Painting New W/r/ Cedar Shingles - General Discussion - Contractor Talk
Old 06-22-2020, 03:28 PM   #1
Goodstuff283's Avatar
Trade: paint
Rewards Points: 2
I am painting an existing 3 story home. Two sides have new w/r cedar shingles which have been up for 2 months. I have heard that because of the sun rays they need to be sanded before I wash,prime and top coat.as for sanding I can't imagine sanding that much area plus three stories up. is there a wash I can use or is sanding an overkill?
Goodstuff283 is offline
Old 06-22-2020, 03:37 PM   #2
Kingcarpenter1's Avatar
Trade: GC carpenter
Rewards Points: 8
Re: Painting New W/r/ Cedar Shingles
Wash it with a product called Jomax available @ Cheapo’s or any hardware. Use a good primer as that will be the key to your paint job. Use Sherwin Williams 2 coats & sleep well
Kingcarpenter1 is offline
The Following User Says Thank You to Kingcarpenter1 For This Useful Post:
Goodstuff283 (06-23-2020)
Old 06-22-2020, 04:18 PM   #3
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
If the wood has weathered and started to turn grey , it should be sanded to expose fresh wood .
An alternative is to use a deck brightener , or similar product , following the manufacturer痴 directions
A pressure washer could be used as well , using a 15 or 25 degree tip to remove the weathered surface . Not recommended if you are not familiar with the process as a pressure washer can cause a lot of damage in the wrong hands
Fresh clean wood will hold paint much better than grey weathered wood
Molon Labe 覧 King Leonidas of Sparta
Freedom of choice is what you got
Freedom from choice is what you want覧 Devo
Idothat is offline
The Following User Says Thank You to Idothat For This Useful Post:
Goodstuff283 (06-26-2020)
Old 06-22-2020, 04:25 PM   #4
Trade: GC carpenter
Rewards Points: 8
Wash it with Jomax prime with Glidden Gripper & it will take a dozer to pull it off. Done deal
Old 06-22-2020, 04:28 PM   #5
Trade: GC carpenter
Rewards Points: 8
Oh yea and a couple of coats of S.W.
Old 06-22-2020, 04:31 PM   #6
Trade: GC carpenter
Rewards Points: 8
Why would you use a “ deck brightener” if your going to paint it...
Old 06-22-2020, 05:54 PM   #7
Idothat's Avatar
To remove the grey weathered surface .
Weathered grey wood will not hold paint as well as clean fresh wood
Idothat is offline
Old 06-22-2020, 06:33 PM   #8
Trade: GC carpenter
Rewards Points: 8
Cedar is going to soak paint in like a sponge in case you have never painted cedar not to mention if it’s only 2 months old
Old 06-22-2020, 07:32 PM   #9
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Wtf for not putting up prefinished shingles.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Old 06-22-2020, 07:37 PM   #10
Idothat's Avatar
[quote=Kingcarpenter1;7794031]Cedar is going to soak paint in like a sponge in case you have never painted cedar not to mention if it痴 only 2 months old[
The op asked a specific question , I gave a specific answer
__________________________________________________ ________
Cedar
It is recommended that you paint within two weeks of installing the cedar. Make sure that you wait no more than 12 weeks.
Allowing fresh siding to weather for as little as two weeks negatively affects coating adhesion. Test results from the Forest Products Testing Lab (run by the USDA for the Forest Service), show that after 12 weeks of exposure to sunlight, cedar siding has lost half of its ability to hold a film-forming coating system like primer and paint.
https://www.thespruce.com/painting-c...-guide-4125927
Idothat is offline
