned items or something. The partitions are removable to make more or less space per area. I set it up so they can take them out completely included the slotted guides so she can have a single open space or put a drawer in there.
Something that's harder to see is the upper cabinet straight in front of the doorway has 2 removable hanging bars so she can hang her decorative table linens in there.
I will be working there for the next 2 years or so on various projects so eventually she'll fill the pantry up and I'll see what she planned for the partitions.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-23-2019, 11:33 AM   #11416
LRG WoodCrafting
Leo G's Avatar
Originally Posted by tjbnwi View Post
Leo,
Thanks Tom
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-23-2019, 06:56 PM   #11417
End of yesterday and today.
The Following 5 Users Say Thank You to A&E Exteriors For This Useful Post:
asevereid (03-23-2019), B.Johnson (03-23-2019), Bull Trout (03-25-2019), Idothat (03-24-2019), KAP (03-24-2019)
Old 03-24-2019, 01:04 PM   #11418
SprayGenX's Avatar
Trade: Industrial Painting
Latest project, a commercial flat black ceiling. I actually love these types of jobs!
*New Member Alert! lol
SprayGenX is offline
The Following 4 Users Say Thank You to SprayGenX For This Useful Post:
A&E Exteriors (03-25-2019), asevereid (03-24-2019), DaVinciRemodel (03-24-2019), Idothat (03-24-2019)
Old 03-24-2019, 01:50 PM   #11419
CityDecks's Avatar
Trade: Deck Builder
No job site today but at shop prepping... this is why I love the Fein. Besides the obvious of it being a work horse. Auto Clean is excellent and will smoke a festi ac any day of the week.( Don't get me wrong I enjoy festi very much). I Know I had one and traded up. Its impressive how compact it is. And compact easy in/out/lean is a life style for me.
You can stack tstak and sys boxes.... Perfect GRABNGO
The Following 2 Users Say Thank You to CityDecks For This Useful Post:
asevereid (03-24-2019), Idothat (03-24-2019)
Old 03-24-2019, 02:07 PM   #11420
LRG WoodCrafting
Leo G's Avatar
That's the one with the Yikes! pricing.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
