Post A Picture Of Your Current Job -- Part II - Page 553 - General Discussion - Contractor Talk
Old 01-19-2019, 07:01 PM   #11041
Patrickstew's Avatar
Trade: Exterior Remodel and Repair Contractor
Rewards Points: 298
Re: Post A Picture Of Your Current Job -- Part II
New Simonton Stormbreaker windows new roof tear off reside and aluminum bahama shutter and addition of grill deck.
Patrickstew is offline
The Following User Says Thank You to Patrickstew For This Useful Post:
Idothat (01-19-2019)
Old 01-19-2019, 07:11 PM   #11042
Rewards Points: 298
Stucco demo to find studs to nowhere and a house falling over from covered up termite damage unmentioned by drywall contractor before we tagged in.
The Following 2 Users Say Thank You to Patrickstew For This Useful Post:
Idothat (01-19-2019), overanalyze (01-20-2019)
Old 01-19-2019, 07:22 PM   #11043
Rewards Points: 298
Add on Azek composite deck, pergola with sleeves, and composite rail and ballasters. Very odd floating footer we had to run per engineering but turned out nicely.
asevereid (01-20-2019), Idothat (01-19-2019)
Old 01-19-2019, 07:25 PM   #11044
Rewards Points: 298
New Simonton Impacts and Reside with Hardie color plus Evening Blue. First time using color and it turned out great.
Old 01-19-2019, 07:30 PM   #11045
Rewards Points: 298
Azek composite deck to replace existing non code trash
Old 01-20-2019, 11:39 AM   #11046
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
Wow those stringers are super spanned for composite decking stairs. What's the tread material?
Sent from my SM-G930W8 using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 01-20-2019, 11:44 AM   #11047
Rewards Points: 298
We added more believe me. Azek Premier eased edge.
Old 01-20-2019, 12:08 PM   #11048
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
I misunderstood. I thought you were installing on the existing stringers as shown.
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
Patrickstew (01-20-2019)
Old 01-20-2019, 12:10 PM   #11049
Rewards Points: 298
Existing wasnít to code when we got contracted so we made it right. No mechanical hardware on stringers existed no ledger board for original stringers etc. was a real wreck and why it was in need of replacing.
heavy_d (01-20-2019)
Old 01-20-2019, 08:53 PM   #11050
tjbnwi's Avatar
Rewards Points: 1,640
Set a few more doors today.
Post A Picture Of Your Current Job -- Part II-img_0895.jpg   Post A Picture Of Your Current Job -- Part II-img_0894.jpg   Post A Picture Of Your Current Job -- Part II-img_0892.jpg   Post A Picture Of Your Current Job -- Part II-img_0896.jpg
tjbnwi is online now
The Following 8 Users Say Thank You to tjbnwi For This Useful Post:
asevereid (01-21-2019), B.Johnson (01-21-2019), Idothat (01-20-2019), KAP (01-21-2019), Patrickstew (01-20-2019), rblakes1 (01-21-2019), Robie (01-20-2019), Xtrememtnbiker (01-20-2019)
Old 01-20-2019, 09:00 PM   #11051
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 765
Much better with the green tape
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-20-2019, 09:03 PM   #11052
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 798
Fantastic work as usual
How did you do the square holes in the panels?
Idothat is online now
Old 01-20-2019, 09:22 PM   #11053
tjbnwi's Avatar
I did it for you.
Old 01-20-2019, 09:23 PM   #11054
tjbnwi's Avatar
They are 1/2" diameter round holes.
Old 01-20-2019, 09:26 PM   #11055
Rewards Points: 298
What did you finish coat these with and what prep was involved beforehand? They look amazing man!
Old 01-20-2019, 09:28 PM   #11056
Idothat's Avatar
Rewards Points: 798
Okay, they looked square to me on my tablet . I was guessing a mortiser but , I didnít think that would work , thatís why I asked
The Following User Says Thank You to Idothat For This Useful Post:
Old 01-20-2019, 09:58 PM   #11057
tjbnwi's Avatar
I use Sherwin Williams Kem Aqua +. It is a water bourne lacquer.
Assemble, check for surface flaws, fill, sand 150, Gen II primer/surfacer, inspect for flaws, fill, sand 240, Gen II primer/surfacer, check for flaws, fill, sand 240, top coat, top coat.
Old 01-20-2019, 10:15 PM   #11058
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 765
More work in it than I have to do with MLC solvent base.
White wood fill if there is something big. Prime, fill with Mohawk crayon if necessary. 2 Topcoats.
Yours look real nice. Eventually we'll all be forced to go waterborne.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-20-2019, 10:32 PM   #11059
tjbnwi's Avatar
I like to go over things and fill flaws prior to the finish sand. Has nothing to do with the product, everything to do with my preferred process. By the way M.L. Campbell waterborne suck.
I use trowelable floor filler, Elemers Max or (can't remember the name, sucks getting old[er])
I could go with one coat of Gen II, I've always preferred 2 prime coats. Gives me a chance to go over everything.
99% of the sanding is under power, using a Festool ETS 125, RTS or DTS.
Top coat applications are wash. If it is more than 12 hours between coats, SW recommends a 240 sand prior to the second top coat.
Old 01-20-2019, 10:43 PM   #11060
Rewards Points: 298
Thatís an obnoxiously full punch list to get a finish like you accomplish but as a perfectionist as Iím assuming you are also, it really looks outstanding. Beautiful man.
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
