Post A Picture Of Your Current Job -- Part II - Page 372 - General Discussion - Contractor Talk
Old 03-03-2017, 08:39 PM   #7421
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
Re: Post A Picture Of Your Current Job -- Part II
Try again, done
Post A Picture Of Your Current Job -- Part II-1488591414763.jpg   Post A Picture Of Your Current Job -- Part II-1488591493725.jpg   Post A Picture Of Your Current Job -- Part II-1488591532258.jpg
Aaron Berk is offline
The Following 6 Users Say Thank You to Aaron Berk For This Useful Post:
Calidecks (03-06-2017), DaVinciRemodel (03-07-2017), EricBrancard (03-08-2017), illbuildit.dd (03-14-2017), NJGC (03-03-2017), Xtrememtnbiker (03-04-2017)
Old 03-03-2017, 09:08 PM   #7422
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,235
It's been painted. Paint has a green hue in my spray room but looks like BM Swan White in LED and Sunlight, which is the primary light sources in the house.
Got my router bit and hinges and the mirror frames will work as they are. To bad I have to prime and paint them now.
And the claw feet
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
The Following 5 Users Say Thank You to Leo G For This Useful Post:
Calidecks (03-06-2017), EricBrancard (03-08-2017), illbuildit.dd (03-14-2017), overanalyze (03-03-2017), Xtrememtnbiker (03-04-2017)
Old 03-06-2017, 09:10 PM   #7423
LRG WoodCrafting
Leo G's Avatar
Got the lower cabinet put together. Drawer slides, drawer fronts, made the back and clear coated it. Needs to be attached.
Here's the upper painted. I put the back on it and the doors. No pics of it put together.
Here's one of the two Walnut counters. Stained it with a 1/2 strength American Walnut and 3 coats of 2K sealer to fill the grain and 1 coat of 2K polyurethane.
They sold me a slow close mechanism, but the mount wouldn't work with the inset door. So I pulled apart one of my face frame adapter plates and replaced the original plate with the plastic plate used to mount the slow close device. Worked out really well and looks good with all metal.
Tomorrow it all goes into the house.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
The Following 6 Users Say Thank You to Leo G For This Useful Post:
Calidecks (03-06-2017), DaVinciRemodel (03-07-2017), EricBrancard (03-08-2017), overanalyze (03-06-2017), Philament (03-13-2017), Xtrememtnbiker (03-07-2017)
Old 03-07-2017, 09:06 AM   #7424
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,794
Barn is older than me x2. Client didnt want any new steel other than what is going on the door this week and covering the track. Door measures 14'L x 10'H
CharlieDelta is offline
Old 03-07-2017, 06:56 PM   #7425
LRG WoodCrafting
Leo G's Avatar
Originally Posted by KAP View Post
Thought you meant installed it at the customers house... what the heck is taking you so long?...
Vanity is installed. Lights, outlets and the sink/faucet need to be installed. The upper doors will have mirrors and the center open shelf will have three 3/8" glass shelves and a light above.
The electricians screwed up the placement of the upper wires. It was suppose to be 27" (left & right) off center of the cabinet. They did it off the center of the wall which pushed the wires 8" to the right. The left hole was buried under the cabinet, the right hole was outside the cabinet. Nice that the sheetrockers were there to patch it up nice.
I screwed up on the height of the cabinet to line up with the plumbing by 1/4". My cabinet was to tall. Simple fix, open the sheetrock a bit and unscrew 3 screws and move the plumbing up 1/4".
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
EricBrancard (03-08-2017), KAP (03-07-2017), SmallTownGuy (03-08-2017), TEnglish14 (03-10-2017), Xtrememtnbiker (03-07-2017)
Old 03-07-2017, 08:30 PM   #7426
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 678
No reflection on your work Leo, but that is one stoopid looking sink.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Morning Wood (03-08-2017), TimelessQuality (03-08-2017), TxElectrician (03-08-2017)
Old 03-07-2017, 08:32 PM   #7427
LRG WoodCrafting
Leo G's Avatar
Says right in the instructions it's not designed to be used in a countertop. It is suppose to be hung from a wall bracket.
Since I've been dealing with it for a while now, it's grown on me.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-08-2017, 07:56 AM   #7428
Box Builder
Morning Wood's Avatar
Rewards Points: 10,346
Is it just rough casting on the underside? I have to agree, it is odd they chose that style. Did you have to set it in caulking around your cabinet to protect the wood from water
Morning Wood is offline
Old 03-08-2017, 08:00 AM   #7429
LRG WoodCrafting
Leo G's Avatar
It'll have be set in bright white silicone after the plumber gets things setup. Right now its just trapped in place. At 100 lbs it won't move much anyway.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-08-2017, 08:03 AM   #7430
LRG WoodCrafting
Leo G's Avatar
It's not a raw casting. It has a black coating on it. It's designed to be exposed.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-08-2017, 12:29 PM   #7431
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
I was thinking the exact same thing his work looks amazing the cabinet itself looks stupid
Sent from my XP7700 using Tapatalk
SectorSecurity is offline
Old 03-08-2017, 12:30 PM   #7432
13 HP servers bought at government auction for 800$
Will likely hold on to a few of them for personal use and will sell the others.
Old 03-08-2017, 02:46 PM   #7433
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Simple vinyl plank floor, but first time I used a multiple width product... It's a step up from the standard look imo.
-Steve
TimelessQuality is offline
The Following 6 Users Say Thank You to TimelessQuality For This Useful Post:
Calidecks (03-08-2017), DaVinciRemodel (03-08-2017), hdavis (03-09-2017), illbuildit.dd (03-15-2017), overanalyze (03-08-2017), Philament (03-13-2017)
Old 03-13-2017, 08:07 PM   #7434
LRG WoodCrafting
Leo G's Avatar
The electrician came by last Friday. The plumber was here today. Had to help him take the sink in and out a few times. Had to protect my countertops.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
The Following 3 Users Say Thank You to Leo G For This Useful Post:
asevereid (03-14-2017), illbuildit.dd (03-14-2017), KAP (03-13-2017)
Old 03-13-2017, 08:10 PM   #7435
LRG WoodCrafting
Leo G's Avatar
Made some beaded tongue and groove, 6" and 4". Sanded, sealed the rear, primed the front in a goldish color and delivered it last Friday. Got the beaded wainscot installed today.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Big Shoe (03-14-2017)
Old 03-13-2017, 11:37 PM   #7436
KAP's Avatar
Trade: Custom
Rewards Points: 37,976
Sorry... you only get one "thanks" even if you post the same thing twice...
KAP is offline
Old 03-14-2017, 01:00 AM   #7437
Frank Castle's Avatar
Rewards Points: 532
Client liked the bedroom floor I did for them a few months back. They are doing the rest of the basement in an acid stain. Finished up the game room half and a little side room. Still working the rest. These pictures don't do it justice.
Turned out real nice. People are very happy.
Post A Picture Of Your Current Job -- Part II-game-room-3-finished-combos.jpg   Post A Picture Of Your Current Job -- Part II-game-room-5-finished-combos.jpg   Post A Picture Of Your Current Job -- Part II-game-room-pole-detail-finish-2.r.jpg   Post A Picture Of Your Current Job -- Part II-side-room-finish.cr.jpg   Post A Picture Of Your Current Job -- Part II-game-romm-4-finish.cr.jpg
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following 16 Users Say Thank You to Frank Castle For This Useful Post:
asevereid (03-14-2017), blacktop (03-14-2017), Calidecks (03-14-2017), DaVinciRemodel (03-14-2017), Deckhead (03-14-2017), hdavis (03-14-2017), illbuildit.dd (03-14-2017), KAP (03-14-2017), overanalyze (03-14-2017), Philament (03-14-2017), Resta (03-14-2017), Robie (03-14-2017), tgeb (03-14-2017), TimelessQuality (03-16-2017), TxElectrician (03-15-2017), Xtrememtnbiker (03-14-2017)
Old 03-14-2017, 10:24 AM   #7438
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,272
That floor looks great!
overanalyze is online now
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Deckhead (03-14-2017), Frank Castle (03-14-2017)
Old 03-14-2017, 08:53 PM   #7439
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 5,410
That's something you don't see every day. Looks awesome.
It'd be cool to know how to do it.
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is online now
The Following User Says Thank You to Deckhead For This Useful Post:
Old 03-14-2017, 11:18 PM   #7440
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
I've done a lot in this house (made all alder door jambs from scratch , hung lots of beams and beam grids, bla bla bla) but this was my first time to make 6" wide corbels on the band saw. They actually turned out great. Can't wait to finish this one. Especially since it's an hour away.
Post A Picture Of Your Current Job -- Part II-kimg0769.jpg   Post A Picture Of Your Current Job -- Part II-kimg0770.jpg   Post A Picture Of Your Current Job -- Part II-kimg0773.jpg
illbuildit.dd is offline
The Following 2 Users Say Thank You to illbuildit.dd For This Useful Post:
blacktop (03-15-2017), TimelessQuality (03-16-2017)
Post a Picture of your Shop Deadhead Derek General Discussion 213 04-30-2014 10:52 PM
Local Market Online Domination Part One - Claim Your Local Listing kcremodeler Marketing & Sales 10 11-20-2009 12:24 PM
Picture post??? Kim1181 Flooring 2 03-09-2004 04:10 PM
