Osb Vs Plywood In Shearwalls - Page 3 - General Discussion - Contractor Talk
Old 12-19-2018, 07:10 PM   #41
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 3,908
Re: Osb Vs Plywood In Shearwalls
I'm really worrisome about OSB. It might be rated for whatever but in all the hurricane aftermath I've ever been to, the OSB always fails more often. Could be that siding gets torn off and then you got exposed OSB getting pelted with hours of wind and rain and gradually weakens it.
For what it's worth, they are spec'ing it all over the place here now. Everything is going back to OSB. Crazy world we live in. For about 10-15 years while I was framing OSB was a HUGE no-no in v-zones. Now it's commonplace again.
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is offline
Old 12-20-2018, 06:45 PM   #42
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,411
Is a New Toyota or Honda worth more then a Kia that is 15000$ cheaper?
In ten or eight years of salty roads it will obvious...
Eventually MOST home have water leaks from plumbing, fire sprinklers, roofs, storms, snow and ice, and criminal acts. OSB will generally have to be torn out to stud level...
If you are building throw away homes, OSB is the way. IMHO
Even the best wood sheathing can't compete with average masonry rain walls...
Join Us, on the dry side
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
superseal (12-20-2018)
Old 12-20-2018, 06:52 PM   #43
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 958
Hogwash
Big Johnson is offline
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
Calidecks (12-20-2018), Dirtywhiteboy (12-20-2018)
Old 12-20-2018, 08:09 PM   #44
diplomat
Golden view's Avatar
Rewards Points: 742
All this time I've been thinking interior shear walls. Around here if someone says shear wall, they mean inside. Outside it's a given that it's a shear wall. Today I saw OSB for less than 1/3 the cost of ply.
Golden view is offline
SmallTownGuy (12-21-2018)
Old 12-20-2018, 09:51 PM   #45
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 288
I miss the old plywood sub floors. I could walk the hell out of a bucket on them .
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 12-20-2018, 10:08 PM   #46
Drywall Slave
blacktop's Avatar
Rewards Points: 288
Painted plywood sub floors are sweet for bucket walking.
blacktop is offline
The Following 6 Users Say Thank You to blacktop For This Useful Post:
Dirtywhiteboy (12-21-2018), hdavis (12-20-2018), overanalyze (12-24-2018), Peter_C (12-20-2018), rustyjames (12-22-2018), SmallTownGuy (12-21-2018)
Old 12-22-2018, 04:30 PM   #47
Trade: Masonry
@ 44 above: Here Shear walls transfer right angle loads into the foundation through anchor hardware,
The Majority of shear walls being parts of the "envelope".
The designated SWalls having a PE stamped nailing/fastener layout.
In some Seismic Zones, Types of Gypsum panels are used to DAMPEN Earth Quake movement through their rubble-rizing the solid Gyp boards , the dampeners needed to replaced prior to reoccupation... the size and type of materials need to exactly match the test versions.
Old 12-23-2018, 10:37 AM   #48
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,659
Simpson uses OSB in their Strong Wall Shearwalls, so it must have some legit.
rescraft is offline
The Following 2 Users Say Thank You to rescraft For This Useful Post:
Calidecks (12-23-2018), overanalyze (12-24-2018)
Old 12-23-2018, 10:54 AM   #49
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,252
good point !!
JFM constr is offline
Old 12-23-2018, 01:46 PM   #50
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,028
Originally Posted by Deckhead View Post
... in all the hurricane aftermath I've ever been to, the OSB always fails more often...
I have to wonder how much of the damage is just due to it being a poorly, quickly, or cheaply built home that used OSB because it's cheaper. The well built expensive home might have also used OSB but because they didn't cheap out on everything else you're not seeing damaged OSB there because the house is still intact.
I don't really have any idea if that is the case, but it does make sense, no? We're more likely to see cheap material fail in a cheaply built house because the whole structure failed. The house that doesn't fail we're just not seeing it either way so maybe it's ply and maybe it's OSB.
SPG is offline
Old 12-23-2018, 01:58 PM   #51
JFM constr's Avatar
sure makes sense to me ,must be part of it .40 yrs ago i heard the same said about plywood .
Old 12-23-2018, 02:00 PM   #52
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,372
If OSB is getting wet it's not a problem with OSB. That's like blaming the oil in your car for the water that's in it. .
Mike.
_______________
Calidecks is offline
hdavis (12-23-2018), Justin Rhoades (12-23-2018), overanalyze (12-24-2018)
Old 12-23-2018, 07:40 PM   #53
Trade: Masonry
sooner or later everything in a home with indoor plumbing/under a roof, is going to get wet... Why use materials that can't survive getting wet to build with?
Think of the decades of cheaper insurance/repair costs.
Can any home with OSB last even Two hundred years? A hundred maybe????
My engine oil has an additive to absorb some water, which then the 205 degree Fahrenheit thermostat that "boils" the water out of the engine oil during longer trips, (helped out by the partial vacumn of on the crankcase created by the PVC system)
less H2O, in the oil, less Acids to corrode important metals like bearings and compression rings...
Old 12-23-2018, 07:51 PM   #54
GC/carpenter
Calidecks's Avatar
I've lived here 27 years never once had a leak that I didn't find out about immediately. And it sure as **** didn't get so wet it would've damaged osb . Not anymore than a rain storm during framing. Which I've been on many times without a failure. If you have a leak that last long enough to do extensive damage to your osb shear walls the shear walls are not the problem.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Dirtywhiteboy (12-23-2018), overanalyze (12-24-2018)
Old 12-23-2018, 07:55 PM   #55
GC/carpenter
Calidecks's Avatar
Now go ahead someone give me an unlikely scenario where it's more the exception. Lol!
Any length of time of consistent moisture will damage any wood product.
Mike.
_______________
Old 12-23-2018, 08:37 PM   #56
Rewards Points: 958
Some multi million dollar home frame jobs get exposed to weather for months and months and the OSB is still fine. Discolored maybe but still fine.
Old 12-23-2018, 08:38 PM   #57
Rewards Points: 958
Never had an insurance company quiz me on wether OSB or plywood was used.
Old 12-23-2018, 08:43 PM   #58
Trade: Masonry
Rusty Hot water heater, bad steam valve on Heater, leaks caused by over pressure on city mains. Common in high relief terrain areas.
Old washer hoses, clothes and dish....furnace condensate lines leaking, plugged AC coil pan drains....
Water damage non-flood sourced is the 4th leading home insurance claim.
Big Johnson, I'd want plywood to used to REPLACE your damaged panels instead cornstalks....
Some one is still thinking Plywood is worth the $ upcharge, or they wouldn't sell ANY.
Old 12-23-2018, 08:47 PM   #59
Dirtywhiteboy's Avatar
Rewards Points: 13,204
I have never lived or worked in a one hundred year old house.
Man they must smell musty
I didn't know the plumbing and wires lasted that long
Dirtywhiteboy is offline
Old 12-23-2018, 08:52 PM   #60
diplomat
Rewards Points: 742
lots of 4 story apartment complexes going up here in the winter with OSB. Ultimately it gets well protected with multiple redundant layers of flashing, weather resistive barriers, rain screens, siding, etc.
A plumbing leak or two in the next 100 years isn't going to condemn the building.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
NYgutterguy (12-23-2018), overanalyze (12-24-2018)
Walls paneling with 1/4 or 1/2" plywood. tipitop Finish Carpentry 9 05-19-2016 01:54 AM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
