Osb Vs Plywood In Shearwalls - General Discussion - Contractor Talk
Old 12-17-2018, 12:36 AM   #1
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,362
looking for some specs on how osb performs vrs plywood in shear walls.1/2" [10' lengths] was 48$ vrs 1/2" osb was 17$ . On that price difference I need to do a little research . Sure seems like the osb would shed those nails faster .i can imagine it tearing away but maybe with nails a good inch from the outer edge it would perform reasonable well .
JFM constr is offline
Old 12-17-2018, 12:47 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,004
Re: Osb Vs Plywood In Shearwalls
in my experience using osb as shear is the architect/engineers call.
griz is offline
The Following 4 Users Say Thank You to griz For This Useful Post:
Deckhead (12-19-2018), Dirtywhiteboy (12-17-2018), hdavis (12-17-2018), Rio (12-17-2018)
Old 12-17-2018, 12:53 AM   #3
diplomat
Golden view's Avatar
Rewards Points: 1,550
What griz said but I believe in many cases OSB has higher shear rating than ply.
Golden view is offline
The Following 3 Users Say Thank You to Golden view For This Useful Post:
Calidecks (12-17-2018), Dirtywhiteboy (12-17-2018), hdavis (12-17-2018)
Old 12-17-2018, 12:57 AM   #4
Fire up the BBQ
griz's Avatar
likely depend on structure requirements, calcs and type of plywood.
griz is offline
Caleb1989 (12-17-2018)
Old 12-17-2018, 01:03 AM   #5
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Bay Area Retrofit is very generous with information, which in turn probably gets them a ton of jobs. They even have a forum where you can ask questions and they get answered. FWIW they helped write the schedule "A".
Once on link below click on:
"Resources" near top of screen.
"For Contractors"
"Shear wall"
Start reading...
https://www.bayarearetrofit.com/need...-type-plywood/
https://www.bayarearetrofit.com/shear-walls-2/
Peter_C is offline
The Following 4 Users Say Thank You to Peter_C For This Useful Post:
asevereid (12-17-2018), Defenestrate (12-23-2018), griz (12-17-2018), Seven-Delta-FortyOne (12-17-2018)
Old 12-17-2018, 01:06 AM   #6
Fire up the BBQ
griz's Avatar
"For Contractors"
"Shear wall"
Start reading...
very cool site....
thank you...
griz is offline
Old 12-17-2018, 01:13 AM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
It seems to me the use of 10' long or loner special order sheathing would add redundancy at a very low cost for the add strength over the rim joists.
In low rise wood structures many designers don't even realize the use of of 3" and 4" wide studs as a massive labor saver, and allows bigger cavities that = cheaper installed HVAC and higher R values in the field.
My personal experience is that a few hundred dollars spent on using thicker Plywood or OSB on walls, floors and roofs is amply rewarded in the following decades. Roof nails hold much better in 3/4" OSB then 1/2" etc.... 3/4" thick wall sheathing flattens much more of a crooked stud, saving $$ on Dry wall and finish labor....
And the wider studs have more room for nails before spliting into toothpicks
Fouthgeneration is offline
Old 12-17-2018, 01:19 AM   #8
Fire up the BBQ
griz's Avatar
agree w/3x & 4x studs, but they have been called out on 24" or 48" oc to accommodate shear nailing.
had a job where architect called out 3x 6 studs.
due to delay in delivery i rfi'd to use 4x6 & the guy actually argued with me to use the 3x6. I did eventually win, but wtf.....
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
Calidecks (12-17-2018), Fouthgeneration (12-17-2018), Seven-Delta-FortyOne (12-17-2018)
Old 12-17-2018, 10:24 AM   #9
JFM constr's Avatar
i saw the idea that osb had more shear written on a thred in this forum somplace .yet never anywhere else .I kinda dought it .in the book https://www.amazon.com/Wood-Framed-S...l+construction it says use 5 ply plywood over osb but gives me no details .
Old 12-17-2018, 02:08 PM   #10
hdavis's Avatar
Rewards Points: 1,280
Originally Posted by JFM constr View Post
i saw the idea that osb had more shear written on a thred in this forum somplace .yet never anywhere else .I kinda dought it .in the book /www.amazon.com/Wood-Framed-Shear-Construction-Illustrated-Guide/dp/158001996X/ref=sr_1_1?ie=UTF8&qid=1545060013&sr=8-1&keywords=wood+framed+shear+wall+construction it says use 5 ply plywood over osb but gives me no details .
I think there is some confusion there. Nails into OSB may have a higher withdrawal force, but head pull through would be the typical fail, and pull through force tends to be less for OSB. Stiffness of plywood is also better than most OSB, so plywood is the obvious choice.
hdavis is offline
fjn (12-28-2018), Golden view (12-17-2018)
Old 12-17-2018, 02:20 PM   #11
hdavis's Avatar
And here's a link that contradicts what I said - withdrawal is the same, and pull through is higher for OSB.
Now that that's cleared up....
hdavis is offline
Old 12-17-2018, 03:38 PM   #12
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
meh...
https://bct.eco.umass.edu/publicatio...d-and-plywood/
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (12-17-2018)
Old 12-17-2018, 03:42 PM   #13
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,596
I just hate OSB because it completely disintegrates when it gets wet.
I'll go for plywood any day, even with the increased cost. Probably get an extra 100 tears out of the building.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
fjn (12-28-2018), hdavis (12-17-2018)
Old 12-17-2018, 04:27 PM   #14
hdavis's Avatar
Originally Posted by SmallTownGuy View Post
Oops, that's the link I left out....
hdavis is offline
Golden view (12-17-2018), SmallTownGuy (12-17-2018)
Old 12-17-2018, 04:46 PM   #15
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,622
I recall plywood usually being specd for shear walls but never thought about it much
TheConstruct is offline
Old 12-17-2018, 08:12 PM   #16
Trade: Masonry
If the building contains ONE water pipe / fixture that WILL eventually leak, why use standard OSB ANYWHERE under the fixture/ roof?????
Ditto paper faced Drywall products..... in any plumbed area. IMHO
Old 12-17-2018, 08:23 PM   #17
hdavis's Avatar
Bathroom floors get advantech.
hdavis is offline
Old 12-17-2018, 08:24 PM   #18
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,232
I remember when I was a kid my dad made a dog door out of OSB (technically wafer board back then as it wasn’t structural) and rubber tire. I was talking to my dad about how much I hate working with OSB one day and he told me that thing lasted until they sold their house, through 2-1/2 dog lifetimes. It got wet every time it rained.
Big Johnson is offline
hdavis (12-17-2018)
Old 12-17-2018, 08:38 PM   #19
JFM constr's Avatar
thankyou . ok ,looks like i have some adjusting to do .obviously like plywood osb has different grades . but what i got from the article is the 5/8" osb i got for 18$ will do fine for the shear wall i am doing and i will move to using it more often . takes some getting used to .
Old 12-17-2018, 08:44 PM   #20
Dirtywhiteboy's Avatar
Rewards Points: 4,720
advantech is very strong stuff. It has something in it to repel water too. We use it for the whole house.
Dirtywhiteboy is offline
The Following 3 Users Say Thank You to Dirtywhiteboy For This Useful Post:
Fouthgeneration (12-18-2018), hdavis (12-17-2018), overanalyze (12-20-2018)
Walls paneling with 1/4 or 1/2" plywood. tipitop Finish Carpentry 9 05-19-2016 01:54 AM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
