Possible Pipeline Rupture - General Discussion - Contractor Talk
Old 12-12-2019, 01:38 AM   #1
Dale Kennedy's Avatar
Trade: pipe fitter journeyman
I've worked in the oil and gas industry since 2002.
I've discovered a pipeline that I believe will rupture due to inadequate stucture of management in regards to protecting personal. This led to the design and fabrication of the pipeline having faults. Mainly the welding of said fabricated pipeline.
This pipeline is in a large LNG plant.
I would require proof of a design error before submitting it to the proper means of dealing with this error.
Especially because my life will generally be effected. As well as those of friends and their families.
If I'm wrong, it's on me for causing a stir. ****, one has to ask right ? and I've asked before to no avail.
thanks
Dale Kennedy
Dale Kennedy is offline
Old 12-12-2019, 08:34 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,803
Re: Possible Pipeline Rupture
I Know a guy who's involved with designing cogen plants. Shall I inquire on your behalf?
MarkJames is online now
Old 12-12-2019, 09:58 AM   #3
rustyjames's Avatar
Rewards Points: 1,774
I'm not a pipeline engineer but that's a saddle supporting the pipe, not for connecting two sections of pipe. The wall thickness of the pipe is really that thick?
rustyjames is online now
The Following User Says Thank You to rustyjames For This Useful Post:
TheConstruct (12-12-2019)
Old 12-12-2019, 05:13 PM   #4
TimNJ's Avatar
Rewards Points: 5,648
What are you asking?
Considering filing as a "whistleblower"?
TimNJ is offline
Old 12-12-2019, 05:45 PM   #5
yeah sure, that would be great.
Old 12-12-2019, 05:50 PM   #6
hey hi, yes the saddle is a support. it for some reason had the design modified during construction and is welded all the way around. yes it's about 59mm thick.
Old 12-12-2019, 05:52 PM   #7
or....... BBQ ??
The Following User Says Thank You to Dale Kennedy For This Useful Post:
Mordekyle (12-14-2019)
Old 12-12-2019, 05:53 PM   #8
or....... BBQ ??
im asking if the line is going to rupture in the future. it's in operation now.
Old 12-12-2019, 05:54 PM   #9
Old 12-12-2019, 06:12 PM   #10
Old 12-12-2019, 06:38 PM   #11
Mike-B's Avatar
Rewards Points: 1,074
I don't quite understand what your trying to say.
If you question the safety of the pipeline due to design issues, speak to the EOR.
If you question the safety due to the welding, ask the CWI that inspects the work there and see what they say.
If this is a legit pipeline install I would assume the work was engineered and inspected. It would make sense to ask those involved.
Sent from my SM-G970U using Tapatalk
Mike-B is offline
Old 12-12-2019, 07:10 PM   #12
TimNJ's Avatar
They are putting in a pipeline near me right now.
One day driving by and stuck in traffic since one lane was closed, I looked at the pipe.
EVERY single joint had the date, exact time, who welded it, and who inspected it written on the joint.
Pretty good accountability I thought as I was sitting there.
But then I thought, well if it blew, I don't think you'll be able to read who welded and inspected that joint.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
Old 12-12-2019, 07:18 PM   #13
rustyjames's Avatar
All I can say is that I've never seen pipe wall that's almost 2.5" thick . That would take a zillion passes to fill that v groove. What's the diameter of the pipe?
Rio (12-18-2019)
Old 12-12-2019, 10:59 PM   #14
really ? I've put together heaps of it. yeah I just stick it together mostly then the welders come along. all stick.
Old 12-12-2019, 11:02 PM   #15
hey, yeah basically I just want to verify if there is a design error before I do that.
Old 12-12-2019, 11:03 PM   #16
All I can say is that I've never seen pipe wall that's almost 2.5" thick <img src="http://img.contractortalk.com/smilies/eek.gif" border="0" alt="" title="Eek" class="inlineimg" />. That would take a zillion passes to fill that v groove. What's the diameter of the pipe?
really ? I've put together heaps of it. yeah I just stick it together mostly then the welders come along. all stick fill.
Old 12-13-2019, 04:11 PM   #17
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,272
So you think asking on an internet forum people you have never met is your best first approach? I'd think taking this right to the people who count is where you need to go. If they are a legitimate company, they will be happy to address a problem before it erupts into something catastrophic.
Mike.
_______________
Calidecks is online now
Old 12-13-2019, 05:34 PM   #18
rrk's Avatar
Rewards Points: 3,296
the pipeline near where I live has xrays of all welds and the trench was 20ft deep or more
rrk is online now
Old 12-13-2019, 06:32 PM   #19
TheConstruct's Avatar
Rewards Points: 1,384
You're going to feel pretty silly if it does blow and you could have saved the town...
Why not just mention it?
TheConstruct is offline
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
Calidecks (12-13-2019), Justin Rhoades (12-15-2019)
Old 12-13-2019, 10:29 PM   #20
Mike.
_______________
yeah na na na, what I was trying to is verify my information before I do that.
