Pocket Door - General Discussion - Contractor Talk
Pocket Door
Old 03-29-2012, 06:01 PM   #1
Diablo View's Avatar
Rewards Points: 75
Pocket Door
So I am talking to a door supplier who says he can change out the track for a pocket door without opening up the sheet rock.
He says he came up with a tool to do this and no he won't tell me what it is.
I usually leave existing track and just replace hardware if the track isn't jacked up.
Any ideas on how it can be done?
Diablo View is offline
Old 03-29-2012, 06:03 PM   #2
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: Pocket Door
A very long right angled screwdriver. With a light on it.
katoman is offline
Old 03-29-2012, 06:04 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 182
Re: Pocket Door
Crow bar?
Warren is online now
Old 03-29-2012, 06:15 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,024
Re: Pocket Door
http://pocketdoorrepair.com/
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Hmbldr (03-29-2012), TNTRenovate (03-30-2012)
Old 03-29-2012, 06:19 PM   #5
Hmbldr's Avatar
Trade: Residential contractor
Rewards Points: 150
Re: Pocket Door
Well, I guess this is really 2 questions... how to get the old one out, then how to attach the new one. Getting the old one out (without ruining the wall) would seem to remove what you can and then prying/ripping out the track (just the track) I would loom towards an upgraded new track, like Hafele, for the new install. Something that might work with only and ent mount install in side the wall, so it could be done with just along driver attachment. Hafele makes some nice hardware rated for very heavy door. Should work easily for a standard door.
As for the salesman not giving up his secret might just cost him the sale. Annoying
Hmbldr is offline
Old 03-29-2012, 06:30 PM   #6
jb4211's Avatar
Rewards Points: 2,306
Re: Pocket Door
It can't be done properly/correctly. As much as some things are a PITA, there just isn't a short cut to certain things.
Just my opinion. I've been wrong before.
But taking short-cuts usually results in regrets, followed by doing the repair the right way to correct the repeated failure.
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
olligator (03-30-2012)
Old 03-29-2012, 06:35 PM   #7
Gary H's Avatar
Rewards Points: 2,342
Re: Pocket Door
JLC mag had a story on how to do it without cutting the sheetrock. I will see if I can find it.
Gary H is offline
Old 03-29-2012, 11:40 PM   #8
Rewards Points: 75
Re: Pocket Door
In my post I stated he has a tool to do this with.How is that a short cut?
Old 03-29-2012, 11:57 PM   #9
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,248
Re: Pocket Door
Not that I can think of. It certainly can't be done on any the pocket doors I've installed. Assuming you are talking about removing the entire track assembly, and not just the hardware.
Old 03-30-2012, 05:22 AM   #10
jb4211's Avatar
Re: Pocket Door
IMO, I used the term "short-cut" because I don't think it's possible to replace the track properly without exposing the track.
But, after considering what Kato suggested, it may be possible. Difficult, seems like a short-cut, but possible. However, I think you'd need a angled screw driver, light and camera.
Jon
jb4211 is offline
Old 03-30-2012, 05:49 AM   #11
Hmbldr's Avatar
Rewards Points: 150
Re: Pocket Door
Along the lines of what I suggested and if you check out Griz' posted link, precisely that..... a tool to remove the screws and a new track that attaches to the wall in side the pocket.
I think we all take 'short cuts' in that we all use the best tools and adaptive methods to make our jobs easier and better. A router is not a 'short cut' to hand plane molding profils. It's just better and makes more sense and is 1000 faster. Power this and cordless that, shortcuts we take for granted. Using this pocket tool is a lot better and faster than having to rip out the wall and all the steps nad time to repair.
Yep, there's a tool for that.
Hmbldr is offline
The Following 2 Users Say Thank You to Hmbldr For This Useful Post:
Diablo View (03-30-2012), TNTRenovate (03-30-2012)
Old 03-30-2012, 07:54 AM   #12
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
Re: Pocket Door
If it is an old door with slotted screws, forget it.
Steve
stp57 is offline
Old 03-30-2012, 08:25 AM   #13
mbobbish734's Avatar
Trade: Property Preservation & Remodeling
Re: Pocket Door
Steve
Gotta love those slotted screws
mbobbish734 is offline
Old 03-30-2012, 09:03 AM   #14
Gary H's Avatar
Re: Pocket Door
Slotted screw? Those must have been before my time.
Gary H is offline
Old 03-30-2012, 09:12 AM   #15
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Re: Pocket Door
I hate slotted screws, but philips aren't much better. A screw that is designed to cam out is begging for disaster. That being said, I think that Griz's site looks like your best shot.
Good luck!
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 03-30-2012, 04:30 PM   #16
cairnstone's Avatar
Trade: maintenance carpenter
Rewards Points: 167
Re: Pocket Door
I have done a couple by prying the old pressed steel track out using a prybar. The new thrack and hardware is from kristrack and it is heavier duty Aluminium. I an install all but the lasst screw. I use lagers screws than the original did and so far none have failed. Trick is a right angle drill andlong extensions and patience
cairnstone is offline
Entry Pocket Door stp57 Windows, Siding and Doors 41 01-04-2011 06:43 PM
Pseudo-Elliptical Pocket Door in Arch basswood Finish Carpentry 22 03-15-2010 08:20 AM
Glass Shower Pocket Door or Outside Mount Door AboveAndBeyond Remodeling 6 04-02-2009 11:05 AM
Door install hell - customer angry HellisLikeNewrk General Discussion 17 06-04-2008 09:40 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
