Painting Pole Barn Slider Door Rails - General Discussion - Contractor Talk
Old 01-09-2019, 02:50 PM   #1
hoef17's Avatar
Trade: Carpenter/Builder and H.S. Constr. Trades Teacher
Rewards Points: 18
1st time user, long time forum fan, Hello all.
I am a builder and a H.S. Construction Trades Teacher in which we build Pole Barns with the students.
My question to you all is:
Has anyone had success in painting the white aluminum slider door rails that come already primed, ( I think that is primer??).
I have done some research on painting aluminum but it depends on who is answering to the tips you get.
We have tried different methods to paint these to match the trim of the barn and have not been happy with how scratch resistant they are. And I mean, just brush up against it and it looks like crap.
In the past we have scuffed the white paint or primer, then used our own aluminum etching primer, and then 2-3 thin coats of spray paint.
Anyone out there have advice to what we are doing wrong.
Maybe the better question is....where can I buy painted door rails? Our suppliers say they can only get white.
Thanks for considering my post and appreciate any answers y'all have.
hoef17 is offline
Old 01-09-2019, 03:16 PM   #2
avenge's Avatar
Rewards Points: 454
Re: Painting Pole Barn Slider Door Rails
You're spray painting with what? And what is it scratching down to?
avenge is online now
Old 01-09-2019, 03:25 PM   #3
hoef17's Avatar
Rewards Points: 18
I have used like a Rustoleum enamel spray paint can, and when it scratches .......I think it scratches back down basically to the white Primer/paint that was scuffed prior.
hoef17 is offline
Old 01-09-2019, 03:39 PM   #4
Ed Hartmann's Avatar
Rewards Points: 184
I have used a product Will-Bond as a deglosser and painted with Maxbond by Dutchboy. I don't typically paint with Dutchboy but I really like Maxbond for that type of application. I don't know how its different than other paint other than from experience and the smell.
Are you sure you cant just order the trim the color you want? Most steal suppliers will send you what ever you want factory painted.
Ed Hartmann is online now
Old 01-09-2019, 08:50 PM   #5
TimNJ's Avatar
Rewards Points: 3,998
I would talk to a body shop.
Since you want to paint aluminum, that's what Ford pickups are now.
TimNJ is offline
Old 01-09-2019, 10:26 PM   #6
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,668
Prime with SW Procryl and finish with sw Shercryl. You will be happy.
Ohio painter is offline
Old 01-09-2019, 11:34 PM   #7
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 2,436
Take them to get anodized.
Or prime with an epoxy primer and topcoat with a compatible epoxy paint.
This is my favorite epoxy primer. Stuff is almost bullet proof.
https://www.aircraftspruce.com/catal...akzoprimer.php
Big Johnson is online now
Old 01-10-2019, 07:35 AM   #8
builditguy's Avatar
Rewards Points: 984
You're in a different part of the country, but when you think about steel companies and their distribution networks, we aren't that far.
I don't think we are talking about the same parts.
I've never used any aluminum part on a pole barn. I've never seen a slider come in aluminum.
To me, a slider for a door would be the track that the door rollers sit in.
https://fabral.com/media/2237/slidingdoorheader.pdf
Those always come in galvanized steel.
Can you show what part you are taking about?
builditguy is online now
Old 01-10-2019, 07:39 AM   #9
hoef17's Avatar
Rewards Points: 18
Ed, I don't call the rails trim, but in my research around here...I cannot get slider door rails (that attach to the 2x and trims out the steel) in a specific color like I can with j channel, F, corners, etc. etc.
Ohio, what does the SW stand for? I am far from a painter of any kind.
Tim, Was hoping to avoid a body shop but it has been advised to me numerous times.
Costs too much $$
Thanks all for input, BUT one last question: Is the paint that comes on those rails primer or paint, and if I do use some of these primer products you speak of...do I sand off the entire white that comes on it to get back to square one with the aluminum?
Thanks again, have a good Thursday....still waiting for snow up here so we can work and play! Where is the winter???
hoef17 is offline
Old 01-10-2019, 07:44 AM   #10
builditguy's Avatar
Rewards Points: 984
Since I don't know how long before he logs in, I'll answer your question.
SW= Sherwin Williams.
Not to step on any toes.
The Following User Says Thank You to builditguy For This Useful Post:
Ohio painter (01-11-2019)
Old 01-10-2019, 07:46 AM   #11
builditguy's Avatar
Rewards Points: 984
https://fabral.com/media/3511/slidingdoorjamb.pdf
On this picture, are you talking about the "L" trim on the end of the door. This detail doesn't say what it's called, but you can see it on the end of the door.
Old 01-10-2019, 08:36 AM   #12
hoef17's Avatar
Rewards Points: 18
I talking about these. (attachments hopefully came thru??, still learning your site) I have only put on the top example of the Quick Rails in first attachment. All one piece, made of a strong about 1/8th aluminum. I thought everybody used these??
Painting Pole Barn Slider Door Rails-barn-sliding-door-rails.jpg   Painting Pole Barn Slider Door Rails-quick-rails.jpg
hoef17 is offline
Old 01-10-2019, 08:47 AM   #13
Costs too much $$
You’ll want to remove the old primer first. Use an acid etch/nitric acid solution just prior to priming.
You could also try this:
https://www.aircraftspruce.com/catalog/cspages/zinc.php
hoef17 (01-10-2019)
Old 01-10-2019, 09:00 AM   #14
Costs too much $$
There’s an aircraft charter school based at KGRR, if you’re doing this for a school project an instructor there might give you some products to try out. Give them a call.
West Michigan Aviation Academy
Public Charter High School
Gerald R Ford International Arpt
5363 44th St SE
Grand Rapids, MI 49512
Phone: (616) 446-8886
Fax: (616) 957-0491
Website: www.westmichiganaviation.org
Email: [email protected]
Old 01-10-2019, 09:06 AM   #15
hoef17's Avatar
Rewards Points: 18
Yep, I know who you are talking about....we share ISD meetings for articulation for CTE....wish I would have thought about that a couple weeks ago when we were sitting at the same table. Thanks
hoef17 is offline
Old 01-10-2019, 09:08 AM   #16
builditguy's Avatar
Rewards Points: 984
They are aluminum. Different areas get slightly different building details. Around here, nobody would combine steel and aluminum on a pole barn. It's just not done.
I was thinking about it. The last pole barn I did was 27 years ago. I'm sure some things have changed.
As far as the paint goes, in steel, they make everything in all of their standard colors. Not sure why they would do aluminum any different.
And as far as painting, cleaning, a light sanding, primer, and finish coat should be doing the trick. That's what we would do.
I don't think I can help you.
Old 01-10-2019, 09:25 AM   #17
hoef17's Avatar
Rewards Points: 18
I know what you are talking about on the Steel touching Aluminum and I bet there are guys on here that could give a lot of different opinions on that...or maybe there is a thread on here that has already addressed that.
Around here, we have F channel touching steel siding, and other applications like that and due to it all being painted, we just do it and in the 50 yrs. some of my veteran mentor builders have had zero corrosion.
Unlike when guys would wrap pressure treated green exterior lumber with painted coil stock aluminum flashing and watch it eat it away in two years! Just haven't seen that happen with aluminum trim and steel siding /roofing.
Opinions?
Question: what product do people use as rails for this type of door if they don't use the rails I am referring to? I assume it is made of steel and can be painted? and then put steel J channel to finish as a separate piece?
hoef17 is offline
Old 01-10-2019, 09:52 AM   #18
Rewards Points: 184
I don't know how close you are to a Menders but you can get those rails in a lot of colors ordering off there site.
https://www.menards.com/main/buildin...283696&ipos=15
Old 01-10-2019, 12:08 PM   #19
hoef17's Avatar
Rewards Points: 18
Thanks Ed, didn't know that and I just checked it out....however of course they don't have the black color we need. They have midnight grey that may be good enough but I doubt it.
I notice there product is aluminium....so now we go back to the debate (or maybe there shouldn't be a debate) on whether you should be putting metal siding in those Aluminum rails??
Now let me throw a whole new pitch into this at bat....I just talked to my Local supplier and they now do not carry aluminum Rails, they carry powder coated steel rails. They just switched and they did so in part to hearing people have concern (me being one of those peeps) not wanting the aluminum and for painting difficulties. But they still come as an off white only and I looked it up...it is not a primer but a powder coat paint.
My question now becomes....What should I use for paint in this application and should I scuff and paint, scuff, prime, then paint?
hoef17 is offline
Old 01-10-2019, 12:36 PM   #20
Rewards Points: 184
Those aluminum rails are designed to be used on steel pole barns. No issue there. I would just get a factory color that looks ok with the building even if not the same color. Its mostly covered. Its similar to a garage door weather strip that is some times a bit off. Stripping and painting trim is overkill for the situation.
looking for info on pole barn truss jacks D & H Tools & Equipment 1 03-08-2014 07:26 PM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 07:44 PM
pole barn question bigz Carpentry 7 04-10-2012 11:22 PM
Pole Barn RandyB1986 Framing 8 03-04-2012 10:33 PM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 10:39 PM
