Post A Picture Of Your Current Job -- Part II - Page 566 - General Discussion - Contractor Talk
Old 03-06-2019, 01:19 AM   #11301
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 294
Re: Post A Picture Of Your Current Job -- Part II
So close... but so far...
Post A Picture Of Your Current Job -- Part II-20190227_160724-1-copy.jpg   Post A Picture Of Your Current Job -- Part II-20190225_113845-copy.jpg
bwiab is offline
The Following 5 Users Say Thank You to bwiab For This Useful Post:
asevereid (03-06-2019), B.Johnson (03-06-2019), Calidecks (03-06-2019), Dirtywhiteboy (03-12-2019), Idothat (03-06-2019)
Old 03-06-2019, 08:18 AM   #11302
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
Sorting this little mess out. Looks like the Telco crossed a line at the street.
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
The Following 2 Users Say Thank You to Stryker1-1 For This Useful Post:
hdavis (03-06-2019), Idothat (03-10-2019)
Old 03-09-2019, 10:40 PM   #11303
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,846
Wrapped this city yard up cpl of month ago didn't really get hold pics till today.
Sent from my E6810 using Tapatalk
CityDecks is online now
The Following 11 Users Say Thank You to CityDecks For This Useful Post:
asevereid (03-09-2019), B.Johnson (03-10-2019), Calidecks (03-10-2019), Idothat (03-10-2019), Jaws (03-09-2019), KAP (03-09-2019), overanalyze (03-12-2019), Rio (03-10-2019), SmallTownGuy (03-10-2019), tgeb (03-10-2019), Tom M (03-12-2019)
Old 03-10-2019, 02:34 PM   #11304
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,425
This is an oops from the client. He wanted me to do a bump out of the crown over the sink cabinet area because he would be putting tile up after I left from installing the kitchen. I did that for him. Applied a 7/16" strip of wood and put the crown on top of that leaving a small space under the crown for the molding to tuck if the tile guy chose to go that route.
The client went on vacation and a day later called to tell me he forgot to tell me that he was putting tile on the media wall too. And that I needed a bump out for the tile in the crown on that wall also.
Well, of course I cope my crown so it makes it a pain to remove a section without it affecting another run of crown. So I came up with a plan to circumvent removing the crown that was tucked under the other cope. The right side of the crown was the over cope (easily removed), and the left side was the under cope (trapped)
I took my measurements at the house and went to the shop to do the work on the crown. I happened to buy an extra piece and that's where it was. The space between the cabinet and the door trim is 45". So I coped both ends of a pc of 55" trim, tuned it in with my Dremel. I did a setup to determine the length I'd need to cut the outside miter at by mimicking the crown on the cabinet and the 7/16" board I was using to space the crown from the wall. Got the length, cut the miter. And then for the other cope, which is very skinny I setup the crown on the 7/16" board, made the mark and cut the miter. This left a 1/4" slice of crown with a miter on one side and a cope on the other, very delicate. Then I glued the two miters together, just TBII and about 2 minutes of clamping with my fingers.
Then I did a test and because the return is so skinny I couldn't just overlay it like I was hoping. I made a test pc and cut an angle on it finally coming up with about 35º that the mating part needed to be cut at along with removing a bit at the top of the crown to make it all work.
All this took about an hour.
Brought it to the house and made a mark on the crown using a laser to line things up.
This is the only pic I have of the original crown on the wall.
This wall
Made the cut, you can see the laser I used to line the cut with.
The crown I assembled at the shop worked out well, copes on both ends fit nice. A little caulk and it'll look perfect.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 5 Users Say Thank You to Leo G For This Useful Post:
asevereid (03-11-2019), Idothat (03-11-2019), rblakes1 (03-11-2019), Robie (03-10-2019), tgeb (03-10-2019)
Old 03-10-2019, 04:55 PM   #11305
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,976
Quaint little porch we're doing.
Mike.
_______________
Calidecks is online now
The Following 4 Users Say Thank You to Calidecks For This Useful Post:
Idothat (03-10-2019), overanalyze (03-12-2019), rblakes1 (03-11-2019), Robie (03-10-2019)
Old 03-10-2019, 05:58 PM   #11306
KAP's Avatar
Trade: Custom
Rewards Points: 36,650
Mike.
_______________
For kicks?...
Never seen you do one that small...
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
asevereid (03-11-2019), Calidecks (03-11-2019)
Old 03-10-2019, 07:01 PM   #11307
CityDecks's Avatar
Trade: Deck Builder
Hot Job . It's lil like therapy.
Mike.
_______________
The Following User Says Thank You to CityDecks For This Useful Post:
Old 03-11-2019, 03:07 PM   #11308
rblakes1's Avatar
Rewards Points: 3,532
Refinishing the doors that go with the trim I stained last week
-Rich
rblakes1 is offline
The Following 5 Users Say Thank You to rblakes1 For This Useful Post:
asevereid (03-11-2019), hdavis (03-11-2019), Idothat (03-11-2019), KAP (03-11-2019), overanalyze (03-12-2019)
Old 03-11-2019, 04:46 PM   #11309
LRG WoodCrafting
Leo G's Avatar
Gonna be putting this pullout ironing board into a cabinet for a laundry room. Nice quality unit. But it did have a non-oiled issue with the 2 SOSS hinges, squeaked like a mouse being run over. And it's setup for a Euro style cabinet so I'll need to modify the stops they have setup, which I can do without much hassle. Other than that it's very sturdy and easy to operate.
Video was done pre-oiling the hinges.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
asevereid (03-11-2019), Idothat (03-11-2019), KAP (03-11-2019)
Old 03-11-2019, 06:49 PM   #11310
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,684
I don't like it.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 03-11-2019, 07:09 PM   #11311
Hack
asevereid's Avatar
Rewards Points: 100
Oops...
Painting doors for the reno I'm trapped in right now. Tried to rush, made a mistake.
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following 3 Users Say Thank You to asevereid For This Useful Post:
Idothat (03-11-2019), overanalyze (03-12-2019), TheConstruct (03-12-2019)
Old 03-11-2019, 08:07 PM   #11312
Box Builder
Morning Wood's Avatar
Rewards Points: 10,240
Still ripping this turd apart. Going to make it shine.
Morning Wood is offline
The Following 3 Users Say Thank You to Morning Wood For This Useful Post:
Old 03-11-2019, 08:53 PM   #11313
LRG WoodCrafting
Leo G's Avatar
Originally Posted by Robie View Post
I don't like it.
Who's asking you anyway?
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-11-2019, 08:58 PM   #11314
CityDecks's Avatar
Trade: Deck Builder
Just another day to crush in the City
The Following 5 Users Say Thank You to CityDecks For This Useful Post:
asevereid (03-11-2019), Calidecks (03-11-2019), Idothat (03-11-2019), KAP (03-12-2019), SmallTownGuy (03-11-2019)
Old 03-11-2019, 08:59 PM   #11315
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Hey Robie, do you like it?
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
B.Johnson (03-12-2019)
Old 03-11-2019, 09:18 PM   #11316
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 544
Originally Posted by asevereid View Post
Oops...
That’ll buff right out
Idothat is online now
The Following 2 Users Say Thank You to Idothat For This Useful Post:
asevereid (03-11-2019), DaVinciRemodel (03-12-2019)
Old 03-11-2019, 09:22 PM   #11317
LRG WoodCrafting
Leo G's Avatar
To bad it's latex. It'll take forever to dry. Let it dry and cut it off with a razor. Sand smooth and try again.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 03-11-2019, 09:58 PM   #11318
Robie's Avatar
oops...
Painting doors for the reno i'm trapped in right now. Tried to rush, made a mistake.
sent from my sm-g903w using tapatalk
btdt
Mark Twain
Robie is online now
Old 03-11-2019, 10:07 PM   #11319
tjbnwi's Avatar
Rewards Points: 1,134
Oops...
Lift it with masking tape.
tjbnwi is online now
Old 03-12-2019, 07:02 AM   #11320
Robie's Avatar
No kidding?
Tell me more...never heard of that method.
Mark Twain
Robie is online now
The Following 3 Users Say Thank You to Robie For This Useful Post:
Lettusbee (03-12-2019), overanalyze (03-12-2019), tgeb (03-12-2019)
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
