Post A Picture Of Your Current Job -- Part II - Page 567 - General Discussion - Contractor Talk
Old 03-12-2019, 07:23 AM   #11321
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Siding, & Additions
Rewards Points: 15,362
Re: Post A Picture Of Your Current Job -- Part II
It's about that time...
A&E Exteriors is online now
The Following 3 Users Say Thank You to A&E Exteriors For This Useful Post:
asevereid (03-12-2019), CityDecks (03-12-2019), overanalyze (03-12-2019)
Old 03-12-2019, 04:45 PM   #11322
Hack
asevereid's Avatar
Rewards Points: 408
Got rid of my problem with the runs....
Fixed the door I screwed up too...
I cut the paint down as flush as I could with a razor blade, then scuffed the area, wiped a thin coat of Crackshot on it, sanded that down, spot sprayed, scuffed the whole door again, then applied one more coat.
I tried to go too light, so it's got a bit of texture to it. I may scuff it and spray one more coat because I'm still set up for it.
Just about finished at this reno I'm on, but the HO keep making last minute changes that are continuing to prolong the completion...
I just want to get back to my other one and start siding...
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
The Following 7 Users Say Thank You to asevereid For This Useful Post:
B.Johnson (03-12-2019), bwiab (03-13-2019), overanalyze (03-12-2019), rblakes1 (03-12-2019), Robie (03-12-2019), SmallTownGuy (03-12-2019), Tom M (03-13-2019)
Old 03-12-2019, 06:09 PM   #11323
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,792
I just want to get back to my other one and start siding... [IMG]https://uploads.tapatalk-cdn.com/20190312/517442a70f96c93d1792943222993879.jpg[/IM[IMG]https://uploads.tapatalk-cdn.com/20190312/7444be8388b3c6b8d012baed95ced015.jpg[/IM[IMG]https://uploads.tapatalk-cdn.com/20190312/e3a5912bf90aba089b9f76ef5aa235f0.jpg[/IM
Are they the hollow masonitish doors? Those always have a slight texture without a ton of work.
Big Johnson is online now
Old 03-12-2019, 06:41 PM   #11324
Hack
asevereid's Avatar
Rewards Points: 408
Nope...one is solid pine (actually turned out decent) ,4 are fir or old growth pine (original to the house), one is hollow core, and there's one smooth solid core.
I got texture because I misted the repair coat and didn't sand before applying it.
By the end of the day today I had time to fix it.
Sanded the door with 100 grit, wiped it down, spot sprayed the details, and then applied a heavy, even coat and let it lay flat until I could pick it up without worrying.
http://goo.gl/Il8c2
The Following User Says Thank You to asevereid For This Useful Post:
TheConstruct (03-12-2019)
Old 03-12-2019, 06:42 PM   #11325
Hack
asevereid's Avatar
Rewards Points: 408
I think this is the "after" pic...
http://goo.gl/Il8c2
Old 03-12-2019, 06:48 PM   #11326
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,223
100 grit.
Whoa.
I use 220 or 320 for in between coats.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 03-12-2019, 06:53 PM   #11327
Hack
asevereid's Avatar
Rewards Points: 408
Originally Posted by Leo G View Post
100 grit.
Whoa.
It's what I had on hand from drywall prep... It was pretty worn down by this point.
http://goo.gl/Il8c2
Old 03-12-2019, 07:41 PM   #11328
220 wet, then 320 wet on that run and you probably could have gotten away without repainting it. Maybe a final 400 polish. Depending on the paint sheen.
I can wet sand a satin run with 220 and you have to bounce light off the repair just right to make it out.
The trick is to not burn the paint while sanding.
The Following 4 Users Say Thank You to Big Johnson For This Useful Post:
asevereid (03-12-2019), bwiab (03-13-2019), overanalyze (03-12-2019), TheConstruct (03-12-2019)
Old 03-12-2019, 07:57 PM   #11329
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,216
With the size of that run, hed have to wait till sometime in May before he could wet sand it.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
The Following 3 Users Say Thank You to DaVinciRemodel For This Useful Post:
asevereid (03-12-2019), bwiab (03-13-2019), TheConstruct (03-12-2019)
Old 03-12-2019, 08:03 PM   #11330
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,548
1 of 2 custom vanities we made for a master bath. Had my cab shop make the boxes for me and then I cut and fit the fronts and panels. These have Salice push-to-open glides with soft close. Royal pain to get everything aligned and working right with solid wood slabs.
Epoxied the voids prior to cutting the components. Mitered edges with grain matched corners.
Took the pieces over to our lumber yard and ran them through their wide belt this morning...that thing is awesome!!
overanalyze is online now
The Following 11 Users Say Thank You to overanalyze For This Useful Post:
asevereid (03-12-2019), bwiab (03-13-2019), Calidecks (03-12-2019), CityDecks (03-12-2019), Idothat (03-12-2019), KAP (03-12-2019), pizalm (03-15-2019), rblakes1 (03-12-2019), TheConstruct (03-12-2019), Tom M (03-13-2019), Xtrememtnbiker (03-12-2019)
Old 03-12-2019, 08:10 PM   #11331
Hack
asevereid's Avatar
Rewards Points: 408
With all the last minute changes and the "while you're here's..." I very well might still be here in May...
http://goo.gl/Il8c2
The Following 4 Users Say Thank You to asevereid For This Useful Post:
DaVinciRemodel (03-13-2019), KAP (03-12-2019), overanalyze (03-12-2019), TheConstruct (03-12-2019)
Old 03-12-2019, 08:17 PM   #11332
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,780
Building another deck and addition 25' across the street. It gets better. My shop is about 125' down the street.
Sent from my E6810 using Tapatalk
CityDecks is offline
The Following 7 Users Say Thank You to CityDecks For This Useful Post:
asevereid (03-12-2019), Calidecks (03-12-2019), Idothat (03-12-2019), KAP (03-12-2019), overanalyze (03-12-2019), rblakes1 (03-13-2019), tgeb (03-12-2019)
Old 03-12-2019, 10:00 PM   #11333
It is pretty bad, almost like he tried to do it.
Old 03-12-2019, 10:15 PM   #11334
Hack
asevereid's Avatar
Rewards Points: 408
Nope, just good old fashioned ineptitude.
http://goo.gl/Il8c2
Old 03-12-2019, 10:51 PM   #11335
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 342
Originally Posted by Robie View Post
No kidding?
Tell me more...never heard of that method.
When I visited Tom he showed me how to do it by creating a run and then lifting it.
You take a piece of tape a few inches long, hold it in both hands with the sticky side facing the work piece, and roll/push (for lack of a better term) it into the run.
You don't even have to be that careful or precise while doing it, and it just works... Obviously you want to do it as soon as possible so the paint can level out around the area you just removed the run.
Xtrememtnbiker is online now
The Following 2 Users Say Thank You to Xtrememtnbiker For This Useful Post:
asevereid (03-12-2019), overanalyze (03-13-2019)
Old 03-13-2019, 09:00 PM   #11336
rblakes1's Avatar
Rewards Points: 4,012
Installing a new door. Thermatru with Reeb finish on it.
Tomorrow I'll get the trim done and storm door on
-Rich
rblakes1 is online now
The Following 4 Users Say Thank You to rblakes1 For This Useful Post:
asevereid (03-13-2019), Idothat (03-14-2019), overanalyze (03-14-2019), Tom M (03-22-2019)
Old 03-13-2019, 10:04 PM   #11337
tjbnwi's Avatar
Rewards Points: 4,694
No kidding?
Robie,
Travis explained the process well. Works very well, timed properly the area will fill itself back in. This comes from my automotive days, if you ran Imron it was hard as granite, it take 36 grit to grind the run out. It was always best to lift the run.
I though I had a YT video up on how to accomplish this, wasn't there. I'll look on my phone to see if I can find it.
I highly recommend getting fine and corse run chasers/de-nibbing files, and a razor run trimmer.
tjbnwi is online now
Old 03-13-2019, 10:19 PM   #11338
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,006
I'd really like to see that video, if it exists. Travis did probably as well as can be expected via text, but my text-to-video just isn't working all that well.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
overanalyze (03-14-2019), tgeb (03-14-2019), Xtrememtnbiker (03-13-2019)
Old 03-13-2019, 10:27 PM   #11339
tjbnwi's Avatar
Travis, did you shoot a video on your phone?
If not, should get to this by the end of the month...
Tinstaafl (03-13-2019)
Old 03-13-2019, 10:39 PM   #11340
Rewards Points: 342
I shot it but it was your phone. February 3rd or 4th 2018.
If I recall you sucked at making a run on purpose and went way overboard and weren't happy with it.
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
