Post A Picture Of Your Current Job -- Part II - Page 568 - General Discussion - Contractor Talk
Old 03-13-2019, 10:41 PM   #11341
tjbnwi's Avatar
Rewards Points: 2,850
Re: Post A Picture Of Your Current Job -- Part II
Originally Posted by Xtrememtnbiker View Post
I shot it but it was your phone. February 3rd or 4th 2018.
If I recall you sucked at making a run on purpose and went way overboard and weren't happy with it.
Thanks.
tjbnwi is offline
Old 03-13-2019, 11:04 PM   #11342
tjbnwi's Avatar
Thanks Travis, I found them by the dates.
As Travis said, got a little heavy on the paint. You'll see the process.
tjbnwi is offline
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
asevereid (03-14-2019), kevjob (03-14-2019), Tinstaafl (03-14-2019)
Old 03-13-2019, 11:24 PM   #11343
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 288
https://youtu.be/67PyCglwgyg
With a more properly applied amount of paint and a more typical run, this does in fact work. As I recall we tossed the piece in the dumpster and you said you would try again...
Xtrememtnbiker is offline
Old 03-14-2019, 12:27 AM   #11344
hdavis's Avatar
Rewards Points: 7,630
Looks easy to do, but with some technique.
hdavis is online now
Old 03-14-2019, 08:21 PM   #11345
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,394
Almost done with the stupid lightweight concrete
A&E Exteriors is offline
Old 03-14-2019, 08:30 PM   #11346
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,254
Self level right? Getting rid of low spot/ ponding?
Sent from my E6810 using Tapatalk
CityDecks is offline
The Following User Says Thank You to CityDecks For This Useful Post:
A&E Exteriors (03-14-2019)
Old 03-14-2019, 08:31 PM   #11347
CityDecks's Avatar
Trade: Deck Builder
Big roof
Old 03-14-2019, 08:33 PM   #11348
You got it. Getting rid of the ponds.
1 80lb bac stucco concrete and 1 25lb pag of perlite per mix..... 10 down 2 to go. Lol
The Following User Says Thank You to A&E Exteriors For This Useful Post:
overanalyze (03-14-2019)
Old 03-14-2019, 08:35 PM   #11349
Big roof
Right about 130sq with the walls.
Got my 170sq former save a lot waiting for me to get back to michigan....that one has to come off first.
Old 03-14-2019, 08:36 PM   #11350
CityDecks's Avatar
Trade: Deck Builder
We've done fair amount of that before we Deck it.
Old 03-14-2019, 08:38 PM   #11351
CityDecks's Avatar
Trade: Deck Builder
Wow 1700' of roof demo... Just curious how thick/layers on that thing.
Old 03-14-2019, 08:43 PM   #11352
Roughly 3" of built up hot mop. I pulled the penetrations on the rear section last fall so the spray fomer could do his thing underneath.
Been waiting on that job for 2 1/2 years
Old 03-14-2019, 08:52 PM   #11353
CityDecks's Avatar
Trade: Deck Builder
Is 3 yrs typical for commercial job of that size? Under the 3" of crap is there the usual steel deck with concrete? Shoots and dumpsters or pack up what we call jumbo sack's. Typically used for sand and cement etc. They hold 1.5+/- tons and crane off roof? We use the jumbo sack's Stage them and call a crane and demo guy on ground with trailer or stake body. We have a 1000' deck to demo soon. Cut it sack it crane to dump trailer below. Sack it to dump trailer.
Old 03-14-2019, 08:55 PM   #11354
CityDecks's Avatar
Trade: Deck Builder
Staging 4000'... What a day
The Following 5 Users Say Thank You to CityDecks For This Useful Post:
A&E Exteriors (03-14-2019), asevereid (03-14-2019), Calidecks (03-15-2019), overanalyze (03-14-2019), SmallTownGuy (03-15-2019)
Old 03-14-2019, 09:05 PM   #11355
6-12 months is more of a typical wait.
The owner has just had more pressing projects going and was using that building for storage. Now he has a gym tennant renting the rear section of the building and the front is leaking bad.
He is pretty much stuck with a complete and total reroof. I pushed to get him to do the rear last fall but he opted to wait.....i even told him after we pulled the penetrations out that the aluminum coil stock and tar patch job would last 6 months tops when we did it. As he initially had been the one to mention pulling the trigger on the "back 40" sq section.
I want to say that one has a steel deck, 1/2" celotex fiberboard then the felt and hot mop sandwich.
CityDecks (03-17-2019)
Old 03-14-2019, 09:08 PM   #11356
The plan for us is to use my roofcutter. (That thing is on its second or third tank of fuel....lol) and use a skytrack to move the debris to the dumpster.
I'd love to do one of your projects
Old 03-14-2019, 09:20 PM   #11357
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,718
No one else in Phili builds decks?
Inner10 is offline
The Following 3 Users Say Thank You to Inner10 For This Useful Post:
A&E Exteriors (03-14-2019), cedarboarder (03-14-2019), Stryker1-1 (03-22-2019)
Old 03-14-2019, 09:55 PM   #11358
rblakes1's Avatar
Rewards Points: 2,932
Got the outside wrapped up today. I made the new fluted molding to match what was there before. Used Kleer boards for everything, so no rot worry.
Tomorrow I'll finish the casing inside and get the number back up on the outside, and that should wrap it up.
They are having new siding installed in a week or two, so that's why there's a gap at the edges
-Rich
rblakes1 is offline
The Following 6 Users Say Thank You to rblakes1 For This Useful Post:
asevereid (03-14-2019), B.Johnson (03-15-2019), KAP (03-15-2019), overanalyze (03-15-2019), SmallTownGuy (03-15-2019), Tom M (03-22-2019)
Old 03-14-2019, 09:57 PM   #11359
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,324
Allegedly
Big Johnson is offline
Old 03-15-2019, 09:53 PM   #11360
tjbnwi's Avatar
Can finally see the light at the end of the tunnel....
Post A Picture Of Your Current Job -- Part II-img_1056.jpg   Post A Picture Of Your Current Job -- Part II-img_1057.jpg   Post A Picture Of Your Current Job -- Part II-img_1059.jpg   Post A Picture Of Your Current Job -- Part II-img_1055.jpg   Post A Picture Of Your Current Job -- Part II-img_1051.jpg
tjbnwi is offline
The Following 10 Users Say Thank You to tjbnwi For This Useful Post:
asevereid (03-16-2019), Bull Trout (03-16-2019), Idothat (03-16-2019), J.C. (03-18-2019), KAP (03-16-2019), overanalyze (03-15-2019), rblakes1 (03-16-2019), TheConstruct (03-15-2019), Tom M (03-22-2019), Xtrememtnbiker (03-15-2019)
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
