Post A Picture Of Your Current Job -- Part II - Page 537 - General Discussion - Contractor Talk
Old 11-08-2018, 09:12 PM   #10721
Box Builder
Morning Wood's Avatar
Rewards Points: 9,662
Re: Post A Picture Of Your Current Job -- Part II
Originally Posted by heavy_d View Post
Finished this deck today. Built most of it in the rain and mud. My next and final deck of the season is Trex.
Sent from my SM-G930W8 using Tapatalk
3 days?
Morning Wood is online now
Old 11-08-2018, 09:34 PM   #10722
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,876
Originally Posted by Morning Wood View Post
3 days?
Longer than that. I didn't keep track of this one as it was frustrating working around the rain.
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 11-08-2018, 09:59 PM   #10723
Dirtywhiteboy's Avatar
Rewards Points: 9,330
Originally Posted by WarnerConstInc. View Post
Under 30" requires no hand railing.
Not going to get anywhere trying to fight something built to code. Plus an attorney owns the place.
No ones fighting.. I know codes are different all over. We have very odd and stiff codes here. We can't build a deck less that 24" off the ground to bottom of beam. It really cut's us out on a lot of decks.
Dirtywhiteboy is offline
Old 11-08-2018, 11:49 PM   #10724
Decks go out back, not out front.
Thanks for letting me know where you guys put your decks. We don't fallow your rules here. Here we do the thing called a Lanai and they often wrap all the way around the house. Makes it extra living space because we can be outside here year round
I think a lot of the architecture here is old Victorian.
The Following 3 Users Say Thank You to Dirtywhiteboy For This Useful Post:
Calidecks (11-09-2018), griz (11-08-2018), Tom M (11-09-2018)
Old 11-09-2018, 01:11 AM   #10725
Safety Third
shanewreckd's Avatar
Trade: Concrete Cowboy
Rewards Points: 682
Originally Posted by Easy Gibson View Post
Are you an eccentric billionaire or something? What you makin?
No I'm just a cog in the wheel man.
Building a LPG terminal facility in Prince Rupert, BC. Our contract is the foundations for the 3 spheres being built to hold the propane. It's been an interesting project; gnarly weather, lots of blasting, the tear-down of the final remaining towers from the pump mill that closed in 01, some engineering , this 400t crane.
shanewreckd is offline
The Following User Says Thank You to shanewreckd For This Useful Post:
Easy Gibson (11-09-2018)
Old 11-09-2018, 07:49 AM   #10726
KAP's Avatar
Trade: Custom
Rewards Points: 32,598
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
shanewreckd (11-09-2018)
Old 11-09-2018, 04:53 PM   #10727
Safety Third
Rewards Points: 682
Originally Posted by KAP View Post
I would be lost without you KAP
Old 11-10-2018, 11:09 AM   #10728
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,120
Put up a digital mirror for a store personally I think it's nothing but an over priced over sized android tablet but hey it's not my money
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
The Following 5 Users Say Thank You to Stryker1-1 For This Useful Post:
KAP (11-10-2018), onmywayup (11-11-2018), overanalyze (11-10-2018), rblakes1 (11-10-2018), TheConstruct (11-10-2018)
Old 11-10-2018, 02:41 PM   #10729
Mike-B's Avatar
Rewards Points: 850
We are planning to lift this faux brick enclosure up onto a rooftop in the city on Monday. It was prebuilt in our shop. We dont make the parts, just assemble. New antennas and radios installed. There is some existing equipment on site that will be moved inside the enclosure once set.
We drove it to site this morning. After checking the lights on the trailer i realized i covered them up with the banner. Had to move it before hitting the road
This was the first oversize, permitted load we've hauled in house. It typically gets subbed. This one is less than 12' wide and 10K lbs so, decided to do it ourselves. Getting the permit was a learning curve..
This material has been in our laydown yard for months. During tge first attemot to build it, we went to site to field verify some dimensions and found multiple issues. The specialty fab corp and the EOR were pointing fingers at each other for the mistakes. Then it got put on me, both were saying it is my responsibility to field verify before it is released to fabrication. I agreed with them on that but, we did not release it to fabrication. Once that point was made, everything got quiet for a awhile.
Finally, a SOW was agreed upon snd a PO released. We had to fab and weld new base plates on all support columns, punch new holes for columns in the main beams since all were improperly located. Rework all holes for vertical and diagonal FRP attachment to main beams. Once we did that and started assembly, we found they didnt provide any antenna masts so we had to weld some up. The panels didnt line up quite right so we had to cut one in the shop and then cut a new rabbet in it for alignment. I'm thinking a router would have been the tool of choice but, I dont have one.
Mike-B is offline
The Following 7 Users Say Thank You to Mike-B For This Useful Post:
asevereid (11-10-2018), KAP (11-10-2018), overanalyze (11-11-2018), rblakes1 (11-10-2018), SmallTownGuy (11-10-2018), tgeb (11-11-2018), TheConstruct (11-10-2018)
Old 11-10-2018, 03:56 PM   #10730
rblakes1's Avatar
Rewards Points: 2,928
Alex is my 2nd cousin, was really cool watching him in the Olympics 4 years ago.
Edit- on TV that is
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Stryker1-1 (11-10-2018)
Old 11-11-2018, 03:41 PM   #10731
mrking3000's Avatar
Trade: Aerial Site Surveyor
Rewards Points: 18
Foundation replacement
mrking3000 is offline
The Following 7 Users Say Thank You to mrking3000 For This Useful Post:
asevereid (11-11-2018), Dirtywhiteboy (11-11-2018), Idothat (11-11-2018), KAP (11-11-2018), overanalyze (11-11-2018), SmallTownGuy (11-11-2018), tgeb (11-11-2018)
Old 11-11-2018, 03:42 PM   #10732
mrking3000's Avatar
Rewards Points: 18
Wow, that looks great!
Old 11-11-2018, 07:29 PM   #10733
Stryker1-1's Avatar
Installed and calibrated some traffic counting cameras for a book store.
More and more stores are trying to gather as much analytics on their customers as possible.
The Following User Says Thank You to Stryker1-1 For This Useful Post:
TxElectrician (11-17-2018)
Old 11-11-2018, 07:59 PM   #10734
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,570
Wrapped up a small factory / warehouse upgrade from 400w metal halides to 165w LEDs.
Increased the facility's lighting levels by 77.8%, dropped 162 amps off the lighting panels and reduced the heat of the breakers an average of 22F.
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be.
480sparky is offline
The Following 10 Users Say Thank You to 480sparky For This Useful Post:
Calidecks (11-11-2018), Idothat (11-11-2018), Jaws (11-11-2018), KAP (11-11-2018), META (11-11-2018), overanalyze (11-11-2018), Stryker1-1 (11-11-2018), tgeb (11-11-2018), TheConstruct (11-11-2018), TxElectrician (11-17-2018)
Old 11-11-2018, 09:18 PM   #10735
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 628
That has to reduce the electric bill right? That's a big reduction.
overanalyze is online now
Xtrememtnbiker (11-11-2018)
Old 11-11-2018, 10:48 PM   #10736
GC/carpenter
Calidecks's Avatar
Rewards Points: 15,350
Love LED's.
Mike.
_______________
Calidecks is offline
Old 11-11-2018, 10:50 PM   #10737
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,702
What brand? I just installed a bunch, company called "Door Counts".
Inner10 is online now
Old 11-12-2018, 07:29 AM   #10738
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,274
More and more stores are trying to gather as much analytics on their customers as possible.[IMG]https://uploads.tapatalk-cdn.com/20181112/4353680156bf747abac26711f8134385.jpg[/I[IMG]https://uploads.tapatalk-cdn.com/20181112/b621335a1a4cece808338e568713593a.jpg[/I[IMG]https://uploads.tapatalk-cdn.com/20181112/b22b4734a603d5415116459bfba76927.jpg[/IM
Creepy ass motherfvckers. Maybe they should work on improving their service instead of spying on their customers.
Big Johnson is online now
Old 11-12-2018, 05:39 PM   #10739
Box Builder
Just finished putting the treads down on these stairs. Now we continue wading ahead with the rest of the railings etc. boral risers, skirts, posts and locust for all the wood.
The Following 5 Users Say Thank You to Morning Wood For This Useful Post:
asevereid (11-12-2018), Calidecks (11-13-2018), hdavis (11-12-2018), Idothat (11-13-2018), KAP (11-12-2018)
Old 11-12-2018, 06:24 PM   #10740
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 6,288
Highest grossing day possibly ever for me. 830-230.
NYgutterguy is online now
The Following 8 Users Say Thank You to NYgutterguy For This Useful Post:
asevereid (11-12-2018), Calidecks (11-13-2018), Idothat (11-13-2018), KAP (11-12-2018), META (11-12-2018), overanalyze (11-13-2018), tgeb (11-12-2018), Xtrememtnbiker (11-12-2018)
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
