Portable Job Site Heat - General Discussion - Contractor Talk
Old 12-08-2016, 03:59 PM   #1
Finelli, A's Avatar
Rewards Points: 30
I will be starting a renovation here in upstate ny in January. I'd like to get my guys and I some portable heat to help keep the chill out of the air and hopefully allow us to not have to work in huge carhartt jackets. I was thinking a propane convection heater 50/60/80k btu in the middle of the room would help a lot but I was wondering what you all use and recommend. I'd rather stay away from kerosene but if it's cheaper to run than propane I'd go with it. Any advice is greatly appreciated!
Sent from my SM-G900V using Tapatalk
Finelli, A is offline
Old 12-08-2016, 04:59 PM   #2
hdavis's Avatar
Rewards Points: 2,000
Re: Portable Job Site Heat
I prefer electric, if possible. Kerosene next, due to cost. Propane last.
Kerosene and propane put a lot of moisture into the air, so all the wood is a little wet - it's a good setup for nail pops, trim gaps, etc.
hdavis is online now
brhokel606 (12-11-2016), overanalyze (12-08-2016)
Old 12-08-2016, 05:03 PM   #3
Finelli, A's Avatar
Rewards Points: 30
Just looking for something to get me through until hvac is in, then I'll have that for all the finish work
Old 12-08-2016, 05:09 PM   #4
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
I did these renovations for 10 years. The furnace guy was always the last one to show up . Makes sense you wouldn't want all that construction dust getting sucked into a new system. No matter what you do certain areas are going to stay cold...you won't notice it while your're working ....it shows up years later as arthritis
Irishslave is offline
Old 12-08-2016, 06:32 PM   #5
fjn's Avatar
Trade: mason
Rewards Points: 11,202
IMHO,electric is the only way to go.No nauseating headache producing fumes,no tanks to monitor and fill. Not to mention,the fuels dump many pounds of water into the job site,while one is trying to dry stuff out and acclimatize the place for trim. Also,the fuels are a huge no no for the placement of fresh concrete,effects it adversely.
fjn is offline
brickhook (12-08-2016)
Old 12-08-2016, 08:00 PM   #6
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
We've always used kerosene space heaters in our "gas chambers" ....wouldnt recommend it to anyone.
brickhook is offline
Old 12-08-2016, 08:05 PM   #7
brickhook's Avatar
Trade: masonry
I never knew there would be a problem with concrete slabs and kerosene heaters til last year (seems I'm always last to arrive to the party "
What does it do?
The owner at the concrete plant was telling me horror stories about this last year...but he never explained why.
Old 12-08-2016, 09:15 PM   #8
dayexco's Avatar
Rewards Points: 766
40 years ago when first married, in winter months i tended for a masonry crew. they always ran propane fired heaters in the shelters.
they always said kerosene was a no no
dayexco is online now
Old 12-08-2016, 11:34 PM   #9
Part-Time Wannabe
atypicaltexan's Avatar
Trade: Part-Time Carpentry, AV/Low Voltage Install
Rewards Points: 96
Originally Posted by brickhook View Post
What does it do?
I'm guessing it affects the compressive strength or the curing, but I don't know.
These guys below poured kerosene in the sand, then mixed the concrete. Not sure what happens when you spill it on fresh concrete that is already set.
https://www.researchgate.net/publica...ure_conditions
atypicaltexan is offline
Old 12-09-2016, 01:27 AM   #10
Bull Trout's Avatar
Rewards Points: 134
indirect fired heater ducted into the house
Bull Trout is offline
Old 12-09-2016, 06:41 AM   #11
builditguy's Avatar
Rewards Points: 2,136
If you can go electric, do that. Propane dumps a ton of moisture into the house. Kerosene has an odor that makes me sick.
I have seen a few guys use an old furnace and temporarily hook it up. I just don't have an old furnace to use.
builditguy is offline
Old 12-09-2016, 08:24 AM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
If it isn't an exhausted kerosene heater I feel like hurling by lunch.
It's SOP here to get the furnace online right away during the winter months, we need something to keep the footers warm and then heat the house for drywall. Before the house changes hands a duct cleaning company comes in and blows out the dust.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Finelli, A (12-09-2016), hdavis (12-09-2016)
Old 12-09-2016, 01:35 PM   #13
MonsieurBon's Avatar
Trade: Framing and finish carpentry
Rewards Points: 200
When I was in Japan years ago everyone used kerosene heaters indoors and would just open a window once everyone started getting woozy.
It doesn't get super cold here in the PacNW but I see a lot of towable external heating units ducted into commercial job sites.
We used some propane heaters in a few houses that had been framed really slowly in constant rain on a slab. The supervisor said even with the moisture from the heater, we were drying things out.
Sent from my Moto G (4) using Tapatalk
MonsieurBon is offline
Old 12-09-2016, 06:45 PM   #14
fjn's Avatar
Trade: mason
What does it do?
John; The carbon dioxide will combine with the calcium carbonate on the surface.When this occurs,the floor surface will dust under traffic.For this reason,the carbon dioxide producing heaters should not be used near fresh concrete.
fjn is offline
The Following 5 Users Say Thank You to fjn For This Useful Post:
atypicaltexan (12-10-2016), brhokel606 (12-11-2016), brickhook (12-09-2016), hdavis (12-10-2016), Sisyphus (12-25-2016)
Old 12-13-2016, 07:06 PM   #15
madmax718's Avatar
Trade: General
Rewards Points: 3,276
as inefficient as it may sound, a big generator with portable heaters run through extension cords if you dont have on site power. A tad bit on the noisy side of course, but you dont have fumes running into the home. 1500 watts is generally adequate for warming up 300 sq feet. A medium duty 3500 watt would be adequate to heat up a two rooms, 3 if you only operate them on low.
madmax718 is offline
Old 12-14-2016, 06:43 PM   #16
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Rewards Points: 1,028
GC put these on each floor. It got worm within the space of an hour. In two hours we took jackets off.
Portable job site heat-2016-12-14-12.13.33.jpg   Portable job site heat-2016-12-14-12.14.44.jpg
Resta is offline
The Following 3 Users Say Thank You to Resta For This Useful Post:
blacktop (12-14-2016), fjn (12-14-2016), john5mt (12-25-2016)
Old 12-14-2016, 07:25 PM   #17
fjn's Avatar
Trade: mason
Now your talking,no noxious fumes to contend with. Also,an added advantage of electric heat, most of the time the electric bill is in the property owners name,no money to dispute over.
fjn is offline
Old 12-14-2016, 07:48 PM   #18
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 358
There's a common sense practice to taking care of a heat pump during construction on a new home.
BUT! Common sense Is a rare thing these days! And that's why the HAVC Guys won't Warrant the system being run during construction .
Everyone wants to blame It on the drywall dust .. I've always shut the heat off during sanding ..Then cut It back on after the house was shop vac and completed . [common sense] But the biggest culprit! winter or summer is the floor sanders ! Any Central air guy will tell you that !
blacktop is offline
Old 12-25-2016, 10:02 PM   #19
RedAdobe's Avatar
Trade: Sparks
Rewards Points: 138
I found that a kerosene heater using new ultra low sulfer diesel with about a 10% mix of 90+ % Isopropal alcohol added burns clean and not near as many headaches as kerosene....cheaper too. less then 1/2 the $
However electric is the way to go if you can but sometimes its not feasable
RedAdobe is offline
Old 12-25-2016, 11:31 PM   #20
john5mt's Avatar
Rewards Points: 1,500
Double post delete
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Tile Heat shield redwood Tiling 16 10-23-2012 08:54 PM
Adding blog to web site gastek Websites and SEO 4 03-08-2012 05:59 PM
It's getting hot out there, people......... 480sparky Health & Safety 9 07-11-2010 07:23 PM
