Osb Vs Plywood In Shearwalls - Page 2 - General Discussion - Contractor Talk
Old 12-17-2018, 08:47 PM   #21
diplomat
Golden view's Avatar
Rewards Points: 1,550
Re: Osb Vs Plywood In Shearwalls
Originally Posted by Dirtywhiteboy View Post
advantech is very strong stuff. It has something in it to repel water too. We use it for the whole house.
I've wondered if that also repels thinset when putting down underlayment for tile.
Golden view is offline
Old 12-17-2018, 08:54 PM   #22
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,798
I doubt it, thinset is sticky ****. Plus the thinset isn’t supposed to hold the underlayment, the fasteners are. Thinset is just to fill voids.
Big Johnson is online now
Caleb1989 (12-17-2018)
Old 12-17-2018, 08:56 PM   #23
diplomat
True, unless the underlayment is ditra or similar.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Big Johnson (12-17-2018), overanalyze (12-20-2018)
Old 12-17-2018, 09:00 PM   #24
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,004
Thinset over Advantech is good for filling voids, but I don't know of anyone who will warrant tile on thinset on Advantech.
Tinstaafl is online now
Old 12-17-2018, 09:18 PM   #25
diplomat
Schluter warranties installation over OSB.
Old 12-17-2018, 10:11 PM   #26
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,834
3/4" AdvanTech subfloor is a whole "nother thing from 7/16" OSB on a shear wall or roof assembly.
hdavis (12-17-2018)
Old 12-17-2018, 10:31 PM   #27
Capra aegagrus
Tinstaafl's Avatar
Advantech isn't just OSB. Ask them. I did, and the answer was no.
Old 12-17-2018, 11:09 PM   #28
diplomat
It is oriented strand board. The best, but still just OSB. I hate marketing BS.
Justin Rhoades (12-17-2018)
Old 12-17-2018, 11:21 PM   #29
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,102
I have no issues with OSB struct 1 for shearwalls. I can't tell you the last time we used plywood. And we're here in siesmic country.
Mike.
_______________
Calidecks is online now
hdavis (12-19-2018)
Old 12-17-2018, 11:22 PM   #30
hdavis's Avatar
Rewards Points: 2,000
Back to shear.
If it's an engineered design, they would have to design using the specific product properties. This may result in a preference one way or the other when specifying the sheathing. Just speculation on my part.
I don't think prescriptive code cares one way or the other, as ling as it's rated for the application.
hdavis is online now
Old 12-18-2018, 12:11 AM   #31
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,406
Mike.
_______________
i will look into what structual 1 is .
JFM constr is online now
Old 12-18-2018, 12:16 AM   #32
GC/carpenter
Calidecks's Avatar
It's called out on our shear and nailing schedule.
Mike.
_______________
griz (12-18-2018)
Old 12-18-2018, 01:40 AM   #33
Designer/Contractor
Rio's Avatar
Rewards Points: 1,272
Well, ever since the seminar by the mold expert I regained being leery about OSB. He said he's seen so many problems with it if it gets wet, said plywood will recover oftentimes but you can be really screwed with OSB.
Regarding Structural 1 I think it's actually Structural I. The reason I do is because on the APA books and tables it shows it as an I and not a 1. This is a minor point but it has come up. In that good presentation up the thread it's called Structural 1 and I've had discussions with plan checkers on it but since that's how it's called by the APA that's how we're calling it.
Rio is online now
Old 12-18-2018, 10:29 AM   #34
GC/carpenter
Calidecks's Avatar
Says right on the OSB a number 1. Iirc
Mike.
_______________
Rio (12-18-2018)
Old 12-18-2018, 11:29 AM   #35
Designer/Contractor
Rio's Avatar
Mike.
_______________
Thanks, it's confusing because there seems to be a conflict in the nomenclature. Here's another excerpt from the APA on the subject.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Calidecks (12-18-2018)
Old 12-18-2018, 02:35 PM   #36
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
"Advant" tech type OSB in my experience lasts as long as exterior glued plywood, if not longer.
See JLC article on Tight Air home that had to have the OSB painted to close the pores in the sheathing to pass the air door tests.....
The builders had to "Unside" the home, Paint all exposed sheathing... reassemble.
If your are looking to add some decades of trouble free home living, paint/seal, All the framing and sheathing elements to resist short term moisture events that total normally wood frame homes.
The smart $ Uses Masonry in potentially Wet and damp locations, and I heard it is really popular in the burnt areas of California.
I think there might be just a little Conflation Of seismic damping through destruction of hundreds of fasteners and sheathing connections vs. getting enough connections to achieve 100% loading of the shear panel for wind & other loads.
Fouthgeneration is offline
Old 12-18-2018, 03:53 PM   #37
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,274
Roman numeral I = #1 maybe?
SPG is offline
The Following User Says Thank You to SPG For This Useful Post:
Rio (12-18-2018)
Old 12-18-2018, 04:26 PM   #38
Designer/Contractor
Rio's Avatar
The 2nd link I posted explains it, it's definitely supposed to be Structural I, at least according to the APA.
The #1 might be the exposure rating but I also think that the I looks a lot like 1 so it's been assumed that it is supposed to be Structural 1. I checked it out originally when a plan checker was ragging on us about it.
Rio is online now
Old 12-19-2018, 02:20 AM   #39
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
When referring to World War 1 is it WWI or WW1? WWII or WW2? They are both correct, but typically written with an "I".
Roman numerals: I V X Come on sports junkies, what Super Bowl is it?
Peter_C is offline
Old 12-19-2018, 07:06 PM   #40
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 7,550
Superbowl II
As in this is the second Superbowl I won't watch...
‘ugly and inaccurate because our thoughts are foolish, but the slovenliness of our language makes it easier for us to have foolish thoughts.’ -George Orwell
Deckhead is online now
The Following User Says Thank You to Deckhead For This Useful Post:
Peter_C (12-19-2018)
Walls paneling with 1/4 or 1/2" plywood. tipitop Finish Carpentry 9 05-19-2016 01:54 AM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
